boeing 747-311
Arm Doors And Cross Check?
Sat Jun 22, 2002 3:01 pm
Arm doors and cross check, is that what teh fa's say when they close the doors? or its something like that, what exactly does that mean? thanks a lot in advaced!
boeing 747-311
Come fly with US
flightsimfreak
RE: Arm Doors And Cross Check?
Sat Jun 22, 2002 3:14 pm
It means arm the slides and check the door acrost from you to make sure that F/A did the same.
pilottim747
Sun Jun 23, 2002 1:19 pm
You can see the lever that the flight attendents need to flip each time they get to a gate and then leave. Right by the emergency exit door on the small lever it has two positions that say something like manual or automatic. This just means that the inflatable slide that would come out in an emergency won't pop up if the aircraft is at the gate.
The cross check (as FlightSimFreak explained) is just having the F/A across from you double check the position. It has happened before that a F/A has forgotten to disarm the emergency slide at the gate and it has inflated. As far as I know, however, this has never happened at the boarding door (that would be real bad).
pilottim747
Aviation Photographers & Enthusiasts--Coordinate your life.
boeing 747-311
Sun Jun 23, 2002 2:21 pm
tHANKS guys i appreciate the information that is great, becuase i didnt have a clue exactly what that was!!
Come fly with US
Users browsing this forum: ap305, AsiaTravel, Baidu [Spider], CrimsonNL, flylku, fraT, Google Adsense [Bot], hyd09l27r, JAmie2k9, JerseyFlyer, kraz911, log0008, Mayday111, mjoelnir, Ned Kelly, Revelation, rocketPower, SingaporeBoy, springtx, Tedd, Tokushima, whitefalcon and 325 guests
