babaero
747 Reverser Deployment
Wed Jun 26, 2002 6:27 pm
Look at the following two pictures.Both taken on same day at same location.Looks like No3 reverser has begun to deploy.
One is a landing shot, the other take off.
I understood 747 reversers only deployed once the truck tilt sensor indicated runway contact..
Also both pictures seem to show one of the wing gears missing.
Photo © Michael F. McLaughlin
It is also impossible to lock out a reverser in a partial deployed position.
Any comments
CX Flyboy
RE: 747 Reverser Deployment
Wed Jun 26, 2002 6:40 pm
Perhaps it is just a band around the cowling of a different colour.
...the only way you could deploy the reverser in the air is if the air/ground sensing was such that the aircraft believed it was on the ground.....or if the thrust reverser interlocks failed. Is that correct?
