CactusCMH
A330-200 Vs. -300
Thu Jul 25, 2002 1:13 am
I would like to know is there any way to tell the differences between A330-200 from the 300 just by looking at them. The same question is for A340-200 and A340-300. Thanks!
airsicknessbag
RE: A330-200 Vs. -300
Thu Jul 25, 2002 1:18 am
I know this won´t help you that much, but both -200s look stubby and, in short, well, short. When you see one, and when you can appreciate the length, you´ll know immediately whether it´s a -200 or -300.
Sorry, no real visual differences, they have the same exit layout, so if you don´t want to count windows, you´ll have to rely on your gut feeling.
Plus of course some airlines only have -200, others only -300.
Daniel Smile
ATA L1011
Thu Jul 25, 2002 1:50 am
Besides being shorter the 200 has a taller and larger tail than the 300. The 200 looks alot like a A300 with a longer wing and taller tail.
Treat others as you expect to be treated!
CF-CPI
Thu Jul 25, 2002 4:34 am
The larger tail applies only to the A330-200, not the A340-200, which is externally identical to the -300 except for few fuselage frames. (ATA, your post was clear, I just wanted to emphasize this). I suppose there were some more stringent lateral control issues in case of engine out on a twin vs. a quad.
