fspilot747
767-400 And 777-200...any Major Difference?
Sun Jul 28, 2002 12:28 pm
The flightdeck of the 777 and the 764 are almost identical, if not, identical. The body is very similar. The 777 is slightly wider, yes, but in general, what is the difference? Why would, say, Delta by X number of 764s instead of 772s?
Just curious..
-FSP
The Coachman
RE: 767-400 And 777-200...any Major Difference?
Sun Jul 28, 2002 12:39 pm
The flight controls of the B777 are fly-by-wire whereas the 764 is not.
The 777 has more underbelly cargo space.
The 777 does not have the same type-rating as the 764 (which has common ratings with the 763, 762 and 757).
M88, 722, 732, 733, 734, 73G, 73H, 742, 743, 744, 752, 762, 763, 772, 773, 77W, 320, 332, 333, 345, 388, DH8, SF3 - want
UGA777
Sun Jul 28, 2002 12:46 pm
The 777-200 has more range than the 764. The 764 was designed mainly for high demand domestic routes in Delta's case. The 772 is meant more for international routes.
kaitak
Sun Jul 28, 2002 4:12 pm
1. The 764 is a variant of the 767, the cabin of which is considerably narrower than the 777.
2. The 777's range is considerably higher.
3. Airlines want to buy the 777!
donder10
Mon Jul 29, 2002 3:56 am
764 has wingfences ,772 does not.
fspilot747
Mon Jul 29, 2002 1:19 pm
Alllllrighty then, lol...understood. Thanks for clearing that up.
-FSP
VirginFlyer
Mon Jul 29, 2002 2:19 pm
The 767-400 does not have wingtip fences, it has raked winglets
V/F
It is not for him to pride himself who loveth his own country, but rather for him who loveth the whole world. The earth is but one country, and mankind its citizens.
Celebrating the Bicentenary of the Birth of Bahá'u'lláh, 21-22 October 2017
BA
Mon Jul 29, 2002 2:29 pm
They're two entirely different aircraft.
Simply put, the 767-400 is a 767, and the 777 is well.....a 777.  Smile
Two different familes. Like everyone mentioned, they're also different type ratings.
Two completely different aircraft. Neither is derived from another.
The only things in common with the 777 and the 764 is a SIMILAR flight deck (not exactly the same, but similar) and a very similar cabin interior design.
However, the rest of the 767 series are now available with this "777 style" interior.
"Generosity is giving more than you can, and pride is taking less than you need." - Khalil Gibran
fspilot747
Mon Jul 29, 2002 2:46 pm
VirginFlyer: I know the difference in that sense.. What I meant was like economical difference. What I meant was what is the economical or practical application of a 767 over the 777..
But question answered! Thanks guys.
-FSP
VirginFlyer
Mon Jul 29, 2002 2:54 pm
FSPilot747 - oops, sorry I was ambiguous, I was actually refering to Donder10's post, not yours
V/F
BA
Mon Jul 29, 2002 3:05 pm
FSPilot747,
The 767-400 isn't exactly an excelent aircraft from an airline's perspective.
It does a job well done for high density domestic routes (like what Delta uses them for), but when it comes to long-haul transatlantic runs, that is when it's weaknesses start to really show up.
Compared to the A330-200, it's not much when it comes to transatlantic operations. One of the reasons is because it's a 767. Airlines love hauling as much cargo as they can on long-haul routes. The A300/A310/A330/A340 all have much larger cargo bays which are capable of carrying much more cargo than the narrower 767.
This is where the 767's biggest weakness takes its toll.
Another reason is economically, it's not as efficient as the A330-200. Range is also relatively limited on the 764. It can do transatlantic runs of course, but it can't do transpacific runs which is a big limitation.
Best example to show the 767's weakness is KLM. Currently KLM has many 767-300ERs. They operate an all Boeing fleet, no Airbuses. However recently they placed an order for 6 A330-200s. The reason for this is simply because the A330-200 is a better aircraft.
Even officials at Boeing admit that the A330-200 is a better aircraft and it truly is.
Now that doesn't mean the 767-400ER is a bad aircraft. It's still a great aircraft and it does an excelent job when it comes to high density domestic routes like how Delta uses them.
Continental uses them on long-haul routes, and they seem to be doing fine.
However, the biggest mistake Boeing did lately in my opinion is shelving the 767-400ERX which would have a fuel tank in the tail, which would boost it's range very close to the A330-200s.
Many airlines have expressed interest for this longer range 767-400, however Boeing decided to shelve it. Biggest mistake ever.
With the 767-400ERX, Boeing can steal a lot of A330 orders.
I am sure KLM would have waited for the 767-400ERX instead of the A330-200 if Boeing decided to continue with it.
There is still a chance that it might be developed though. Boeing simply shelved the project.
I'm assuming when the economy improves and air travel returns to normal, Boeign will go ahead and develop the 767-400ERX. This will be a big score for Boeing for sure.
There was a discussion about the 767-400ERX a couple days ago. You might want to search for it.
