ChautauquaFA
Is The 757 Cabin The Same Width As The 737?
Wed Jul 31, 2002 2:15 pm
Having just flown on a 757 a couple days ago, I noticed that the cabin seems wider and taller than a 737. I'm pretty sure it is the same, and that it's just the way the cabin interior is layed out, it just gives it a more open feel. Can anyone answer this?
Derek
b757300
RE: Is The 757 Cabin The Same Width As The 737?
Wed Jul 31, 2002 2:23 pm
If I remember correctly and my brain isn't fried after writing a Spanish paper for the last 11½ hours, the 707, 727, 737, and 757 all have the same cabin width.
"There is no victory at bargain basement prices."
BA
Wed Jul 31, 2002 2:25 pm
Yes, they are exactly the same.
"Generosity is giving more than you can, and pride is taking less than you need." - Khalil Gibran
MarkTPA
Wed Jul 31, 2002 3:05 pm
Yes,
They are all the same width. It is an optical illusion, the 757 just seems wider because of the layout and the legnth of the cabin.
Leo
Wed Jul 31, 2002 3:29 pm
Boeing builds only ONE narrowbody cross section (and cockpit)........
...the 1957 design for the B707 !!!
...and uses it over and over and over again.......
B727-100
B727-200
B737-100
B737-200
B737-300
B737-400
B737-500
B737-600
B737-700
B737-800
B737-900
B757 but, ...... new nose section
B757-300 but, .....new nose section
This can only mean the Boeing cross section is a living classic...
KLM-MD11
Wed Jul 31, 2002 5:20 pm
Yes, same width, and too bloody narrow!!
klm-md11
GELUK IS GELUL MET EEN K
RickB
Wed Jul 31, 2002 6:51 pm
Leo - they have two narrowbody cabin widths now, the 717 has a much narrower cabin !! I think Boeing need to start rationalising their cabin widths (5 is way too many) to reduce costs.
RickB
Trident
Wed Jul 31, 2002 8:00 pm
Obviously the 717 is not of Boeing's design being a Douglas DC-9 at heart.
Leo
Wed Jul 31, 2002 8:19 pm
RickB:
Trident is absolutely right, no one would call the B717 a ..... Boeing!!
Leo
Wed Jul 31, 2002 8:23 pm
.....Because it clearly is a classic ............ Douglas ..!!!
Greg
Wed Jul 31, 2002 11:07 pm
I think the useable interior cabin width actually is 2" wider than it was from the original design due to thinner insulation and closer molded cabin walls.
Just my .02
CoAir@IAH
Wed Jul 31, 2002 11:22 pm
How much wider and taller is a a319, than say a 735?
Andrew
fly_emirates
Thu Aug 01, 2002 1:39 am
compared to airbus narrow bodies, Boeing 757,737 windows are lower, and some how uncomfortable. but on Airbus even though they might seem smaller, they are higher so still you can see comfortably
trident3
Thu Aug 01, 2002 2:11 am
The 757 was of course originaly designed with the same forward fuselage as the 727 which would have meant an even higher degree of commonality.
"We are the warrior race-Tough men in the toughest sport." Brian Noble, Head Coach, Great Britain Rugby League.
tupolev154b2
Thu Aug 01, 2002 2:39 am
Wider. Sometime ago I flew on a 57 right after flying on a 37. On the 37 my head was a bit above the top of the window while on the 57 it was a bit below it.
gr8slvrflt
Thu Aug 01, 2002 4:28 am
I'll have to research this one but I think that although the 757 shares the floor-width dimension with the 707/727/737 the fuselage cross-section is actually quite different.
I work for Southwest, but the views expressed are my own and do not necessarily represent those of Southwest.
Greg
Thu Aug 01, 2002 5:35 am
The 707 is different from the 737/727/757. The lower lobe is considerably shorter on the later aircraft. Also, while similiar looking, the 727 and 737 share only the windscreen from the 707. The nose, while similiar, is a different shape (and of course, the 757 is totally different).
