f.pier
707-777 Comparasion
Sat Aug 03, 2002 8:56 pm
The 707 was the plane which introduced long lange flights. It made the transoceanic flights possible. Now there is the 777, its nephew.
What about a comparasion? The lenght, the wings, the weight, the number of seats, the engines, the costs.
I think it would be quite interesting.
Was it possible to fly non stop routes from Europe to Los Angeles with 707?
delta-flyer
RE: 707-777 Comparasion
Sun Aug 04, 2002 5:04 am
Here are some interesting comparisons.....
Boeing 707-320B versus 777-300ER (from the Boeing web site):
Length...........153 ft..........242 ft
Wingspan.......146 ft..........213 ft
Cruise spd......607 mph......555 mph
MTOW...........336,000 lb....750,000 lb
Range...........6160 miles....8300 miles
Pax .............141 (2 cl.......365 (3 cl)
Thrust...........72,000 lb......230,000 lb
Ceiling...........36,000 ft......35,000 ft
Note the new plane flies 35% farther, but weighs 14% less per passenger at take-off.
I seem to recall that there were polar flights to Europe from the west coast, but sometimes they would make a fuel stop in Canada on the westbound leg.
Pete
"In God we trust, everyone else bring data"
411A
Sun Aug 04, 2002 7:30 am
Actually, the B707 was the first jet aeroplane that could carry more fuel (weight) than the airframe empty weight (-300 series).
In addition, as I have personally operated the 707 to FL410...it goes just slightly higher than 36,000ft.
BOAC (now BA) operated the first LAX-LHR flights with the 707 'round about 1962. Also AirFrance operated LAX-ORY at about the same time.
CV990
Sun Aug 04, 2002 8:20 am
Hi!
It's too difficult to compare the 707 with the 777! But I would like to see the 777 beeing compared with the DC-8-62 or the 747SP, those where great ultra-range airliners, the 707 was not a long-ranger, the 720B was better than the 707.
I think air transportation evoluted a lot in these past few years, what I like in the 777 is that we can handle passengers like the old Classic 747's with only 2 engines, that a great achievement.
regards
CV990, the Maserati of the skies!
411A
Sun Aug 04, 2002 8:50 am
Hi there CV990.
FYI, the 720B carried no center tank fuel, 'twas a medium rande airliner, and designed thus.
Have personally flown the 707 for 12:25 (ATH-HOU) non-stop. Long enough for you?
CV990
Sun Aug 04, 2002 11:39 pm
Hi!
411A
According to my figures the 707-320C had a range with max payload of 4.300 mls ( 6.920 Kms ) and the 720B had a range with max payload of 4.110mls ( 6.450 kms ). So it's not just a big diference betwen both. About flying ATH-HOU in 707 non stop, that doesn't mean you have a bigger range, that means that the pilot really saved a lot of fuel flying in a great flight level and flying a very economical speed!!! You know, you could actually fly a CV990 from USA to Austria without making a tech-stop? Yes!!!! And the CV990 had a range of just 3.800 mls ( 6.115 kms )! The 720B had the same wing of a 707 with less payload, so that why it was used in special long routes where less passengers and less payload was needed. Boeing was very wise because they used the 720 to catch clients and letter offer them the longer 707, look at airlines like Ethiopian, AA, Saudia, El Al, Avianca, Aer Lingus, Northwest..... they started with the 720 and latter evoluted to the 707, brains, brains in Boeing!
regards
411A
Mon Aug 05, 2002 11:22 am
CV990
Having flown both the 707 and 720B, I can assure you that your figures are quite wrong.
The 720B had no (as in none) center tank fuel, so could not fly as far as the 707, with the same payload.
The 720B wing is NOT the same as the 707 (no fillet flaps on the 720).
If the 720B was flown on the route I mentioned before, with the same payload, it would be "dry tanks" approaching Bermuda.
In case you don't know, this ain't good.
CV990
Mon Aug 05, 2002 5:21 pm
Dear 411A
I took this information from an old book written by William Green & Gordon Swanborough, so I'm not just throwing numbers up in the sky. Now can you please give me the numbers you have so we can compare? Also please explain me what's "no fillet flaps", because I don't understand that!
411A
Tue Aug 06, 2002 3:08 am
CV990
Do a search about fillet flaps for the 707, you may even be able to see them on a photo on this web site.
A little project for you. Have a look at the fuel capacity of the 707-320B and compare this to the fuel capacity of the 720B. Figure 12,000 pounds/hr for the 707 and 10,000 pounds/hr fuel burn for the 720B, do the math and see what you come up with.
Its OK to ask questions, but you have to do a little work as well, if you want the answers. Nobody ever said that aviation was easy.
transswede
Tue Aug 06, 2002 3:59 am
It looks like Boeing already has their SC - the B707!  Smile It flies almost 10% faster then the 777...
Areopagus
RE:
Tue Aug 06, 2002 5:33 am
My understanding was that the KC-135, 707-120, and 720 used the same wing, which had a straight trailing edge, whereas the intercontinental 707-320 had a new (or heavily revised) wing with a bend in the trailing edge which added area inboard.
CV990
Tue Aug 06, 2002 5:43 am
Hi 411A.
Please explain me what you mean by "Nobody ever said that aviation was easy", because for for me aviation is an hobby, I like to receive more and more information from people that is willing to give it. If you really are what you are you should at least try to help those that know less than you. I've really good friends that have the same job that you here in Portugal, true gentlemans people that started flying with TAP/Air Portugal since 1945 and everytime I wanted to know a little bit more about aviation they where really happy to give all the details and clear all the doubts I had. I think you came from a different school!!!
thanks and I will not bother you again, I'll get the information from people that think " Aviation is easy"!
regards
411A
Tue Aug 06, 2002 9:31 am
Areopagus
Your information is quite correct, clearly you have done your homework...top of the class to you Sir! In addition, leading edge devices were different, some full span, some not. In addition, one particular 707 model was shorter than even a 720, do you know which one? Hint, Qantas operated same.
Those that do not want to invest just a little effort (CV990?) will find aviation a tad harder than they expected. That's life, some realise, some don't.
