LH Code On SAS Cargo Flight?
Thu Aug 29, 2002 8:55 am
Just want to ask that are the SAS Cargo MD11 operated by Lufthansa Cargo under code-share agreement? (Like LH code on SAS Cargo flight)
SAS Cargo currently flies:
Gothenburg-Fairbanks-Osaka
Gothenburg-Sharjah-Hong Kong
Does LH Cargo actually code-share on SAS Cargo flight?
fritzi
RE: LH Code On SAS Cargo Flight?
Thu Aug 29, 2002 3:42 pm
LH Cargo code-shares with SAS cargo becuase SAS doesn´t own any cargo planes.
I think that all of the flights have LH codes.
ARN
Thu Aug 29, 2002 8:23 pm
How are these operations managed? Does LH have their crews based in GOT? Or do all cargoflights from GOT originate in FRA?
GOT
Thu Aug 29, 2002 10:48 pm
I think that all crews are based in FRA and that all flights originate there. I don't know if the flights are code-shared in any way (is there a need when it's Cargo?), but I know for sure that the MD-11F's that come to GOT use both Lufthansa and Scandinavian callsigns.
Hope this helps
GOT
Just like birdwatching - without having to be so damned quiet!
johnnybgoode
Fri Aug 30, 2002 5:02 am
well, that flight is operated by LHCargo aircraft, and i believe it is also a codeshare with JAL cargo.
the GOT-SHJ-HKG should also be routed via FRA, i suppose, since LHcargo does not operate anythig else from GOT than the aforementioned routings, afaik.
cheers
daniel
If only pure sweetness was offered, why's this bitter taste left in my mouth.
