ATl, Largest L-1011 Airport?
Thu Sep 05, 2002 12:48 pm
Hello all,
Before Delta retired the great L-1011 Tristar, Which airport got the most L-1011 service? I seem to think ATL since its Delta's largest hub and also due to their route structure. I know places like DFW, LAX, MCO & HNL got a lot of them to.
MCO-ATL
IMissPiedmont
RE: ATl, Largest L-1011 Airport?
Thu Sep 05, 2002 1:56 pm
You forgot MIA. I think it had the most L10s of any airport at the Tristars peak.
The day you stop learning is the day you should die.
HlywdCatft
Thu Sep 05, 2002 9:45 pm
Probably ATL with all the Delta L1011s
But remember in the 80s at Miami Eastern and Pan Am both had hubs at MIA and both had L1011s, but then also ATL had an Eastern hub too.
Nowadays, I might say IND is the biggest L1011 hub with the remaining few from ATA.
akelley728
Fri Sep 06, 2002 12:20 am
Last time I was at Toronto there were still a number of Air Transat L1011s there. This was a few months ago, though.
gr8slvrflt
Fri Sep 06, 2002 12:52 am
Probably ATL in the 70s and 80s with dozens EA and DL L-1011s on the ground at the same time. Also MCO, MIA, PBI & FLL. In addition EA, DL, AC and TW all flew many TriStars into LGA and JFK.
I work for Southwest, but the views expressed are my own and do not necessarily represent those of Southwest.
United_fan
Fri Sep 06, 2002 1:25 am
L1011 lovers should go to GSO.When I was there last month there were at least 8 there.Even the only TWA L to be painted in new colors.
Champagne For My Real Friends,and Real Pain For My Sham Friends
ATA L1011
Fri Sep 06, 2002 1:56 am
AtL was the busiest up to ther 90's with 1011 traffic. Dont forget STL saw alot of them as well because of the TWA hub, as well as LAX in the 70's-90's with DL,TWA,EAL,HA,ATA and AC. I also think LAX was one place that just about all of the majors operating it in that time frame sent 1011's to.
Treat others as you expect to be treated!
