aussie_
Boeing Ground Qantas And Virgin 738s
Sat Sep 14, 2002 10:19 am
Due to a fault in the tail. Causing minor disruptions across the network (being Saturday, there are spare a/c around).
More news as it comes to hand.
tsentsan
RE: Boeing Ground Qantas And Virgin 738s
Sat Sep 14, 2002 10:20 am
6x Qantas 737-800s, and 2x Virgin Blue 737-800s are affected.
All aircraft (except 1 QF) are expected in the air by lunch time, currently 1x QF and 1X DJ is back in service.
NO URLS in signature
aamd11
Sat Sep 14, 2002 10:47 am
WOW, this is strange. Was it Boeing who grounded the aircraft or the CAA[ or whatever the aviation authority down there is called]?
What is the actual "fault"?
does anyone know?
A^A MD-11
wirraway
Sat Sep 14, 2002 11:07 am
Qantas, Virgin ground planes
September 14, 2002
QANTAS and Virgin have been hit by a grounding order by Boeing on their 737-800 jets this morning.
Qantas spokesman Martin Sharp said the airline received notification overnight from the manufacturer.
"The order affects six of our jets, one is back in service, another four are expected to be back in the air by lunchtime and the sixth, which is in Townsville, will take a little longer," he said.
Virgin airlines was forced to ground two of its planes, airline spokesman David Huttner said.
"We got the order overnight, which affected two of our planes," he said.
"Boeing said they were concerned about a batch of these parts which are part of the plane's operating systems and we take the most conservative approach, which of course is replacement," he said.
"The part was replaced on one jet overnight and the other was flown to Melbourne for the replacement and will be back in the air by lunch time.
"There was some inconvenience for passengers flying from Sydney to Melbourne, but they understood it was a matter of safety first," he said.
AAP
BR715-A1-30
Sat Sep 14, 2002 11:16 am
What was the part called, and what role did it have in-flight?
Puhdiddle
aamd11
Sat Sep 14, 2002 11:19 am
Something to do with the rudder perhaps?
the part being in the tail, it is possible it is rudder related.
Lets wait and see before we jump to [the wrong] conclusions.
Best Regards
A^A MD-11
wirraway
Sat Sep 14, 2002 11:21 am
from Bloomberg:
Boeing, the world's No. 1 planemaker, identified a potential fault with a back-up device for the flight-control hydraulic system of some of its 737 aircraft, Qantas spokesman Michael Sharp said in an interview.
Boeing spokeswoman Liz Verdier said the company discovered during flight tests that flight-control modules on some of its ``next-generation'' 737s were failing, and that a supplier had provided faulty parts in some cases.
The problem may affect about 60 of 1,300 737-600, 737-700, 737-800 and 737-900s in service worldwide, Verdier said. Operators should check to see if they have one of the parts identified by the supplier as potentially faulty and replace it if necessary, she said.
Wirraway
aamd11
Sat Sep 14, 2002 12:57 pm
Not something to be taken likely then,
congrats to Boeing to identifying the problem,
shame that such problems do arise, but there is always soemthing that can go wrong, and this time it seems, it was found before something went horribly wrong.
A^A MD-11
