FrequentFlier
Best Way To ATL
Tue Sep 17, 2002 10:32 am
I'm looking to fly to ATL from NYC in Nov.
I've looked at DL from LGA and HPN, and Air Tran from LGA as well as CO from EWR. However, while LGA has dirt cheap prices, HPN is much more convinient, and CO would allow me to take advantage of FF miles.
What should I do?
exusair
RE: Best Way To ATL
Tue Sep 17, 2002 10:55 am
HPN generally has higher fares due to having to connect through a hub such as PIT or PHL on US or via CVG on Comair. Try EWR on Delta , AirTran, USAir and CO. You might even be able to find a fare via America West through CMH.
OPNLguy
RE: Best Way To ATL
Tue Sep 17, 2002 10:57 am
Airtran $158 RT LGA-ATL-LGA
Delta $269 RT HPN-ATL-HPN
Continntal $176.50 RT EWR-ATL-EWR
Assuming your 16-20 age profile is correct, you have to ask yourself if going on CO out of EWR just to capture the FF miles is worth the extra $18.50, especially if you're alot of FF miles away from a reward ticket.
Assuming it's not, you then have to ask yourself if it's worth $111 of convenience to fly DL out of HPN versus Airtran out of LGA. If it is, you have your answer. If it's not worth the $111, especially if you're paying for this trip with your own money, I'd head to LGA....
($111 will buy some fun in ATL...)  Big grin
CMK10
RE: Best Way To ATL
Tue Sep 17, 2002 11:11 am
It all depends on where your from. If you from a place like Danbury, CT, maybe HPN is better because its a lot closer. But if your from Westchester County, saving the money by going to LGA or EWR is smarter. If it was me I'd take the AirTran, unless your a bigtime CO FF man.
DC-10's Forever
"Traveling light is the only way to fly" - Eric Clapton
America West
RE: Best Way To ATL
Wed Sep 18, 2002 10:31 am
---You might even be able to find a fare via America West through CMH.---
America West doesn't fly to Atlanta from Columbus.
STT757
RE: Best Way To ATL
Wed Sep 18, 2002 10:44 am
travatl
RE: Best Way To ATL
Wed Sep 18, 2002 12:20 pm
When did HP drop CMH-ATL. I thought they were running ERJs on the route?
Travis
jcs17
RE: Best Way To ATL
Wed Sep 18, 2002 12:24 pm
When I used to live in Atlanta and go to New York I probably flew connecting flights on CO 2 or 3 times, try checking fares out LGA,HPN-ATL on CO through CLE. If you are interested in FF miles that is the way to go.
JCS
America's chickens are coming home to rooooost!
America West
RE: Best Way To ATL
Thu Sep 19, 2002 1:03 am
---When did HP drop CMH-ATL. I thought they were running ERJs on the route?---
They dropped it some time ago. I'm not sure of the exact date. I thought they used to fly it with the CRJ.
The only airline that flies CMH-ATL non-stop is Delta.
flyCMH
RE: Best Way To ATL
Fri Sep 20, 2002 2:51 am
America West's CMH-ATL route was the first route to be flown with Chautauqua's ERJ-145's. The route was discontinued after Sept. 11 along with CMH-MDW.
712,722,732/3/4/5/7/8/9,744,752/3,762/3,772/3,788,318,319,320,321,332,333,343,346,380
D93,M88,M11,F100,B11,L10,146,CR1/2/7/9,E35/40/45/70/75/90,E20,SF3,ATR,AT7,J41,DH1/3/4
