Jetpilot/ 727 30 Degree Flap
Fri Oct 22, 1999 2:03 pm
I know some airlines do not allow there pilots to use 40 degree of flaps as it is said to be too much. That is why on all the modern airliners they only have 30. Do you guys know of any airlines that have inserted a bar across the flap control so there is no way you can get the 40 degree? And jetpilot what are the rules with US air?
Iain
calpilot
RE: Jetpilot/ 727 30 Degree Flap
Fri Oct 22, 1999 11:14 pm
At CO our B727's do have the block at the 40' mark.
However it could be removed for an emergency.
40 degrees can give the airplane a higher landing
weight and a lower approach speed,shorter landing
distance; but higher fuel useage, and with noise
rules, way to many decibels to be allowed. Most
domestic airlines that I know of, I belive operate
that same way for those reasons.
G.L.
jim
Mon Oct 25, 1999 12:15 pm
Delta's 727s are modified as CALpilot states.
JETPILOT
Mon Oct 25, 1999 12:46 pm
Our aircraft are also limited to the 30 degree flap setting. It's all due to noise abatement. The feds actually watch to make sure were not comming in at flaps 40 at aiports like LaGuardia.
The difference between Vref 40, and Vref 30 is only +5 knots. No big deal.
Good to see you back Iain.
