RoastedNutz
Why No Portable Electronics Below 10K Ft?
Thu Oct 03, 2002 2:31 am
Why is it "safe" to use portable electronic devices (i.e. CD players, laptop computers) once the aircraft is over 10,000 ft. ?
myself
RE: Why No Portable Electronics Below 10K Ft?
Thu Oct 03, 2002 2:58 am
Above 10,000 ft, the results of a possible interference with aircraft equipment is less critical, meaning the pilots have more time to respond to the aircraft electronics going nuts.
Below 10,000 ft means the aircraft is in a critical flight phase (either approach or departure) and interferences might have a devastating effect.
LN-MOW
Thu Oct 03, 2002 3:30 am
It has to do with the fact that everything has to be stowed away in order to be able to evacuate the aircraft if necessary, and also be able to hear the command being given. Or any other urgent information given by the flight crew.
- I am LN-MOW, and I approve this message.
