B737-112
Wow, United 747-400 LAX-SFO
Thu Oct 24, 2002 6:34 am
This must be a relocation flight that I found on United.com. I then checked every Saturday through Christmas but no other 744's were seen.
Flight Number: United Airlines 864
Aircraft Type: Boeing 747-400
Departure City: LAX
Departure Date/Time: Oct 26 2:15P
Arrival City: SFO
Arrival Date/Time: Oct 26 3:40P
ContinentalEWR
RE: Wow, United 747-400 LAX-SFO
Thu Oct 24, 2002 7:26 am
And you wonder why their nearly bankrupt!!! Seriously, they are probably re-positioning an aircraft.
FutureFO
Thu Oct 24, 2002 8:18 am
It is on that to:
1) it continues Change of gauge service from SAL.
2) it goes to SFO for MX and in position for the Trans-Pac service the next day.
I Don't know where I am anymore
Thu Oct 24, 2002 9:23 am
When you position an aircraft from point A to point B, it might be empty, but if you can sell a few fares, why not do it...
xxx
I dont see any criticism necessary. Flying a 747 from SFO to LAX, does it require a report on first page of the LA Times and SF Chronicle...?
Sounds to me that it would be better in the National Inquirer for some...
(s) Skipper
cedarjet
Thu Oct 24, 2002 9:31 am
It could be a glitch in the system. Maybe it's a 737 that connects with a 747. If you put Baltimore to Sydney in, you'll get 747 for the equipment but it's actually a 757 that connects with a 747 in SFO, all on one flight number. Maybe this is like the system incorrectly showing a BWI-SFO 747 because of the continuing service.
If you put LA to Manila in for UA864, the CRS might state equipment 747 on the screen but it's really a 737 LA-SFO connecting to a 747 SFO-Manila, again all on one flight number.
EA CO AS
Thu Oct 24, 2002 10:10 am
It IS a change of gauge, but going from an A-320 on the SAL-LAX segment to a B-747-400 on the LAX-SFO segment. However, this only occurs on 26OCT, supporting the possibility that it's simply to reposition the aircraft.
Hope this helps!
»v*ua864/26oct«
26OCT DPTR ARVL MEALS EQP ELPD ACCUM MILES SM¶
SAL LAX C 800A P 1205P B /B /B 320 5.05 5.05 2313 N¶
ARR-TERMINAL 6 ¶
LAX SFO P 215P 340P 744 1.25 8.40 330 N¶
DEP-TERMINAL 6 ARR-TERMINAL 3 ¶
STAR ALLIANCE ¶
FutureFO
Thu Oct 24, 2002 11:15 am
It is in the schedule as far as I looked and that was until after Thanksgiving. Unless they pull it before then.
Spark
Thu Oct 24, 2002 11:18 am
I think even during our recession there is more than enough demand on a SFO-LAX flights to fill 747s.
mel
Thu Oct 24, 2002 4:08 pm
I flew the same route on Saturday, and it was operated by a 747-400 N119UA. The aircraft load was as follows: F12/C8/Y84 out of F14/C73/Y260 (i think that's the 744 capacity). We were non-revving and were able to get into First Suite. Got some photos, and hope to upload them onto airliners in the next 2 weeks. Flight duration was 46mins at FL350. The climb to FL350 took only 11mins. The aircraft was towed to the maintenance hangar at SFO shortly after it was fully unloaded.
NO URLS in signature
trickijedi
Fri Oct 25, 2002 12:11 am
This flight is a continuation of the SAL to LAX flight which is operated on a A320. Keep in mind that this flight is only flown on Sat. and has been going on for a while now.
Check these flights out operated by a 767:
LAX-SFO:
UA 1008 Oct 30
UA 1800 Oct 31
UA 1818 Dec 1
SFO-LAX:
UA 865 Oct 30
UA 1207 Dec 1
Its better to be on the ground wishing you were in the air than be in the air wishing you were on the ground. Fly safe!
wn700driver
Fri Oct 25, 2002 2:04 am
We should file this thread under "Hello & Welcome to Last Week!!!"
I've only mentioned that I have flown that route/AC/carrier combination six times in the last few months, under various threads, usually title "what's the biggest plane you've flown under an hour/shortest route etc..."
It's really no secret that any of the big leaguers reposition the planes in the late afternoons, or at night.
Do a search before posting, no wonder the database is overflowing there. It's all about doing your homework, people...
Base not your happiness on the deeds of others, for what is given can be taken away. No Hope = No Fear
planenutz
Fri Oct 25, 2002 4:05 pm
I know that UA has historically collapsed say 3 737 LAX-SFO flights into a 744. They used to do this a lot when the Shuttle product was still in operation. If they had only a handful of seats sold on a series of flights, or if there was a weather delay into SFO, they would load the 733 pax into a single 744 flight.
Wn700Driver: This is a FORUM. I think that anyone should be able to post whatever they want as long as its about aviation. Thats the point of a forum: to discuss. If someone has question or inquiry, people in the know should answer it. Even if its been discussed or answered before.
Not all who wander are lost....
USAFHummer
Fri Oct 25, 2002 11:32 pm
Ive done a repo flight, USAirways A330-300 PHL-PIT...a one day only thing to position it for a PIT-LGW flight I think, flight #740 on 3/16...the plane was pretty empty and the fares were dirt cheap...repo flights are not uncommon...
Greg
