MAH4546
MIA Pushing For Lagos Flights
Thu Nov 07, 2002 12:26 am
With the start of the first Nigerian-American Chamber of Commerce, based in Miami, MIA has extended it's efforts to bring non-stop service between Miami and Lagos, Nigeria, by both plane and cargo ships. Little details on how they are going to lure the service, but they have reportedly began talks to try to make it happen. A non-stop Miami-Lagos service would have a flying time of only six hours. Right now, it takes as much as 14 hours to travel between the United States and Lagos via Europe. A Miami-Lagos service would be the quickest route between the United States and Africa, and will allow for connections from all over the US.
a.
haveric
RE: MIA Pushing For Lagos Flights
Thu Nov 07, 2002 12:36 am
Isn't Lagos airport deemed by the State Department as unsafe for Americans?
Thu Nov 07, 2002 12:44 am
I very much doubt the flying time of only 6 hours, as the distance is 5630 mi on great circle. This is roughly the distance of MIA-SVO.
So no way this can be done on a regular subsonic passenger jet in 6 hours.
CO 757-300
Thu Nov 07, 2002 2:04 am
what airline could we see doing this?
aa61hvy
Thu Nov 07, 2002 2:50 am
that would an interesting route. I wonder how many nigerians actually live in florida, or even the united states, i have a feeling this will be short lived. but it would be cool to see. and im questioning the 6 hours thing. it takes a little over 6 hours from jfk-lhr.
Go big or go home
flyguy1
Thu Nov 07, 2002 10:22 am
Nigeria Airways already flies from JFK to Lagos 2x per week. The flight is around 8 hours, so Miami would appear to be shorter. I don't know if it is only 6 hours though.
727, L1011, MD80, A300, 777-200, 737-300, 737-700, 747-400, 757-200, 737-800, A320. E190, E135, 767-200, CRJ9
BA
Thu Nov 07, 2002 10:31 am
There is no way Miami to Lagos will take 6 hours. That's just not possible on any modern airliner other than the Concorde. Even a Concorde will not be able to do Miami to Lagos as 5630 miles is above its range.
So no airliner can do the trip in 6 hours.
Lagos to Miami would encounter headwinds and would take even longer.
"Generosity is giving more than you can, and pride is taking less than you need." - Khalil Gibran
BA
Thu Nov 07, 2002 10:44 am
Flyguy1,
JFK to Lagos (LOS) is shorter than MIA to Lagos (LOS). It's only 5,250 miles while MIA-LOS is 5,630 miles.
Just for comparison, LAX-LHR is 5455 miles taking the Great Circle route. That's shorter than MIA-LOS, and LAX-LHR takes 10 to 11 hours depending on the winds and the exact route taken. Airlines often don't take the Great Circle routes since our skies are congested these days. So flights often are longer than what you would find out by using the Great Circle route.
Looking at a flat map to compare the distance will be decieving. You have to look at the globe, and use a string to measure the shortest distance which is the Great Circle route.
One would think JFK-LOS is longer than MIA-LOS, but it is not.
Looks can be decieving.
767er
Thu Nov 07, 2002 11:09 am
Why would anyone in their right mind want to go to Lagos. I hear it is a complete s**t hole.
Aircraft flown:F27,Viscount. EMB120, SAAB340, ATR70, 737-200.737-300,DC8, DC10,747-100,747-200,747-300,747-400, A320, A3
MAH4546
Thu Nov 07, 2002 11:41 am
The six hour time came from the South Florida Sun-Sentinel, so I guess they were wrong. None the less, MIA is pushing for Lagos flights. The United States has about 300,000 Nigerians, of which only about 12,000 live in Miami. Most live in New York City and the Northeast. However, Miami's African population is one of the largest in the United States, made up mainly of South Africans and Senagalis.
I am not sure if this is how the route would work, but looking at a map I would think an MIA-LOS service would be quickest if the flight went South, and then turned over Fortazela, Brazil over and then over the Atlantic.
Locally, MIA-LOS service would most benefit Miami's huge African business community. Miami's geographic location makes it a big centre for African business. I think MIA-DKR would work better, though. There is definitley a sizeable market for that.
a.
BA
Thu Nov 07, 2002 1:23 pm
The Great Circle route is always the shortest route possible.
Take a look:
JFK-LOS - 5250 mi
MIA-LOS - 5630 mi
Distance wise, the Great Circle route is shortest. It's not possible to have a shorter route than the Great Circle route.
Therefore, JFK-LOS is shorter than MIA-LOS by 380 miles if the Great Circle route is used.
Like I said earlier, looks can be decieving. Never judge a book by it's cover.
