United777
World's Longest Range Aircraft?
Tue Nov 12, 2002 10:54 am
Which aircraft is the world's longest range aircraft the Boeing 777-200LR or A340-500. Althought the 777-200LR will be in service way after the A340-500 does when the 777-200LR does enter service which aircraft will hold the titile for the "longest range aircraft"? Also could the 747-400ER fly the same routes as the A340-500 such as SIN-LAX, SIN-SFO or KUL-SEA?
lehpron
RE: World's Longest Range Aircraft?
Tue Nov 12, 2002 2:58 pm
in terms of commercial service, A345 it is now, then 773ER will take the crown.
In terms of longest range, in 1986 a plane called Voyager looped the planet, that's 21600 Nmi, long enough for ya?
flyf15
Tue Nov 12, 2002 3:02 pm
The longest ranged production aircraft in the world is the McDonnell Douglas KC-10A. This being due to the fact that the fuel tanks used primarily for refueling are tied into the aircraft's own fuel system, thus giving it an ENORMUS range if so needed.
ZK-NBT
Tue Nov 12, 2002 5:06 pm
773ER I don't think so, the 744 has a longer range than the 773ER!
The 772LR will have about the same range won't it as the A345 that is.
jhooper
RE: What To Do During A Long Flight?
Tue Nov 12, 2002 5:16 pm
So how far COULD the KC-10 fly fully load with fuel?
I would say an aircraft like the C-5 has the longest range (unlimited by aerial refueling)
Last year 1,944 New Yorkers saw something and said something.
Tue Nov 12, 2002 5:31 pm
In the air force I was flying E-4s... (747 command posts) - with air to air refueling, we could be deployed in the air - for max 72 hours - 3 days...
During Gulf war, I flew a flight from Offutt, Nebraska, to Middle East, stayed on station for 24 hours, and headed back, never landed, total time in the air was 55 hours... we got refueled air-to-air 5 times from KC-10s...
(s) Skipper
sccutler
E-4 On Station- Time?
Tue Nov 12, 2002 6:30 pm
Skip-
When you conducted the E-4 mission referenced above, how many crews were on board in rotation for each duty station? That sounds like some long march, indeed!
The mention of the Gulf War brings back memories of the massive numbers of GIs transported by US-flagged carriers. Didn't Pan Am remove its livery from some such 747s to reduce blatant exposure to sabotage?
...three miles from BRONS, clear for the ILS one five approach...
JAL
Tue Nov 12, 2002 11:00 pm
I think it is the A340-500.
Work Hard But Play Harder
solnabo
Wed Nov 13, 2002 12:00 am
A 342 / the v.i.p´s own a/c made
64.000 miles......talk about record
Almost empty and LOTS of xtra fuel-
tanks Smile/happy/getting dizzy
Michael Sthlm /SE
Airbus SAS - Love them both
artsyman
Wed Nov 13, 2002 12:20 am
according to www.boeing.com, it is the 777-200LR
Approximately 35 percent of the longer-range 777's design will be changed from earlier 777 models, although passengers won't notice it.
Provisions for up to three optional fuel tanks also are being added in the aft cargo compartment for the 777-200LR to allow for its 8,820 nautical miles (16,316 km) -- making it the longest range commercial airplane.
Improved Economics
The Boeing 777 longer-range airplanes will have seat-mile costs that are 15 to 18 percent lower than the A340-500 and A340-600 models.
Fuel burn is considerably lower - 21 to 22 percent lower per seat for the longer-range 777s - when compared to the A340-500 and A340-600.
While BOTH manufacturers claim certain things, when Boeing suggests 22% increases, you can expect that even if they do not acheive this, they will not be wrong by 22%
mikkel777
Wed Nov 13, 2002 12:31 am
The 340-500 have a maximum range of 10 000NM, 8500NM with typical payload, and 6200NM with maximum payload.
The 777-200LR is predicted to have a maximum range of 8820NM with typical payload.
The 777-200LR is predicted to have a 15-18% less seat pr mile cost than the 340-500 and 600.
These numbers are not accurate before some flighttesting is done with the 777-200LR
jhooper
Wed Nov 13, 2002 1:07 am
Talk about a nice way to build PIC time!
Wed Nov 13, 2002 1:28 am
Dear Sccutler - regarding that long flight we had a triple crew since we did not know how long we would be in the air - was the days of the start of Desert Storm - I was in the Reserves and IP on the E-4 (Instructor Pilot then) and with PanAm at the same time - we had a waiver with PanAm on flight time duty time limitations to fly from the US to Saudi Arabia... was wild...
PanAm planes were flown with their colors - we refueled generally in Spain or Italy as the non-Nato nations (Switzerland-Austria) could not approve our overflights, our call signs were "Reach #" and routed from over Egypt into Saudi Arabia...
Looks like they will fly the same type of missions with all the CRAF in the next few weeks...
(s) Skipper
ConcordeBoy
Wed Nov 13, 2002 3:36 am
The longest ranged commercial aircraft currently in service is the A342; the longest ranged commercial aircraft currently flying is the A345; and the longest ranged commercial aircraft currently planned is the 772LR.
artsyman
Wed Nov 13, 2002 4:05 am
huh ? can it fly longer than the 772ER ?, If so, why do we not see the A342 flying the Polar route from NY>HKG ?
I am not 100% on this, but I think your facts are wrong
Jeremy
Hamlet69
Wed Nov 13, 2002 4:14 am
ConcordeBoy,
While you are technically correct, only 1 "A340-8000" (the higher MTOW of the -200) was built, and that was for a vip customer. The earlier -200s had lower ranges than even todays -300X. So from an airline perspective, the longest range commercial airliners are:
In Service
777-200ER: 7,730nm
Flying
A340-500: 8,650nm
Under Development
777-200LR: 8,865nm
Hamlet69
All gave some. Some gave all.
SAS_A330-300
Wed Nov 13, 2002 4:22 am
The Airbus A340-200 has a range of 14800 km/8000 nm with typical payload.
So, of course you can use the it on routes like JFK/EWR-HKG. Unfortunately, it isn't so profitable like its longer sisters (less cargo and pax).
Simon
You know the gear is up when it takes full power to taxi
United777
Wed Nov 13, 2002 11:14 am
Why does it seem like more airlines are ordering the A340-500 and not waiting for the 777-200LR? Do these airlines such as Emirates and Singapore Airlines which do plan to use the aircraft for ultra-long routes to US feel more better flying the routes with a 4-engine aircraft rather then a 2-engine aircraft even though the 777-200 has proved it could fly non-stop from KUL-SEA-KUL nonstop.
Wouldn't the 777-200LR fit good with airlines that already have a big 777 fleet such as SQ and EK and have the A340-500 just for long-haul routes?
Hamlet69
Sat Nov 16, 2002 11:53 am
United777,
I'm not sure when EK placed their A340-500 order, but SQ ordered the -500 before the technical specs on the -200LR were finalized, and before they made their switch to the -200ER. At the time SQ made their decision, the -200X was lighter, shorter-ranged and only had @ 105k lb. engines, which made performance sub-par. Please note also that SQ has only ordered 5 -500s, which are intended to 'test the waters' of the ultra-long range market. SQ has publically stated they intend to determine whether these routes can be operated profitablly before fully commiting to them.
Hamlet69
s.p.a.s.
Sat Nov 16, 2002 12:04 pm
Sorry..
What about the B747SP ? There are still some of those out there...
Rgds,
Renato
"ad astra per aspera"
