Greg
Landing Gear 777-300ER
Tue Nov 19, 2002 11:29 pm
I understand that in order to get 1.5 degree increase on rotation without a tailstrike, the 300ER will actually rotate on the last set of tires on each main bogie. Apparently a hydraulic brace has been engineered to allow the aircraft to rotate on it's 'heels'.
I'm sure I read this from a credible source, but I can't place it.
Is this correct?
Sinlock
RE: Landing Gear 777-300ER
Wed Nov 20, 2002 12:36 am
I remember reading this in AW&ST.
I'm not sure if Boeing actual did it. It should be easy to tell when we get better pictures.
Greg
Wed Nov 20, 2002 4:18 am
I'm pretty sure they had to.
I recall they mentioned they needed the extra degree to create the extra lift necessary to satisfy their takeoff length guarantees...
The gear looks the same to me...(not that I would know what to look for...)
The Vmu tests should be very interesting to see!
Greg
Wed Nov 20, 2002 5:29 am
Hey.
Appreciate it.
Ok...it doesn't look the same.
I guess that ends the speculation....
Brgds.
Hamlet69
Wed Nov 20, 2002 7:19 am
Greg,
You should trust in yourself more! That is actually a very good description of what was done. As the pictures show, the 777-300ER will actually physically lift its front two bogies off the ground during rotation, gaining a greater degree of lift on the wings and thereby cutting down field length.
Should be interesting to see in practice!
Hamlet69
All gave some. Some gave all.
apuneger
Wed Nov 20, 2002 8:13 am
Interesting topic. Maybe the following picture can help:
copyright...euh...that would be me! Big grin
Ivan
PS: yup, this one was rejected  Sad
Ivan Coninx - Brussels Aviation Photography
brons2
Wed Nov 20, 2002 9:59 am
Rejected? Oh man, that's a great pic! Thanks for sharing!
Firings, if well done, are good for employee morale.
danlauz
Wed Nov 20, 2002 10:29 am
could the front wheels go down instead. i am not specialist but to drop the front wheels would help the front of the aircrafy to raise ??
azeem
Wed Nov 20, 2002 5:54 pm
A bit 'off the track' question. Does the A340-600 rotates on same rules?
N79969
Fri Nov 22, 2002 4:28 am
apuneger
Fri Nov 22, 2002 8:44 am
Brons2: Thanks for the compliment  Wink/being sarcastic
DANLAUZ: Very good point. Makes sense to me.
Ivan
