Mr AirNZ
Second Emergency Exit
Fri Nov 29, 2002 5:41 am
In two of the photo's below, ZK-NBJ has only one emergency exit but in a more recent photo the aircraft has two. Was a second exit retrofitted? If so why?
Photo © Torsten Maiwald
Photo © Alastair T. Gardiner
Photo © Raymond Rowe
Crosswind
RE: Second Emergency Exit
Fri Nov 29, 2002 6:16 am
ZK-NBJ is one of several ex-Britannia B767-200s operated by Air New Zealand - as such it has always had 2 overwing exits on each side. It was orginally G-BLKW in Britannia service.
On the first photos they appear not to have been outline painted as they are not actually required in low-density configuration, but they are still visible...
Photo © Garry Lewis
CROSSWIND
Mr AirNZ
Fri Nov 29, 2002 7:13 am
*************Thanks!*************
Douglas DC-9
Fri Nov 29, 2002 12:58 pm
I think that it's not the same aircraft. They may have retired the one with 1 over-wing exit and replaced it with one that has 2 over-wing exits but the new aircraft was given the same tail number as the old 767 that was retired.
Thanks Much,
Daniel
BR715-A1-30
Fri Nov 29, 2002 1:57 pm
Daniel, For some reason, I believe that theory is wrong.
Mr. AirNZ, If you look closely at the first photo, you will see a space where the emergency exit is (and a small sticker above the window) Look at the outlined emergency exit, and tell me what you see above the window. Question is now answered.
ITS HIDING FROM YOU MAN!!!!!!  Big grin  Smile
-761
Puhdiddle
fanofjets
Sat Nov 30, 2002 12:56 am
Both 762s of Balkan had this arrangement
Photo © Robert Schönherr Jr.
F-GHGD
Photo © Lee Collins
F-GHGE
Both were originally delivered directly from the factory to Aeromaritime, migrating to AF after its merger with UTA
The Britannia aircraft with double overwing exits also appeared in the colors of TWA and Air Aruba and Aeromar during leases
Photo © Carlos Borda
The aeroplane has unveiled for us the true face of the earth. -Antoine de Saint-Exupery
