Paulianer
Video: 737 Landing W/O Left Landing Gear
Wed Jan 22, 2003 6:23 pm
Hello everyone,
I've just found an interesting video of a 737 landing without the left landing gear.
Anyone know where this video was taken and what flight this was?
737 Landing
Tobi
Tobias Rose - Hamburg (HAM/EDDH) & (XFW/EDHI) - Canon EOS D60 - ICQ: 235621277 - MSN: Tobias.Rose@gmx.de
lmml 14/32
RE: Video: 737 Landing W/O Left Landing Gear
Wed Jan 22, 2003 6:56 pm
This video was shown on DiscoveryEurope as part of a documentary on the perils of aviaiton. When the gears were lowered on approach both main gears did not extend. The pilot went around and flew by the tower who confirmed that only the nose gear is down. The pilot took the plane to FL100, dived to FL050 and pulled up sharply. This action helped to release the RHS gear. The maneouver was repeated but failed to release the LHS gear. The pilot then decided to bounce the aircraft on the runway (as shown on the video) on the extended gear in an attempt to release the LHS gear from the well. Two attempts failed and the emergency landing followed. On investigation it resulted that the wheels were jammed with a wheel chock which was left in the well by the marshaller.
An interesting observation is how the pilot actually slammed the aircraft on the ground as opposed to a smooth landing and letting the aircraft roll out slowly then gently list to the left on the engine. The pilot said that he decided to disable the antiskid system, land heavily and slam on the brakes so that the tyres would burn and the wheel would skid on the rim in an attempt to prevent a skid. It worked. But I talked to several pilots and asked them what they would do in such a scenario and invariably their answer was the opposite of what this pilot actually did.
The only injury sustained in this incident was that the pilot fractured his little finger while sliding down the rope from the cockpit window.
How would you, as a pilot, have reacted?
turbulence
Wed Jan 22, 2003 7:29 pm
Luckily nobody was hurted, what a bad luck for the pilot, after managin such a good landing, to hurt himself while evacuating he airplane...
Anyway, congratulations for the "ideas" to the captain and thanks to Paulianer for the video.
Best turbulences
AApilot2b
Wed Jan 22, 2003 9:21 pm
This was a US Air flight. I remember seeing this very clip in the news when it happened a few years a go. Unfortunately, I cannot remember the exact time when it occurred. I think the pilot did an excellent job! I'm sure the critics can point fingers and say what he could have done differently, but under tough circustances he landed the plane very well and no one was hurt. Correct me on this, but I beleive the airframe was repaired as well (not a loss).
OPNLguy
Wed Jan 22, 2003 9:44 pm
SWA had one of these incidents back in 1996 at ONT, and the crew in this one also did the opposite of what the Piedmont crew did, i.e. held the wing off as long as possible before it eventually allowed the engine to contact the runway about 65 knots. The gear failure wasn't caused by a mis-stored wheel chock, but by an internal failure within the gear strut which allowed it to hyper extend within the wheel well.
One thing that you will hopefully not see should a main gear problem (on any type of aircraft) recur is a single-gear and touch and go. In the classic example of Charlie Brown, doing one that results in a gear extension makes one the proverbial "hero" in avoiding a couple of million in damage to the aircraft. Doing one that has unexpected problems that make the situation much worse make one (and the passengers along for the ride) the proverbial "goat". Bottom line is that it's better to slide to a stop on the runway at 65 knots than it is to RISK running off or cartwheeling off the runway at 120-130 knots and killing folks in a fireball.
Should a future partial gear situation result in single-gear touch and go that goes badly with a major accident, you know how case is going to be litigated, i.e., "they didn't play it safe and unecessarily risked the lives of everyone aboard..."
RP
Wed Jan 22, 2003 9:47 pm
The aircraft was N413US, B737-401. This happened shortly after the Piedmont-USAir merger. Flight was DCA-CLT, flight diverted to GSO a Piedmont maintenance base. Aug 2, 1989 http://www.airdisaster.com/photos/n413us/photo.shtml
Photo © Torsten Maiwald
Photo © AirNikon
Photo © AirNikon
Photo © Frank Schaefer
OPNLguy
Wed Jan 22, 2003 10:05 pm
FYI, the video is also available at the link below (it's the last one listed), and you'll also note that only one of the two main gears did not extend, not both...
http://www.airdisaster.com/movies/
Rick767
Wed Jan 22, 2003 10:39 pm
For those who are interested, as far as the 757/767 goes in my airline at least the procedure is:
Landing - One Main Gear Down and Nose Gear Extended
Fly a normal approach and flare profile. The landing gear will absorb the initial shock and delay touchdown of the engine. At touchdown, raise the speedbrakes and use rudder and nose wheel steering for directional control. Braking and reverse thrust on the engine opposite the unsupported wing should be used as required to keep the aircraft rolling straight. Maintain the wings level as long as possible. Place the fuel control switch to cut-off prior to the engine contacting the ground. Pull the engine and APU fire handles and discharge fire bottles.
After stopping, initiate the passenger evacuation procedure.
Sounds simple huh? Wouldn't like to try it for real though...
GunFighter 6
Wed Jan 22, 2003 10:42 pm
The pilot did one hell of job  Smile
Really shows some skills..
G.
lmml 14/32
Wed Jan 22, 2003 10:55 pm
Interesting Rick767.
OPNLguy The video shows one gear extended. But the initial problem was that BOTH main gears were stuck in. My source is the Pilot himself describing the incident on the documentary.
I am not criticising his actions in any way. If the end justifies the means, then I would say the pilot did the right thing. But from my point of view, and I am not a pilot, I think what Rick767 says above is safer, more logical and much less stressful on a plane full of pax who had just had an aerobatic experience.
OPNLguy
Thu Jan 23, 2003 1:36 am
OK, I was not aware of that.
I think the procedure that Rick767 mentions (which is the same as ours) is sound, and should be the chosen course, rather than turn a B737 into an XB737 with passengers onboard. Aircraft with tricycle landing gear have been making occasional 2-out-of-3 gear landings for years, and they are emminently survivable. It makes zero sense (to me) to expose passengers to MORE risk from the "solution" than is present from the original problem.
Emergencies of the type that Al Haynes and crew found themselves in with UA232 are another matter, i.e., there's nothing in the book to cover those types of situation, and you have to resourceful out of necessity.
These gear situations don't require that type of resourcefulness to be successful (as in protecting the passengers versus minimizing damage to the aircraft), and as such, established procedures should be followed, i.e., no single-gear touch and go attempts to "shake things loose."
cdfmxtech
Thu Jan 23, 2003 3:16 am
Check the very end of that video as they are evacuating. Notice someone jumped out of the left side L1 door without a slide being there. Of course there would be no exacuation from that side since that was the danegr side. But he jumped out of the door.
Rick767
Thu Jan 23, 2003 9:26 am
"The pilot said that he decided to disable the antiskid system, land heavily and slam on the brakes so that the tyres would burn and the wheel would skid on the rim in an attempt to prevent a skid."
Whilst I am not questioning the decision made by the crew, I would think this invites a wheel well fire, which (whilst it didn't happen in this case) would simply present another emergency once the aircraft had stopped and evacuation was required.
It would be interesting to know if there was a "published procedure" available to those pilots for such an event at the time.
OPNLguy
Thu Jan 23, 2003 9:33 am
Concur, absolutely...
Can't say about the first one, but after the second one, everyone involved was debriefed with "lessons learned" disseminated to all...
flyingbronco05
Thu Jan 23, 2003 10:48 am
Could this video be any worse quality?
I mean god it's horrible.
Glad everyone was ok though.
Never Trust Your Fuel Gauge
AApilot2b
Thu Jan 23, 2003 5:00 pm
Yeh Flyingbronco05! I guess they should have called out a professional camera man. Maybe they could have got the pilot to fly around in circles while they got several professional photographers and what not situated around the airport so they could make these peoples nightmare more entertaining.  Wink/being sarcastic The crash viewed from many different angles, a few added explosions for special effects,.... Shoot! We could have had a scene straight from Hollywood here!
Just Kidding with you Pal. I'm a bit sarcastic today.  Big grin
lmml 14/32
Thu Jan 23, 2003 5:29 pm
The pilot admitted that it was his decision to do so. It seems that it was not in the books. I am sure he had good reason for doing that. But watching the whole landing sequence on TV the landing seemed very violent, especially the engine to ground contact.
PW100
Fri Jan 24, 2003 3:24 am
Looks like a sound procedure as described by Rick767. One observation though:
At touchdown, raise the speedbrakes and use rudder and nose wheel steering for directional control . . . Maintain the wings level as long as possible
Well it seems to me that there is no way to hold the wings level after deploying the speed brakes [=spoilers right?]. Correct me if I'm wrong, but I don't think the ailerons will have sufficient authority over the speed brakes to hold up the wing. This can be seen very clearly in the above link. Once the speed brakes are deployed...bang, down goes the wing and the nacelle slams the runway.
Rick767, did I understand this correctly: are you saying that once the engine has slammed the runway, directional control can be gained/maintained to a certain degree by regulating reverse thrust on the opposite engine? Or would you shut down both engines when the aircraft contacts the runway?
Thanks for clearing this up...
PW100
