mikeclod
Fedex And UPS Uld's
Thu Feb 13, 2003 5:36 pm
Hello, I'm just curious if they use the same "cans", or if they're different. I'm pretty sure the LD-3's are universal, but what about all of the others?
Thanks, Mikeclod.
gigneil
RE: Fedex And UPS Uld's
Thu Feb 13, 2003 5:41 pm
I bet UPS doesn't use LD3s and FedEx does.
LD3s are not the most efficient use of the 757Fs and 767Fs. There's some container (I asked about this in tech-ops) that fits perfectly single file in the 727F and 757F and then side by side in the 767F.
Since FedEx uses the wider A310F instead of the 757F and the A300F instead of the 767F, I bet they DO use LD3s.
I'm sure UPS pilot can correct me on all this.
N
teva
Thu Feb 13, 2003 9:03 pm
Today, UPS operates Airbus and MD11 too.
That's why they probably use LD3s now.
About the main deck, I visited the UPS Airbus during the last Paris air show at Le Bourget.
Ups uses different containers, but I do not remeber the name. They are not as high as the fedex AMJs, but they have a top that is cut on 3 sides, and are lower, to allow easy transfer to 757 and 767.
The position of the locks on the maindeck of the Airbus is completely different.
In fact, on the A300, Ups loads 1 extra can on the main deck, but their cans are smaller. In term of use of the volume of the plane, I think it is equivalent.
teva
Ecoute les orgues, Elles jouent pour toi...C'est le requiem pour un con
UPS Pilot
Fri Feb 14, 2003 9:36 am
Gigneil is right,
UPS uses:
L-11, M1-n (modified M-1), L-9n (modified L-9), A-2n (modified A-2) and of course the corresponding pallets.
The L-9n's are in the A300 belly a and b positions. The A300 main deck has the A2n.
The MD-11 also has the L-9n in the belly a position. Belly b holds the L-11. The main deck can accomodate the A-2n and the M-1N.
The 72 and 75 use the A2-n
fxra
Fri Feb 14, 2003 10:41 am
FedEx uses:
SAA/SAX: 88x125 in base with a contour (full width of B727 fuselage and countoured to match)
AYY/AYX: 88x62.5 in base, essentially half a SAA container
AMJ: 96x125 in base, 96" tall (i think, been a while) with one top corner contoured
AKE/AVE: stadard LD-3 belley containers
AWX: specialty haz at container to fit in the first position of B727, roughly half the footprint of a SAA
Along with standard "cookie sheet" pallets at 96x125" and 88x125" bases and the occasional 20-foot pallet.
As far which aircraft uses what, B727 uses only SAA/AYY containers (the last letter X symbolizes a specialty hazmat container)
A300/A310 can use all cans (except AWX), and numbers vary by load configuration. DC-10/MD-11 is the same.
later
Visualize Whirled Peas
mikeclod
Fri Feb 14, 2003 7:37 pm
Thanks all, but does anyone have any pics of UPS's cans? Are they the same as FEDEX's AYY, SAA, AMJ, but just different designations? BTW Gigneil LD-3's are belly cans. I can't imagine anyone putting them on the topside of any jet. FXRA What's your SQI? LOL
Mikeclod
fxra
Fri Feb 14, 2003 10:27 pm
MIkeclod, for some reason I feel i should know what an SQI is, i don't. Then again, I'm no longer a FDX employee (ahhh greener pastuers).
NO, UPS uses different cans, having seen them sitting next door. Not just different names. SOme are not extremely different, but you can tell.
ANd I'm not gonna tell you how, but I've put LD-3's topside. I also probably did a few lets say non standard ULD loads.
l8r
doug_or
Fri Feb 14, 2003 11:44 pm
its been awhile, buti used to load UPS planes. Is the LD-3 the short A2? if so that is the last position on a dc-8, rotated 90 degrees, so that it fits into the tail section topside. At out station we used A2s, M1s, pallets, and the short containers (LD-3s?) to load everything (we had 727-100, dc-8, 767, 757, 747, A300, MD-11). thats all of them, right?
When in doubt, one B pump off
jjbiv
Sat Feb 15, 2003 2:47 am
SQI=Service Quality Index
FedEx Express' internal operating performance metric.
joe
