b727
Airtran Flight Info
Fri Feb 14, 2003 10:10 am
Could anyone help with the information on following Airtran flights:
4/13/02 Flight 77 ROC-ATL
Flight 127 ATL-TPA
4/19/03 Flight 2138 TPA-ATL (Air Wisconsin Flight)
Flight 582 ATL-ROC.
I believe the types will be 717 except for the 2138 flight.
How is Airtran service?
Does anyone know if the N number is posted ro scheduled this far in advance?
Airtran stated that we could not select a seat untill at the airport. Is this a first come first serve operation? If I get there earlier caould I get better seats??
This is our first time flying Airtran, any commets are appreciated.
B727
Glenn
mrlineguy
RE: Airtran Flight Info
Fri Feb 14, 2003 2:33 pm
Glenn,
I do believe that all of your flights except flight 2138 will be aboard the Boeing 717. Flight 2138 (Operated by Air Wisconsin) will be operated with a CRJ-200. You can check-in for your flight and receive a Boarding Pass with seat assignment up to 24 hours in advance at www.airtran.com. If you choose to check-in at the airport, the earlier you arrive, the better chance of you getting the seat of your choice, as all seats are assigned at the time of check-in. All 717 and DC9 aircraft have 4 abreast seating in Business Class and 5 abreast seating in Economy. Don't forget it only costs $35 to upgrade to Business Class per segment based on availability! Hope you enjoy your flight!
Kevin
AirTran CSA/RAMP - MDW
[Edited 2003-02-14 06:34:30]
More right rudder...
b727
Sat Feb 15, 2003 1:36 am
Kevin,
Thanks for the info, I will be sure to check in early for the flights.
I hope to get a seat on the right side of the aircraft. We are traveling with an infant, and if the seat is not occupied I am sure Airtran would not mind if we used that seat.
Once again Thanks
B727
Glenb
fsuwxman
Sat Feb 15, 2003 3:02 am
You have a 30 minute stop on flight 2138 in the bustling metropolis of TLH.  Yawn Don't get lost in the terminal, if you get off the plane... (just kidding) Bring something to do, cause there won't be any other aircraft around to look at. Maybe a stray CRJ from DL or NW if they are running late.
ASOS... Another Shi#y Observation Station
b727
Sat Feb 15, 2003 4:07 am
I take it that TLH is a small airport. I would guess smaller than our airport here at SYR.
B727
Glenn
