ConcordeBoy
Handling With Only 1 Winglet In-flight?
Tue Feb 25, 2003 1:18 am
Take a look at this pic:
Photo © Yo Tanaka
For the pilots out there-- wouldnt this affect the aircraft's handling quite significantly?
dc-10 levo
RE: Handling With Only 1 Winglet In-flight?
Tue Feb 25, 2003 1:47 am
I'm no pilot, but I think this was discussed just a couple of weeks ago either in this forum or the Tech/ops. Do a search. (I remember reading that it wouldn't affect the plane at all.)
DC-10
jhooper
Tue Feb 25, 2003 3:54 am
This is just a guess here, but I would think that this would cause a SLIGHT roll and/or yaw to the right, since winglets reduce induced drag and improve lift; probably not enough to be noticible. At any rate, it appears to me this crew performed a poor preflight and could probably get into trouble. (or does the 747 MEL allow for this?)
Last year 1,944 New Yorkers saw something and said something.
jcs17
Tue Feb 25, 2003 3:59 am
I'm sure that the crew didnt "miss" it on pre-flight. The effects would probably be so negligible that safe flight could be carried out. I mean, how could you miss a missing winglet?
America's chickens are coming home to rooooost!
N79969
Tue Feb 25, 2003 4:04 am
Actually there are several photos of 744s with missing winglets on this website. I think there may even be a A330 with a missing winglet. I am all but certain that a winglet can MEL'd. I think the last thread on this topic stated there is a slight yaw moment if the winglet is gone but it does not significantly alter the flying characteristics of the aircraft. If that thread was accurate, it seems like a little rudder trim will take care of the yaw moment.
flysab
Tue Feb 25, 2003 5:45 am
Well I flew a 330 with one winglet missing 2 months ago, and there is absolutely no difference. Of course on the 330 the fly by wire and the flight control computers take care of everything, so it's normal not to feel any difference. For the 747 or other non fly by wire aircraft, i just can guess that there must be something to be felt, but it must be easy to eliminate by trimming.
HlywdCatft
Tue Feb 25, 2003 7:11 am
I remember being at DTW a couple years ago and seeing one of the NW 744s with a missing winglet facing me and wondering when did NW get 743s? The plane took off so obviously it was not important enough to pull from service and put in maintenance.
