FATFlyer
Alaska Replacing Horizon On Some BOI-SEA Flights
Sat Mar 08, 2003 10:59 am
Alaska will place 2 MD-80 aircraft on BOI-SEA starting June 8. The change will replace 3 Horizon flights, leaving Horizon with 5 RTs on the route.
No word on which flights will be switched so I have no idea what type of aircraft Horizon is taking off the route, CRJs or Q400s. I wonder what plans Horizon has for the aircraft freed up.
http://biz.yahoo.com/bw/030307/75416_1.html
"Travel is fatal to prejudice, bigotry, and narrow-mindedness." - Mark Twain
doug_or
RE: Alaska Replacing Horizon On Some BOI-SEA Flights
Sat Mar 08, 2003 11:10 am
With what basicaly amounts to a QX hub at BOI, I've been wondering if/when they'd do this. I wonder if this works out if they'll add AS BOI-PDX flights.
When in doubt, one B pump off
BA
Sat Mar 08, 2003 11:23 am
I'm still wondering what exactly is the point of the BOI hub?
Is it mostly an O&D type hub or was it designed as an alternative to SEA and PDX?
I'm still puzzled....
"Generosity is giving more than you can, and pride is taking less than you need." - Khalil Gibran
United777
Sat Mar 08, 2003 11:25 am
I flew this same route in Jan. with a QX CRJ-700. It was a very good flight and a very good aircraft. I am suprised AS is going to fly MD-80's on the route. Does AS fly to Boise from any other cities. When I was in BOI all I saw was QX aircraft.
doug_or
Sat Mar 08, 2003 11:49 am
http://www.alaskaair.com/images/asqxroutemap.pdf
route map for those interested
tzsfo
Sat Mar 08, 2003 2:13 pm
I was looking through SABRE today and apparently AS hasn't updated the flight in SABRE yet....Which is uncommon for them (they are usually on top of that)....Perhaps EA CO AS can shed some light on this????
TZ
It takes nerves of steel to stay neurotic. — Herb Kelleher
Big777jet
Sat Mar 08, 2003 3:40 pm
I don't see any of MD-80 on June 16th between Seattle and Boise. Where did you find out detail about this service?
Here it is:
check website at: http://www.alaskaair.com/shopping/schedule/schedDisplay.dll?DisplaySchedule
You type date and select city then you will see list of the flights.
Big777jet
atcboy73
Sat Mar 08, 2003 11:28 pm
So does Alaska and its partner run banks out of BOI?
I dont really know very much about thier BOI operation, just PDX and SEA.
It seems like a small town to run a "HUB" out of, though I hear its a beautiful place.
FATFlyer
Sun Mar 09, 2003 12:49 am
According to the press release:
"Flight schedules for the new service will be available March 16. "
EA CO AS
Sun Mar 09, 2003 4:03 am
I'm guessing it's based on the timing of the press release. It was released internally around 3:30pm on Friday, and the guys in scheduling have had so much on their plate lately (new Orlando service, a 2nd Newark flight, LAX-RNO, ANC-YVR) that they probably simply overlooked sending the schedule change through.
Odds are it'll be updated no later than Monday. AS usually doesn't like to publish a schedule in Sabre prior to a press release being sent, though. It's done that way to avoid telegraphing their intentions any earlier than absolutely necessary, although the Orlando announcement was such a non-surprise that the schedule had been published in Sabre about 8 hours prior to the official press release being sent.
737-990
Sun Mar 09, 2003 1:17 pm
Just read the employee newspaper (the March 7th Alaska's World) where it talks about all the new flights and schedule changes and looks like something slipped in which hasn't yet been announced or put in Sabre. Looks like Alaska will take over Horizons PDX-DEN flights starting June 8th. This means that Horizon will no longer be in Denver. It did say that QX might return in the fall so it might just be a seasonal adjustment. No info on type of equipment Alaska might use on the route.
Happiest is a man who has his vocation as a hobby
BA
Mon Mar 10, 2003 8:52 am
I'm assuming 73Gs or 734s. Although an MD-80 would indeed be a pleasant surprise.
Alaska right now has 3 daily flights from SEA on 734s. A 4th flight is being added next month that will operate on a 734 for a month then switch to a 73G.
United777
Mon Mar 10, 2003 8:56 am
I wonder what they will do with the CRJ's they used for the PDX-DEN route. Will they be put on new routes?
