lacke
What Is Happening On This Picture?
Tue Mar 11, 2003 3:10 pm
Please someone tell me what is going on here
Photo © Keith Blincow
thanks
kevi747
RE: What Is Happening On This Picture?
Tue Mar 11, 2003 3:13 pm
That engine is spitting out water. Just kidding. I've seen that from inside the cabin before. I don't know what that is. I always thought it was the engime sucking water off the runway/taxiway.
"Reality has a well-known liberal bias." --Stephen Colbert
res
Tue Mar 11, 2003 3:17 pm
Its most likely converging air - the air being sucked into the fan, then the air being blasted toward the engine inlet.
FLY NAVY
AWspicious
Tue Mar 11, 2003 3:20 pm
Nothing serious - Just an airplane relieving it's self after a night of heavy beer drinking.... At Hooters  Laugh out loud
aw
Nevermind political correctness - Envision using your turn signals!
CCA
Tue Mar 11, 2003 3:49 pm
Usually at low speed with high thrust and the right atmospheric conditions low pressure vortices form due to condensation, this one looks more like it's passed over a puddle of water which helps the process but gives a similar, but much more spectacular effect.
This is another way for the same sort of thing.
Photo © David Morrell
I managed to find another one as you can see no forward speed which would require less thrust for the same effect.
P1 in A330, A340, A346, B742, B744, B748.
AApilot2b
Tue Mar 11, 2003 6:08 pm
The answer by CCA says it all. I have seen this a lot with F-16s. They create a mini tornado in front of the aircraft (even at idle) it is most noticeable if their is moisture in the air. It is pretty cool to watch.
VonRichtofen
Tue Mar 11, 2003 6:17 pm
Indeed it is a vorticy created by the engine ingestion and a wet taxi area. As said by CCA this one was probably from a large puddle.
When I worked on the ramp at YYC I saw this all the time when final marshalling a departing aircraft on a wet ramp.
Kris
YYC
A330DAT
Tue Mar 11, 2003 11:16 pm
Just like AApilot2b said. It's a mini tornado being formed with air being sucked into the engine.
Below here are pictures of 737's equipped with "pins" in front of their engines, which are there to avoid injestion (sucking up) of debris. Not all aircraft are equipped with this, of course. In this case they are used in rugged terrain of the high north where the risk of engine damage is greater. Also notice what looks like a ski on the forward landing gear. This also prevents debris (rocks, pebbles...) from damaging the aircraft.
Photo © Rob Rindt
Photo © Den Pascoe
Photo © Den Pascoe
Photo © Kevin Wachter
 Smokin cool
backfire
Tue Mar 11, 2003 11:22 pm
Is the C-17 in the photo engaging reverse thrust?
There's often a flexibility demo at air shows in which the aircraft backs up on the taxiway. If this is the case, does that explain the airflow which has created the vortex?
aamd11
Wed Mar 12, 2003 12:41 am
Here's a few photos i found with similar 'vortexs'
Photo © Pedro
Photo © Pedro
Showing an RB211-524 at 80% N1 (left) and 100% N1 (right).
Pretty cool view  Smokin cool
A^A MD-11
