Gnomon
A321-100 Vs. -200
Thu Apr 10, 2003 2:51 pm
Are there any external differences between the A321-100 and the -200? Is the -200 longer or shorter?
Jean Leloup
RE: A321-100 Vs. -200
Thu Apr 10, 2003 2:54 pm
I don't think there are any external differences like that. If the 200 were longer, it probably would have been called the A322; if it were shorter, it would probably be called the A320 (Hey, wait...). If I recall correctly (but I'm too lazy to check at the moment), the only major difference is the increased range, and the extra fuel capacity (and consequent weight inrease) that goes along with it. Are the engines more powerful?
Next flight.... who knows.
mightyfalcon
Thu Apr 10, 2003 4:02 pm
The A321-200 is an extended range version of the -100: It features higher thrust versions of the -100 engines and an additional centre fuel tank (ACT - Capacity: 2,900 litres) increasing the range by 350 Nm.
A321-100 - MTOW: 83,000 kg (or 85,000 kg optional)
A321-200 - MTOW: 89,000 kg
As for capacity, the -100 and -200 are 100% identical and accomodate 185 passengers in a typical 2-class layout or 200 in an all-economy configuration.
MightyFalcon
The sky has no limit...
