DIA
What Is Going On With This MD-11's Wing?
Sat Apr 12, 2003 8:07 am
What Is Going On With This MD-11's Wing? (The slats underneath) And why are they different than all others I've seen?
Photo © Chris Coduto
I've always seen it like this:
Photo © Yevgeny Pashnin
Thanks ahead of time,
DIA
P.S. If the answers are obvious, then I apologize, I've had a long week and am not thinking very clear at this point.
Ding! You are now free to keep supporting Frontier.
777236ER
RE: What Is Going On With This MD-11's Wing?
Sat Apr 12, 2003 8:23 am
Part of the PIP for Delta's M11s involved redesigned flap fairings.
DIA
The MD-11, like the DC-10, does not have slats that stick out past the trailing edge of the main wings. The DC-10 never did, and I thought the MD-11 is in the same boat. Compare it to any other pic of the trailing edge of any MD-11. Post the pic if you find one that matches the Delta pic.
DIA
Sat Apr 12, 2003 8:25 am
Of course. Just after I post again. . .my answer. Thanks 777236ER. I thought I was going nuts!
Was Delta the only airline to do this?
DIA
trnswrld
Sat Apr 12, 2003 8:27 am
I clearly see what your saying, and until you made this post I had no idea of this design. Thats very interesting, I to am curious what this different design is all about.
777236ER
Sat Apr 12, 2003 8:29 am
I think so. After AA cursed the M11 and bitched about it openly, McDD did lots to boost the range (mainly) of the thing. I think Delta were the only ones to recieve the full all singing and dancing package.
Sat Apr 12, 2003 8:37 am
The first one (DL) has the revised flaps fairings which extend quite a bit over the trailing edge unlike the more ´classic ´ layout on earlier prod.- MD-11´s .
As the armchair specialist that I am I can only tell you that I remind MDD and Swissair and other carriers as well together having developed these ´canoe fairings´as part of a whole package of aerodynamics enhancement back in the nineties to eventually overcome the initial shortcomings of the performances the MD-11 suffered from when it was introduced into airline service.
bunga777
Sat Apr 12, 2003 9:02 am
What kind of aerodynamic enhancements do the new fairings provide?
Sat Apr 12, 2003 9:11 am
The new fairings are mainly reducing drag (hence saving fuel ,don´t have the exact figures however ).They have been developed for the PW-powered MD-11´s since the PW ´s were consuming more fuel than predicted .
FDXmech
Sat Apr 12, 2003 12:21 pm
We have a few like this, or at least a couple. Here's one.
Photo © Chris Sheldon
A330DAT
Sat Apr 12, 2003 5:00 pm
Later MD-11 aircraft were fitted with these new flap-fairings. It's not from one particular airline but rather an aerodynamic design improvement applied by McDonnell Douglas.
Photo © AirNikon
Photo © Paul Jongeneelen
je89_w
Crew
Sat Apr 12, 2003 7:33 pm
A Japan Airlines MD-11 (JA8589––the Rock Ptarmigan) has extended fairings.
http://www.pbase.com/image/15365612
Photo © Andrew Hunt
I remember making a post on this topic quite a while ago too.
http://www.airliners.net/discussions/general_aviation/read.main/900728/6/
Jerrold
