*HighFlyah*
Is The 757-200 Heavy Or Not?
Wed Apr 23, 2003 4:00 am
As far as I know, Heavy = MTOW >= 255,000 lbs.
I have not heard on ATC the 757-200 of UA, US, DL, AA and NW being called "Heavy" though ATA's 757-200 is "Heavy."
I was told before that ATA is "heavy" because of the single class configuration, causing the MTOW to go over 255,000 lbs. All the other major carriers have 2 class configurations and fewer overall passenger loads.
Am I right? I keep hearing that because of wake turbulence issues, 757s are now considered HEAVY too regardless of MTOW. What's the truth?
sxmarbury33
RE: Is The 757-200 Heavy Or Not?
Wed Apr 23, 2003 4:02 am
Its mainly for wake turbulance seperations. The 757 is not classified as a heavy by weight. It is classified heavy because the aerodynamic high lift wings produce much more wake turb than most non-heavy aircraft. this has led to a few planes being flipped as a result of following a 75 to close.
N766UA
Wed Apr 23, 2003 4:05 am
How many billions of times are we gunna go over this? lol. jeeeez.
Only AmTran's 757-200s get called heavy, but all qualify because of the vorticies they produce. They aren't REALLY heavy though, except TZ.
This Website Censors Me
CactusA319
Wed Apr 23, 2003 4:06 am
The 757 is considered a heavy by ATC in terms of separation, i.e. controllers will space an aircraft behind a 757 the same distance as if it were a 747, 767, 777, etc. However, an aircraft only has to use the word "Heavy" in its callsign when MTOW is over 255,000. Most US airlines operating 757's have MTOW's just under 255K, so they won't use the designation. An airline like ATA, which packs 216 pax into their 752's routinely have flights that have an MTOW of 255 or above.
m717
Wed Apr 23, 2003 4:08 am
The 757-200 is treated the same as a "heavy" by ATC for wake turbulence separation purposes.
Wed Apr 23, 2003 7:00 pm
Besides ATA, Mexicana's 757's are "Heavies" as well.
United_fan
Wed Apr 23, 2003 9:10 pm
All 757-300's are heavies...........
Champagne For My Real Friends,and Real Pain For My Sham Friends
PER744
Wed Apr 23, 2003 9:21 pm
It's just big boned! :-P
POSITIVE RATE
Wed Apr 23, 2003 10:07 pm
It's due to wake turbulence. The 757 produces really viscous vortices which have led to some crashes in the past when aircraft follow too close behind.
ual777contrail
Thu Apr 24, 2003 3:29 am
They are not, IMO
ual 777 contrail
fritzi
Thu Apr 24, 2003 3:38 am
Ual777contrail,
Tell that to the Cessna 172 student pilot taking off behind a 757 at MTOW.  Laugh out loud
ual777contrail
Thu Apr 24, 2003 8:32 am
fritzi,
you got a good point, look out!!!
ual 777 contrail
POSITIVE RATE
Thu Apr 24, 2003 12:49 pm
"Tell that to the Cessna 172 student pilot taking off behind a 757 at MTOW"
Better make that tell that to any pilots flying anything in the "light" to medium category, including light jets such as the Learjet/Citation which can just as easily be flipped upside down by a 757's wake as a 172 can.
