JonnyGT
Connection Question At EWR
Thu Apr 24, 2003 8:58 am
My family is going home to visit relatives in Ireland this June. We are flying from Des Moines to Shannon, stopping in Newark on Continental.
Our flights are as follows:
CO2845 (ExpressJet)
LV: DES MOINES 400P
AR: NEWARK 725P
CO24
LV: NEWARK 830P
AR SHANNON 745A
We are a bit concerned about the hour connection in Newark. We know you would not be able to make a connection like this at JFK, but I was at Newark briefly once in November and I found it no so hard to get around in. Do you think we will have ample time to make our connection?
artsyman
RE: Connection Question At EWR
Thu Apr 24, 2003 9:31 am
Its pretty tight, but I would imagine that you will be fine. Try to make sure to check your luggage all the way through, this will speed the process.
STT757
Thu Apr 24, 2003 9:53 am
For the Des Moines-Ireland segment you should be fine (same terminal connection), however the return portion might be iffy since some CO International flights arrive at Terminal B and some at Terminal C.
I'll check on that..
STT757
Thu Apr 24, 2003 9:57 am
I just checked and you should be good on the return (Ireland-Des Moines) segment as well since the Ireland flights arrive at Terminal C, that's CO's main terminal.
The only CO International flights still arriving at Terminal B are..
London/ Gatwick, England - CO29 only
Madrid, Spain
Manchester, England
Rome, Italy
JonnyGT
Thu Apr 24, 2003 10:18 am
Well, interesting thing, we are finishing up our visit by coming home from Gatwick on CO 19.
The flight is:
LV: GATWICK 1030A
AR: NEWARK 125P
LV: NEWARK 310P
AR: DES MOINES 502P
Will this be too close? When you switch terminals do you have to go through security again?
ContinentalEWR
Thu Apr 24, 2003 10:19 am
It is pretty tight, but you should be fine. The Continental Express flight from Des Moines will arrive at Terminal C and the Shannon flight will depart from C as well. Terminal C is quite large, it has three concourses, C1, C2, and C3 but a lot of long haul flights to Europe depart now from C3 and a number of CoEx flights also use C3, the newest part of the terminal.
If you miss the connection to Shannon, Continental should be able to help you with several options, including a 9:25pm code share flight on Virgin Atlantic to London/Heathrow where you can then backtrack to Shannon on Aer Lingus or Virgin Express. There is also a later evening departure to Glasgow, Scotland and there are connection opportunities I am sure from GLA to SNN. If you are really worried, you might want to write down the alternatives just in case.
Have a good trip and enjoy!
ContinentalEWR
ContinentalEWR
Thu Apr 24, 2003 10:24 am
The return should be fine. I believe the Gatwick flight 19 arrives at C. The airport signage at EWR indicates that only CO 29 uses Terminal B, which is the earlier departure from LGW. Your flight from EWR to Des Moines will depart from C so you will be fine.
ContinentalEWR
tailfin
Tue Apr 29, 2003 2:16 am
I was travelling ABQ-IAH-EWR-Ireland last summer.
I flew first from Shannon to the States, my return flight had to be to Dublin as it left later from EWR than the flight to SNN. To get the flight home to SNN the connection at IAH to EWR was 45mins which the agent wouldn't book for me as she said CO were under no obligation to put me on a later flight in case my arrival from ABQ was delayed. It turned out I made it in plenty of time at IAH to make that short connection to EWR, but had to wait for about 2 1/2 hours for a later flight to EWR. When I arrived at Newark on that later flight the Shannon flight still had not left but had to go on the flight to DUB and drive down through Ireland the day after.
It'll be no problem I hope for you.
That day our flight to Dublin was delayed from EWR about 45 minutes, but still arrived early as frequently happens with eastbound TA flights
