Mr Spaceman
Who Uses The Callsign "Night Flight" At YYZ?
Sat May 10, 2003 6:19 am
Hello there.
I'm hopeing that someone can tell me what aircraft company's pilots use the callsign "Night Flight" when checking in with Toronto Intl's ATC (YYZ).
The link to the list of callsigns you guys provided me with several months ago doesn't have it, and I couldn't find anything when I did a search either.
I suspect these pilots are flying for a cargo carrier because I only hear them very early in the morning or very late at night (if that makes any sense Big grin).
They will check in with Toronto arrival as Night Flight 101 for example.
Any info about who the carrier is and the type of aircraft they are flying would be greatly appreciated.
Thank You,
Chris  Smile
Unique
RE: Who Uses The Callsign "Night Flight" At YYZ?
Sat May 10, 2003 6:23 am
It's probably "Knight Flight", used by Knighthawk Air Express Ltd.
JetCaptain
Sat May 10, 2003 6:30 am
Knighthawk is correct. Probably a Beech 1900 inbound from YOW ?
http://www.airlinecodes.co.uk/airlcodesearch.asp
http://www.knighthawk.ca/Home/
JC
Mr Spaceman
Sat May 10, 2003 7:09 am
Hi guys.
Thank You, very much for your information.
You guys were correct. The callsign is actually "Knight Flight" instead of "Night Flight". How could I possible tell the difference between the two when listening to my receiver?
They fly a Beech 1900C Mon to Fri between Toronto and Pembroke, Ontario (a 1 hour flight) with 2 arrivals & 2 departures per day.
They also fly cargo using Falcon 20 bizjets.
Thanks again for your help.
Chris  Smile
Users browsing this forum: 727LOVER, airjamaica, ANA787, angelja, armcom, b777erj145, Baidu [Spider], bw50505, ClipperYankee, CONTACREW, drew777, eaa3, FAST Enterprise [Crawler], fkfnz, Google Adsense [Bot], jacobin777, jbpdx, jbs2886, Jerseyguy, jm079, justplanesmart, LAX772LR, n562wn, poolkeeper, SELMER40, SFOformerFA, shengzhurou, slookabill, TheF15Ace, Tom32286, TransWorldOne, Varsity1, Vctony, whatThe, xieym, Yahoo [Bot], YLWbased, zkncj and 9 guests
