TLHFLA
CO's CLE Hub
Wed Jun 25, 2003 11:25 am
Continental's Cleveland hub certainly has its share of regional jets and 737s. Has Continental ever flown any widebodies in/out of CLE? Right now the biggest plane they fly there is a 752.
Bill in ATL
RE: CO's CLE Hub
Wed Jun 25, 2003 11:29 am
They use to fly A300 to DEN...
N766UA
RE: CO's CLE Hub
Wed Jun 25, 2003 11:32 am
I used to see DC-10s on a regular basis. Most likely to Houston.
This Website Censors Me
TLHFLA
RE: CO's CLE Hub
Thu Jun 26, 2003 7:22 am
Were there ever any A300s to EWR?
Bill in ATL
luv2fly
RE: CO's CLE Hub
Thu Jun 26, 2003 7:27 am
Peter Max was here on a medical diversion! Tho no widebody action here, do miss seeing them.
sllevin
RE: CO's CLE Hub
Thu Jun 26, 2003 8:14 am
CLE-LGW is flown at least seasonally, if not year round, with a 762.
Steve
ConcordeBoy
RE: CO's CLE Hub
Thu Jun 26, 2003 8:18 am
Actually, it's a 752, not 762  Big grin
sllevin
RE: CO's CLE Hub
Thu Jun 26, 2003 8:59 am
Earlier in the year it was definitely a 762; I saw the widebody there at CLE myself. Looks like it's been taken down to a 752 in the current schedule. Hard to believe that there's no widebodies at CLE now...
Steve
luv2fly
RE: CO's CLE Hub
Thu Jun 26, 2003 9:16 am
I wish it was a 762 it has always been flown with the 757.
N766UA
RE: CO's CLE Hub
Thu Jun 26, 2003 9:39 am
Sllevin, sorry pal, but you're incorrect. CO has NEVER flown a 767 into Cleveland, especially on the CLE-LGW run.
CLEfan
RE: CO's CLE Hub
Thu Jun 26, 2003 10:37 am
If CO put the 762 on CLE-LGW, I'm sure that it could be flown year round and have stronger loads. Many people avoid this flight because it is on the narrowbody, including many Clevelanders.
artsyman
RE: CO's CLE Hub
Thu Jun 26, 2003 10:44 am
I would say that an extremely high % of passengers do not know and do not care what aircraft they are on.
luv2fly
RE: CO's CLE Hub
Thu Jun 26, 2003 10:55 am
For a long time I worked for a company that did charter flights out of CLE on ATA and they used a 757 and that fact had no effect on the loads.
ContinentalEWR
RE: CO's CLE Hub
Thu Jun 26, 2003 11:16 am
DC10's were an exception and not the rule at CLE. There were a few A300-RB flights operating into and out of CLE to IAH, DEN, and EWR in the early 1990's. 777's landing at CLE are usually diversions due to weather/traffic at EWR and the CLE-LGW route, which will be axed in October 2003 is flown with a 757. It was going to be operated with a DC10 when the route was first announced. The current runway configuration at CLE does not allow a fully loaded and fuelled heavy widebody from taking off to Europe.
I did see a CO 747 land at CLE in 1992 on weather diversion. It was operating FRA-EWR and overflew EWR.
ContinentalEWR
Alpha 1
RE: CO's CLE Hub
Thu Jun 26, 2003 11:21 am
Never had DC-10-30's on a "regular" basis. A few years back, before the DC-10's were retired, they were run once a week for about 2 months or so to ferry maintainence stores from Houston to Cleveland-including some engines-I think. but it was never a regular service. I did meet the -10 on the inbound on two occasions back then.
Yes, the Scarebus ran CLE-EWR for a while. I think it was twice a day to DEN, once a day to EWR.
I could be wrong, but I don't think a 762 ever flew the route even as an equipment substitution. We did have it run once CLE-IAH, I believe, and a few times CLE-EWR, but never CLE-LGW. I can tell you that, 'cause there's still not a CO gate agent in CLE that has worked more CLE-LGW flights than me (and I haven't worked one in 18 months).
N766UA
RE: CO's CLE Hub
Thu Jun 26, 2003 1:05 pm
Just a note, CLE-LGW will return in spring of 2004.
CLEfan
RE: CO's CLE Hub
Thu Jun 26, 2003 3:07 pm
Artsyman,
I should have clarified my statement better. Many frequent flyers, those who pay close attention to the aircraft, avoid this flight because it was not flown by a widebody. This comes into play in the winter, when business travelers, many who are picky about the services they want, outnumber the leisure travelers.
luv2fly
RE: CO's CLE Hub
Thu Jun 26, 2003 9:40 pm
Clefan, this flight either does not operate in the winter or it only runs on selected day of operation. Also FF will take the most direct flight to get them from point A to point B.
luv2fly
RE: CO's CLE Hub
Thu Jun 26, 2003 10:17 pm
Also on a similar note, RJ's are now flying up to three flights, so narrow bodies are becoming the norm and not the exception. What I am trying to say is that they are becoming more common, so a narrow body across the pond is not that bad, with the way the other majors are going you might see more start offering a 757. Also before the wide bodies you had the 707's DC8's and such flying the route.
dan2002
RE: CO's CLE Hub
Thu Jun 26, 2003 10:46 pm
Now as i type this 1 B1900D and a CO 73G just flew right over my house not even 20 seconds from eachother. But sadly CO has never flown widebodies into cle in the past ten years, and i presume its because of high landing fees.
A guy asks 'What's Punk?'. I kick over a trash can and its punk. He knocks over a trash can and its trendy.
artsyman
RE: CO's CLE Hub
Thu Jun 26, 2003 10:56 pm
This flight is active now, what were you refering to ?
luv2fly
RE: CO's CLE Hub
Thu Jun 26, 2003 11:01 pm
It operates seasonally! Apr/May through the Fall
N766UA
RE: CO's CLE Hub
Fri Jun 27, 2003 1:26 am
Alpha1: I was refering to a statement that flight 66 will be axed in the fall of this year.
