mirrodie
What Is/was The Largest Plane Ever?
Tue Jul 01, 2003 9:38 am
FOr years, I thought it weas the Spruce Goose. But I don;t know the specs on this.
Is the AN 225 now the worlds largest plane?
Forum moderator 2001-2010; He's a pedantic, pontificating, pretentious bastard, a belligerent old fart, a worthless st
flyf15
RE: What Is/was The Largest Plane Ever?
Tue Jul 01, 2003 9:42 am
It depends on how you determine "size" of an airplane. It is usually done by maximum takeoff weight. By this (and many other standards), the An-225 is indeed the largest airplane to ever exist.
bigphilnyc
Tue Jul 01, 2003 9:55 am
How is "largest" measured by weight? He asked what the largest was, not the heaviest.
I don't see how anythig could be bigger than the AN-225.
I once made a paper airplane that was pretty damn big. But the program did not last long, as on its maiden voyage, it stalled after 6 feet and fell to the carpet. All 6 on board received fatal paper cuts.
-Phil
Phil Derner Jr.
bobrayner
Tue Jul 01, 2003 10:25 am
The spruce goose had larger wingspan (320' vs 290') and larger wing area (11430 sq.' vs 10280 sq.'). In this respect you could say it's the largest.
However, it was slightly shorter (218' vs 275'), and much lighter (300000lbs vs 1332770lbs).
If in doubt, Google.  Big grin
Photo © Alastair Bor
Cunning linguist
flyf15
Tue Jul 01, 2003 10:42 am
The reason why I say weight is a good way to compare is with most other measurements, there are other things that can conflict.
Such as "This plane is the largest because it has the greatest wing span." "No, this is bigger because it is longer." "No, this one is larger because it has more power."
Its the best general measurement that can be used to easily compare the size of airplanes. If you know of something better, I'm sure we'd gladly consider it instead.
POSITIVE RATE
Tue Jul 01, 2003 10:55 am
And before the AN-225 came out i believe it was the AN-124 and before that the C5 Galaxy.
UALPHLCS
Tue Jul 01, 2003 11:13 am
Are there any AN225 flying around? Does Volga/Dniepr have one?
A little less Hooah, and a little more Dooah.
gigneil
Tue Jul 01, 2003 11:20 am
I want to say the only one or two flying actually are directly chartered out by Antonov... but I could be way off base.
If there were another operator, you could count on it being Volga/Dnepr.
N
Jean Leloup
Tue Jul 01, 2003 11:30 am
There's only one An-225, and I do believe it's Antonov that operates it.
I tend to agree that maximum takeoff weight is the best measure of 'size' for an aircraft. Otherwise, as pointed out, you have to pick which other dimension to choose. Length? Wingspan? Height?
I believe the Spruce Goose is only the biggest in terms of wingspan. Personally, I don't consider that to be nearly as 'important' an indicator of size as weight, or, even better in my opinion, payload/internal volume. An-225 measure on all such measures, as well as in thrust, I'd imagine. I think people only call the Spruce Goose the world's largest plane, basing the calculation on wingspan, because they want it to remain a tourist attraction. However, I guess at the time of its construction, it was probably also the heaviest/longest plane, etc. Not that it ever flew anywhere!
when the A380 arrives, I guess it's dimensions wil be very close to the An-225. Not much bigger, if at all.
Next flight.... who knows.
LY744
Tue Jul 01, 2003 8:44 pm
Yes, the one and only An-225 is operated by Antonov. It was in open storage for about a decade up until a year or two ago due to lack of funds. Another airframe has been standing incomplete at Antonov's prototype facility near Kiev for many years.
"And before the AN-225 came out i believe it was the AN-124 and before that the C5 Galaxy."
...and before that the An-22.  Smile
LY744.
