dfleet7
Boston's Logan Airport
Wed Jul 02, 2003 8:47 am
I will soon be flying into Logan on AirTran in order to make a connection to an Air France flight to Paris. I know that they are in different terminals, and sometimes you must take a shuttle bus to get from one terminal to another, so how do i get from the airtran terminal to the air france terminal?
thanks.
Drew
ren41
RE: Boston's Logan Airport
Wed Jul 02, 2003 9:22 am
You will arrive at Terminal D with AirTran and depart Terminal C, there is a walkway between the two terminals.
R41
dfleet7
Wed Jul 02, 2003 9:44 am
alright, thanks so much
Drew
LH423
Wed Jul 02, 2003 1:54 pm
Basically, you get off the plane, enter the bus terminal that is Terminal D, make a left towards the United and Delta baggage claims, up the escalator into Terminal C. Air France checks in with Delta along the back wall.
It's very simple, and the transfer will take you from the plane to the check-in queue in about 10 minutes.
LH423
« On ne voit bien qu'avec le cœur. L'essentiel est invisible pour les yeux » Antoine de Saint-Exupéry
Theiler
Thu Jul 03, 2003 5:57 am
You aren't kidding about the "bus terminal" part.. The ought to just expand terminal C or E, and swallow D.
deltairlines
Thu Jul 03, 2003 11:40 am
It's a very short and painless walk, taking the Shuttle Bus here is not even worth it. It should take about 5 minutes to get to the Air France desk from the plane max.
Jeff
