tallguy14
UAL: Seats To Avoid?
Wed Jul 23, 2003 7:48 am
I recently flew on a UA 757 ORDBOS, and I chose a seat in Economy Plus-- 13F. To my dismay, it was a row without a window! So I'm starting a list of "iffy" seats on all UA aircraft. Just so everyone can have a little information before seat selection!
Example: UA Boeing 757
9A,9B,9C (exit row with door slide, psgrs queueing for lavatory)
13A, 13F (no window)
etc.
Thanks for your help!
Jeff
RE: UAL: Seats To Avoid?
Wed Jul 23, 2003 7:51 am
I think you'll find most information you want on good and bad seats at:
http://www.seatguru.com
futureualpilot
Wed Jul 23, 2003 8:18 am
Hmm......Im booked on AWA on a 757, in seat 13A.....uh oh! I hope theres a window!
Life is better when you surf.
UA777lover
Wed Jul 23, 2003 9:03 am
Avoid 14A of 14H in business class on the 777. One window that you have to almost swivel your head around to see out of. One seat to DEFINATLY get if you can is 15A on a 747-400 (upstairs, business class). Loads of leg room as your behind the emergency exit.
L.1011
Wed Jul 23, 2003 11:06 am
12-14 (varies) are usually windowless on 757s so that u dont get killed by a fan blade if there is an uncontained engine failure.
ual777contrail
Wed Jul 23, 2003 12:44 pm
I don't like 8DE on the 757'S, but I disagree with you on 9ABC.
8DE is cramped and 8e really bites.
ual 777 contrail
Capt.Fantastic
Wed Jul 23, 2003 4:10 pm
L1011 said: "12-14 (varies) are usually windowless on 757s so that u don't get killed by a fan blade if there is an uncontained engine failure."
ummm, not true.
Actually, there is no window there because the conditioned air risers come up through that part of the fuselage ... same thing on 767s
UALPHLCS
Thu Jul 24, 2003 3:05 am
I have to disagree about UA's 9ABC on a 757. Those seats have move leg room than any other on any plane. I'm tall as well, I'll take others queing up to use the lav any day so long as my legs can strech to the max.
A little less Hooah, and a little more Dooah.
L.1011
Thu Jul 24, 2003 7:29 am
uh capt.fantastic,
Thats from seatguru and the site says its from a Boeing engineer so I think I know what Im talking about.
highliner2
Thu Jul 24, 2003 12:18 pm
Maybe so, but the a/c risers do go up thru the fuselage there so maybe it's a bit of both. The had to put them somewhere.
Go Cubs!
futureualpilot
Thu Jul 24, 2003 11:47 pm
L.1011, will having no window really stop a thrown blade, weighing over 2 tons when spinning at power....doubtful. I wish they would put a window there, it is very dissappointing to look forward to a flight, only to have no window.
L1011
Fri Jul 25, 2003 12:44 am
Where were the conditioned air risers located on the 737-200, the 727, and the 707? They didn't have any missing windows.
Bob Bradley
Richmond, VA
Fly Eastern's Golden Falcon DC-7B
Greg
Fri Jul 25, 2003 3:30 am
It's clear by any of those 'cutaway' renderings....it's air pac risers.
