derekf
SAA At LHR
Wed Aug 06, 2003 7:31 pm
A quick question. Why do South African use Terminal 1 at LHR and not Terminal 3?
Derek
Whatever.......
gkirk
RE: SAA At LHR
Wed Aug 06, 2003 8:11 pm
Connections with British Midland?
donder10
RE: SAA At LHR
Wed Aug 06, 2003 9:31 pm
I think it might be a throw back from the days of apartheid and the security for SAA.
CPH-R
RE: SAA At LHR
Wed Aug 06, 2003 9:44 pm
An attempt to make it easier for connecting flights, especially those of BA?
derekf
RE: SAA At LHR
Wed Aug 06, 2003 10:40 pm
I wonder if the security reason is the answer as El Al use terminal 1 as well I think.
Derek
Whatever.......
David_itl
RE: SAA At LHR
Thu Aug 07, 2003 9:17 pm
Not related to this thread but they are adding another 2 flights per week on the CPT-LHR route from this winter. Strangely enough, their press release announcing these additional flights says "SAA’s ability to increase flights between Britain and South Africa depended on the availability of early morning slots at Heathrow.".
David
carduelis
RE: SAA At LHR
Thu Aug 07, 2003 10:20 pm
BA intend to switch their South African and Tokyo flights to T1
Quote from BA's website:-
Another change for the winter 2003 season is that British Airways’ flights from London Heathrow to Johannesburg and Tokyo will operate from Heathrow’s Terminal 1 instead of Terminal 4 from October 26, 2003. Both these routes have a high number of transfer passengers, many of whom will no longer have to swap terminals at Heathrow for their connecting flights.
This is the first phase of British Airways’ flight switches between Heathrow terminals which will help make better use of the existing facilities prior to the opening of Terminal 5 in 2008.
To support these additional longhaul services, a major programme of infrastructure improvements is taking place at Terminal 1 including new lounges and check-in facilities.
Per Ardua ad Astra! ........ Honi Soit Qui Mal y Pense!
cedarjet
RE: SAA At LHR
Thu Aug 07, 2003 10:22 pm
Indeed, airlines from 'pariah' states such as SAA and El Al run from T1, to keep crews and passengers apart, in SAA's case from Kenya Airways, Nigeria Airways, Ghana Airways et al; and in El Al's case from MEA, Royal Jordanian, Iranair et al.
The usual long haul terminal is of course T3.
planenutz
RE: SAA At LHR
Fri Aug 08, 2003 1:50 am
What about Cyprus Airways (T1)? Is it because they needed to be separated from Turkish Airlines (T3)?
Unrelated, but why does BA operate MIA out of T3 instead of T4?
Not all who wander are lost....
LHR340
RE: SAA At LHR
Fri Aug 08, 2003 3:15 am
They don't all BA flights operate out of T1 & T4, probably a code share.
LHR340
A340 LoVeR! EC-GQK - LHR The Bussiest International Airport & 3rd Bussiest In The World!
DoorsToManual
RE: SAA At LHR
Fri Aug 08, 2003 3:19 am
Is South Africa still considered a 'pariah state'?
CPH-R
RE: SAA At LHR
Fri Aug 08, 2003 3:21 am
LHR340,
sorry mate, but BA has been operating their MIA flights out of T3 for a while now. I think it's in order to accommodate the connecting passengers, which there's apparently quite a lot of  Smile/happy/getting dizzy
LHR340
RE: SAA At LHR
Fri Aug 08, 2003 3:23 am
CPH-R,
Wow thanks, i've never seen them at T3 I always thought it was from T4, well thanks for that  Smile/happy/getting dizzy.
LHR340
CPH-R
RE: SAA At LHR
Fri Aug 08, 2003 3:27 am
No problem.
On a side note, I think BA also operated a few other flights from T3, that has since been moved to T4. But I can't remember which ones it were. Is there a more enlightened member who knows what routes it were?
United01
RE: SAA At LHR
Fri Aug 08, 2003 3:28 am
BA still operate both LHR-MIA flights from T3, until recently both PHL flights plus Lagos and I think Cape Town also were at T3. BTW I think I read somewhere that BA want to move a few more of their flights around, ie to T1 to improve connections until T5 is built.
David_itl
RE: SAA At LHR
Fri Aug 08, 2003 3:29 am
Think one was PHL.
David
ConcordeBoy
RE: SAA At LHR
Fri Aug 08, 2003 3:30 am
Nope. All BA-metal flights to MIA operate out of T3
Shamrock_747
RE: SAA At LHR
Fri Aug 08, 2003 3:32 am
What's planned to happen when T5 opens? Move all BA flights there?
Declan
DoorsToManual
RE: SAA At LHR
Fri Aug 08, 2003 3:38 am
Hi, I can confirm that BA's CPT flights did indeed use T3.
trintocan
RE: SAA At LHR
Fri Aug 08, 2003 9:44 am
BA's MIA flights use T3 in order to reduce the load on T4 and to ensure adequate executive facilities for the many upper-end pax who fly the route. The issue of connections has been considered and is the reason that flights to Johannesburg and Tokyo will move to T1 later this year (or early next year), with other flights to follow.
Indeed, SAA's use of T1 was for security reasons during the apartheid era. Though that is now over it may not be easily possible for it to move elsewhere - plus its many regular pax would be used to it being there. For similar security reasons, Cyprus and El Al use T1.
TrintoCan.
Hop to it, fly for life!
