Capt.Fantastic
Flaps On Prototype 707
Mon Aug 11, 2003 3:59 am
Hello:
In the recent photos of the Boeing 387, it appears that the trailing edge flaps are not the original type on the model. If I recall correctly (from old footage and photos from the 1950's), the trailing edge the 387's wing had a similar design to that of the production model 707. Was the wing reconfigured and if so, why?
Photo © Royal S King
timz
RE: Flaps On Prototype 707
Mon Aug 11, 2003 7:54 am
Didn't they use it to test 727 flaps?
dispatch
Mon Aug 11, 2003 7:56 am
Captain,
the type is actually 367
Peter
IMissPiedmont
Mon Aug 11, 2003 10:51 am
The 367-80 was indeed reconfigured with the later flaps as seen on 727s.
The day you stop learning is the day you should die.
justplanesmart
Tue Aug 12, 2003 7:05 pm
The 367-80 has been modified several times to test various things. It did have triple-slotted flaps like those on the 727 at one point. Later it had a cofiguration known as "blown flaps" for another test. It has also had different landing gear to test landing on unpaved strips, a fifth engine mounted on the aft fuselage (also a test for the 727), and its original JT3C engines replaced by the JT3D's seen in the picture. At one point Boeing referred to it as "the most modified aircraft."
"So many planes; so little time..."
