AMS
More Turbulence Over Mountains?
Mon Aug 18, 2003 8:58 pm
When flying over a mountain area, I noticed that many times there is more turbulence......especially over Austria, switzerland and also Japan
can high mountains create this turbulence?
Vimanav
RE: More Turbulence Over Mountains?
Mon Aug 18, 2003 9:41 pm
When the land is flat, the wind blowing over the land has no obstructions. However in a mountainous area, the wind strikes the sides of the mountain and tends to be highly disturbed causing updrafts and downdrafts. When the aircraft passes through these updrafts and downdrafts one experiences turbulence.
Hope this clarifies.
Rgds//Vimanav
Sarfaroshi kii tamannaa ab hamaare dil mein hai, Dekhnaa hai zor kitnaa baazu-e-qaatil mein hai
Kay
Mon Aug 18, 2003 9:53 pm
Wave turbulence is a kind of turbulence associated with mountains. The wind goes up and down in a "wave" for a while even though the mountain peak it bumped into is (reasonably) far behind.
In my humble experience in Cessna's, turbulence near mountains is unbearable. I don't remember once being close to the surface of a mountain and the plane not bouncing around like crazy. I once passed a mountain peak and the plane was literally falling even though at full power, because of downdraft. I know the terrain, there is more than enough space to "pull out", but still, it scares passengers.
Aaron747
Tue Aug 19, 2003 1:11 am
Mountains and turbulence are rule one of flight training AMS. Only if you get really lucky and have a calm day will you not experience some bumps when crossing terrain.
OPNLguy
Tue Aug 19, 2003 4:21 am
As the others have mentioned, absolutely yes....
Keeping in mind that air behaves as a fluid, it might help you to visualize (or look at outright) a small stream or brook in your area. After flowing over some rocks or other items raised above the stream bed, you can easily see various disturbances in the water down stream of where the rocks/items are. The air flowing over the mountains can create some similar effects on the lee side of(i.e., downstream from) the mountains.
marcos
Tue Aug 19, 2003 5:26 am
I remember quite vividly flying an AeroPeru DC-8 from Buenos Aires to Santiago over the Andes. Just about tossed my cookies. Most turbulence experienced by me in 30 years of being a passenger.
AMS
Tue Aug 19, 2003 5:42 am
I see! it seems mountain area's do have some turbulence!
MD80Nut
Tue Aug 19, 2003 6:10 am
I've flown over the Andes mountains on several ocassions and all flights experienced some degree of turbulence. As others have explained, the air above the mountains is reacting to the terrain, and the Andes being pretty high, they can affect aircraft flying far above them or even in the general area.
Fly Douglas Jets DC-8 / DC-9 / DC-10 / MD80 / MD11 / MD90 / 717
Thenoflyzone
Tue Aug 19, 2003 6:23 am
Anyone know what time of the day do turbulence's occur the most?
I heard that early morning flights just before or during sunrise is the worst time to fly because of the turbulences?..Is this true?
TheNoFlyZone
us Air Traffic Controllers have a good record, we haven't left one up there yet !!
star_world
Tue Aug 19, 2003 6:25 am
I'd heard the opposite, that the turbulence becomes more severe in the afternoon when the ground has been heated for most of the day by the sun, creating more thermals and therefore more disturbed air.
star_world
POSITIVE RATE
Tue Aug 19, 2003 9:00 am
Definitely afternoon. Early morning is supposed to be the calmest part of the day for flying- especially in summer. By afternoon the ground has heated up and someone already mentioned thermals are created andmore turbulence results.
c172akula
Tue Aug 19, 2003 9:41 am
I do my mountain flying in the morning here at YYC. By the afternoon you can get some wicked turbulence. And when we have the chinook wind coming out of the west, forget flying into the mountains unless you want to experience some Cumulus Granitis.
Thenoflyzone
Tue Aug 19, 2003 11:05 am
yeah!...hehe...Cumulo-Granite is bad!...really bad!..hehe
