9V-SVE
Air Force One Questions
Wed Aug 27, 2003 7:22 pm
Does the US really need two such aircraft? Wouldn't one be enough to suit the needs of the President of the USA? How do they choose which to use etc?
BR715-A1-30
RE: Air Force One Questions
Wed Aug 27, 2003 7:55 pm
They primarily use VC-25A 82-8000, but if that one is having maintenance done when the president needs it, they will use 92-9000. Sometime 82-8000 might be having Engine overhauls ETC. and they will need to use 92-9000. So basically 92-9000 is an identical twin back-up.
Puhdiddle
jetjack74
Wed Aug 27, 2003 10:57 pm
Also one is used a chase plane if they want to switch planes in the middle of the president's trip.
Made from jets!
IslandHopper
Thu Aug 28, 2003 1:38 am
Hopefully AFTER he has landed, of course.  Laugh out loud
twalives
Thu Aug 28, 2003 1:54 am
a tangent from the topic...i got the pleasure last night of watching AF1 takeoff from STL around 8 p.m...that's one gorgeous bird.
ntspelich
Thu Aug 28, 2003 2:34 am
I remember about 5 or 6 years ago that President Clinton flew to CMI to give a speech at the Univ. of Illinois. It had been raining all morning and when USAF1 was taxing off, it made the turn too wide (at least for the airport which is configured mainly for turboprops and rjs) and the front gear got stuck in a giant mud pit. After about an hour of trying to get the plane moved, they brought over some stairs and the President got off and went to make his speech. However, since they couldn't get the plane out, they dispatched a second aircraft as a precaution in case the first was unable to get out of the mud by time the speech was over. Luckily it did get out of the mud, but after the spare had arrived I believe. So, I guess that's a good enough reason to have an extra one lying around.
Here's an article about it if anyone really cares, however they refer to the plane as being a 707. article
NS
United 717 heavy, you're facing the wrong way. Any chance you can powerback to get off of my deice pad?
