Pe@rson
146 Departing With 3 Engines?
Fri Aug 29, 2003 9:32 pm
Four or five years ago, I remember being at LHR when a Manx 146 changed to the departure frequency for takeoff from 27L.
After the usual commentry, the pilot operating the radio (the first officer) stated that it will be departing using three engines - not four - and thus it will need to apply full power before releasing the breaks.
Has anyone experienced this as a passenger or otherwise?
I presume that such incidents rarely occur, but how roughly how frequently do they happen?
What is the likely cause of this? A mechanical problem?
James.
MEA-707
RE: 146 Departing With 3 Engines?
Fri Aug 29, 2003 9:44 pm
I am sure you were listening to the scanner and not on board? It can't possibly have been a passenger flight, presumeably the 146 went tech, most 4 engined planes are known to make 3 engine empty ferry flights to their maintenance base once in a while. I don't think 2 engined planes are allowed to take off with one engine, and I doubt about threeholers.
nobody has ever died from hard work, but why take the risk?
Pe@rson
Fri Aug 29, 2003 9:48 pm
No, it was a scheduled passenger flight - it used its normal flight number on its LHR-IOM service.
Yeah, I was listening to a scanner.
OPNLguy
Fri Aug 29, 2003 10:07 pm
Engines sometimes need to be changed for various reasons, such as internal problems such as failed bearings or metal shavings from a failed component, or due to birdstrike damage, or other reasons. When the determination is made that an engine needs changing, the aircraft may not necessarily be at a location where the airline involved has a spare engine and folks to change it.
Three- and four-engined aircraft can ferry (sans passengers) to locations where the engine can be changed. This is usually done with a management crew flown in especially for the flight. Such a ferry usually isn't a problem, but sometimes they crop up. An ATI DC-8 freighter taking off from KMCI a few years ago on a three-engine ferry aborted takeoff, taxied back and tried again, only to crash on the second attempt. Back in the 1980s sometime, an Eastern L-1011 on a 2-engine ferry coming out of Mexico City to KMIA lost another engine on departure, and they returned safely to MMMX on a single engine. Those are the exceptions; most go off without a hitch.
With two-engined aircraft, the engine must come to wherever the aircraft happens to be, and changed on-site. Here in the US, that means that you usually truck-in a new engine (which can take a day or two, depending how far the aircraft and replacement engine are from one another). In some other cases (with larger engines, or at remote places) a new engine has to be flown in either a dedicated cargo plane, or ferried in as an "extra" engine on a scheduled flight. There a number of photos of 747s and DC-10s in the database that show an extra engine hanging on the wing.
Hope this helps...
POSITIVE RATE
Fri Aug 29, 2003 11:35 pm
I would have like to have seen the rate of climb of that 146. It climbs bad enough with all 4 engines running let alone with 3. Must of been a real dog!
tjwgrr
I witnessed a NWA DC-10 take off from GRR on a ferry flight (w/o pax) to DTW on two engines a number of years ago. The flight had diverted into GRR due to the mx problem.
Takeoff wasn't all that spectacular, but the a/c did use a fair amount of runway and climbed rather slowly....
Direct KNOBS, maintain 2700' until established on the localizer, cleared ILS runway 26 left approach.
dispatch
Sat Aug 30, 2003 12:20 am
I once saw a 747 take off with FIVE engines, does that count in this thread  Big thumbs up
Peter
gigneil
Sat Aug 30, 2003 12:37 am
Hmm... I dunno. Climb performance, and specificially 3 engine climb performance, is the reason why the 146 is the only commercial jet airliner that can serve places like ASE.
N
Capital146
Sat Aug 30, 2003 1:20 am
Gigneil,
not to mention London City! Runway length under 4000ft!
Like a fine wine, one gets better with age.
VC-10
Sat Aug 30, 2003 1:28 am
I can assure you it wouldn't have been a pax flight. Only operating crew are allowed on 3-Eng ferries.
Can you imagine the compnsation claims if it had taken off with pax and them gone down?
Pe@rson
Sat Aug 30, 2003 2:04 am
"I can assure you it wouldn't have been a pax flight."
It's odd, then, why it was using the normal flight number. Ho hum.
meister808
Sat Aug 30, 2003 2:12 am
Positive rate:
Have you ever flown on a 146 or ARJ??? The takeoff is pretty spectacular, and certainly not "bad" as you allude to.
fritzi
Sat Aug 30, 2003 2:16 am
...and thus it will need to apply full power before releasing the breaks.
B R A K E S  Big grin
Hopefully he didn´t apply full thrust on all three engines at the same time.
Normally you increase the power on the engines positioned at the same location under each wing before you apply power on the third one, otherwise you wouldn´t be able to keep the aircraft on the rwy due to the uneven thrust. The thrust on the third engine would be increased slowly as your speed builds up to maintain control of the aircraft.
Pe@rson
Sat Aug 30, 2003 2:25 am
"B R A K E S "
Indeed!  Big grin Time I had a BREAK, though. :p
POSITIVE RATE
Sat Aug 30, 2003 12:14 pm
No i haven't actually flown on the 146 but i've spoken to many people who say the 146 is a poor performer. For starters it's equipped with 4 "blowdryers", and the reason it's got 4 is because each on their own produce so little thrust it needs all 4. ATC often make jokes about the 146 and its slow climb rate. Plus it's limited to 25,000feet altitude(at least here in Australia it is). The RJ is the uprated version so it has better performance- i'm referring to the older 146-100/200/300 series. And yeah i've seen them takeoff, nothing spectacular to look at really. The 737 takeoff is much more impressive.
tavong
Sat Aug 30, 2003 12:22 pm
Well about the performance here in Colobia SAM tried to operate with Avro RJ-100 but their performance here was so poor that they returned them but Colombia has special things that makes a lot of planes difficult to operate, same happened to 737-100.
Gustavo.
Just put me on any modern airliner and i will be happy, give me more star alliance miles and i will be a lot happier.
