POSITIVE RATE
Spruce Goose The Biggest Plane Ever Built?
Fri Sep 12, 2003 9:07 am
I was watching an episode of Wings last night on Discovery channel and they said the Spruce Goose was the largest plane ever built. It was even bigger than the upcoming A3XX, and was the first plane to use hydraulics for flight controls. I find it amazing that something like that could be built in the 30's. It only ever flew once though due to lack of customers. Was Spruce Goose bigger than even the AN-124?
timz
RE: Spruce Goose The Biggest Plane Ever Built?
Fri Sep 12, 2003 9:20 am
It had the longest wingspan, and it might be the tallest. Probably not the largest in any other respect.
flyf15
Fri Sep 12, 2003 9:21 am
It depends on how you measure "big". My preference and a generally accepted way is by maximum takeoff weight. In this catagory, and many many others, the An-225 is the winner by a long shot.
Goose
Fri Sep 12, 2003 9:24 am
The Spruce Goose was actually built in the 40s. Its first (and only) flight was in 1947.
By the time it flew though, it had really passed its projected use - as a sort of "airborne landing craft" to land tanks, men and material on distant shores in (presumeably) the Pacific islands. That would've been interesting to see.
"Talk to me, Goose..."
desertjets
Fri Sep 12, 2003 9:50 am
It was more of a flying lumber yard than an actual plane. I still question whether the plane could really fly, as Howard Hughes only had it skimming the waves for a short while before putting it down.
CanadianNorth
Fri Sep 12, 2003 10:00 am
I thought that the Antonov 225 was the worlds largest...
CanadianNorth
HS-748, just like a 747 but better!
727LOVER
Fri Sep 12, 2003 10:04 am
Where is the Goose now?
"We must accept finite disappointment, but never lose infinite hope." - Martin Luther King, Jr.
Goose
Fri Sep 12, 2003 10:09 am
Official Designation: An-225 Mriya
NATO Code Name: Cossack
U.S. Counterparts: Lockheed C-5 Galaxy (1968) and Boeing 747 SCA (1977)
Primary Role: Massive strategic airlift (designed to transport the Soviet space shuttle, Buran)
National Origin: Ukraine
Manufacturer: Antonov Design Bureau
Wingspan: 290 feet (88.4m)
Length: 275 feet, 7 inches (84m)
Height at Tail: 59 feet, 5 inches (18.1m)
Cargo Hold Length: 142 feet (43.32m);
Width: 21 feet (6.4m);
Height: 14 feet, 4 inches (4.39m)
Armament: None
Engines: Six ZMKB Progress Lotarev D-18T turbofans
Thrust: 51,590 pounds (229.50kN) per engine
Cruise Speed: 497 mph (800km/h) est.
Max Speed: 528 mph (850km/h) est.
Range (w/ max payload): 2,425 nm (4,500km)
Range (w/ max fuel): 8,310 nm (15,400km)
Service Ceiling: Unknown
Operating Weight: Unknown
Max Payload:
(internal or external) 551,150 pounds (250,000kg)
Max Takeoff Weight 1,322,750 pounds (600,000kg)
Basic Crew: Seven
Date Deployed: 1989
Total in Service: 1 aircraft
Official Designation: HK-1 (H-4) Hercules Flying Boat
Unofficial Nicknames: The Spruce Goose, Flying Lumberyard
Primary Role: Military transport
National Origin: USA
Original Contractor: Hughes Aircraft Company
Wingspan: 320 feet
Wing Area: 11,430 square feet
Length: 218 feet, 6 inches
Height at Tail: 80 feet
Tailspan: 113 feet, 6 inches
Height of Fuselage: 30 feet, 6 inches
Width of Fuselage: 24 feet, 5 inches
Volume of Cargo Hold: 165,000 cubic feet
Armament: None
Engines: Eight Pratt & Whitney R-4360 Wasp Major radials (largest radial reciprocating engines ever built)
Horsepower: 3,000 shp each
Propellers: Eight four-bladed Hamilton Standards with a diameter of 17 feet, 2 inches (the four inboard propellers have reverse pitch capability)
Cruise Speed: (est.) 175 mph
Max Speed: (est.) 218 mph
Range (est.): 3,000 miles (flew one mile during first and only flight)
Service Ceiling (est.): 20,900 feet
Gross Weight: 400,000 pounds
Max Payload: 130,000 pounds
Total Cost: $40 million
First Flight: 2 November 1947
Total Produced: One aircraft
... There, a straight-up comparison.
Goose
Fri Sep 12, 2003 10:10 am
The Goose is in the Evergreen Aviation Museum.
http://www.sprucegoose.org
POSITIVE RATE
Fri Sep 12, 2003 10:20 am
I wonder why Hughes didn't take it up any higher than 70 feet? He must not have trusted the aircraft because it had never been flight tested before.
desertjets
Fri Sep 12, 2003 10:25 am
Well Hughes was nuts, but maybe not THAT nuts.
IMissPiedmont
Fri Sep 12, 2003 1:57 pm
All questions of the original post have been answered above.
Whether it ever "really" flew is another matter. Think "Glomar Explorer" on that matter. It wasn't always in the "Disney Dome" you know.
[Edited 2003-09-12 06:58:46]
The day you stop learning is the day you should die.
JMChladek
Fri Sep 12, 2003 5:36 pm
The plane didn't lift higher then 70 feet because Hughes was essentially taking it on a high speed taxi test. So he didn't announce that he was going to do it and the plane wasn't really set up for a true test flight. Hughes was a bit eccentric, but in this case it seems to be a matter of proving his point that it would fly in such a way that if anyone from the FAA asked him that he planned to fly it deliberately, he could cover his butt and say no, that the plane got airborne during the taxi test is all.
I personally like the Hughes reference in "The Rocketeer" when Cliff escapes the FBI by hanging under a scale model of the HK-1 and gliding it out of the hangar. Pretty silly, but a cool movie.
L-188
Fri Sep 12, 2003 5:48 pm
That is the version I heard.
Everybody on the flight deck had been briefed that it was only going to be a high speed taxi test, but about a third of the way down the run Howard asked for the first notch of flaps and the rest is history.
Frankly I think it was a completely intentional unapproved flight.
Don't forget that it wasn't long after that, Howard really came close to killing himself when he crashed his F-10 photo reconnaissance aircraft. A lot of people think that the crash caused brain injuries that led to his madness in later life.
JGPH1A
Fri Sep 12, 2003 8:18 pm
Was the Spruce Goose ever going to be a passenger aircraft ? If so, how many pax, what sort of accomodations. Bearing in mind that in those days the flying boats were pretty luxurious anyway, I imagine that the Spruce Goose would have been spectacular !
Young and beautiful and thin and gorgeous AND BANNED ! Cya at airspaceonline.com, losers
L-188
Fri Sep 12, 2003 8:26 pm
Well it probably could have been but it was never designed for that.
It was designed to be a military transport, much like the Martin Mars series.
At the time the Kreigsmarine where giving us a hell of a time with the U-Boat Wolfpacks decimating convoys. Oddly enough torpedo's generally don't affect aircraft so the idea was to create a couple of very large seaplanes that could move high priority cargo across the pond without the worry about it ending up at the bottom of said pond.
The war ended before either design could be produced, I belive Martin only built 4 Mars Boats, two of which as still used as tankers in B.C. The HK-1 only flew the one time.
Arrow
Sat Sep 13, 2003 12:47 am
Those two Martin Mars have been active 7 days a week up here for the last two months saving our butts (or at least trying) in the worst forest fire season ever recorded. Several times, I've watched them fly overhead in the early evening on their way back to Sproat Lake for maintenance before they trundle back into the Interior again the next day for another go at it.
They are amazing aircraft.
Never let the facts get in the way of a good story.
gr8slvrflt
Sat Sep 13, 2003 2:10 am
I know it's not an airplane per se but the LZ-129 Hindenburg and her sister ship, the LZ-130 Graf Zeppelin II were both 804 feet long. An even larger ship, the unnamed LZ-131, was to have been 863 feet long!
I work for Southwest, but the views expressed are my own and do not necessarily represent those of Southwest.
mariner
Sat Sep 13, 2003 2:12 am
A question:
Does anyone know if the Spruce Goose was bigger than the Princess flying boat?
TIA
cheers
mariner
aeternum nauta
gr8slvrflt
Sat Sep 13, 2003 2:34 am
Saunders & Roe Princess:
Wingspan - 220 feet
Length - 148 feet
Height - 56 feet
Max. TO Weight - 330,000 pounds
Range - 5,270 miles
elwood64151
Sat Sep 13, 2003 2:44 am
DesertJets:
Actually, the Goose reached an altitude of 70 feet and flew for several hundred yards. This is not to say I believe it could have gone any higher or farther, 'cause frankly I don't know that, but it did take to the air.
I think the real reason Hughes took the HK-1 to the air was to make sure he got paid for building it.
L-188:
I'm still laughing at that one...
I frequently wonder why the Navy doesn't build high-speed hydroplanes or surface-skimming "ground effect" lifting bodies to avoid those torpedos... At least then all they have to worry about is missiles, which can be intercepted.
Also, I think the Goose could have been used as an airliner if it had seen action during the war. It was designed, after all, to carry hundreds of troops and/or heavy cargo. Of course, flying boats were on their way out at the end of the war, but an HK-1 becoming operational in, say, 1944 and proving itself the way the C-54 (DC-4) and C-69 (L-649) did might have produced some orders from Pan Am, BOAC, or one of the other long-distance international carriers.
Those who fail to learn history are doomed to repeat it in summer school.
Goose
Sat Sep 13, 2003 1:56 pm
Well, if that's the case.... he lost on that bet. He spent much of his own money to complete the plane - after Kaiser pulled out and the military R&D money dried up, that is.
He never did get repaid the money he spent to build the Spruce Goose.
JMChladek
Sat Sep 13, 2003 5:12 pm
The problem with hydroplanes and ground effects craft is that they are somewhat limited in overall size and capability. Hydrofoils require a certain speed to work, and even then you still have a parts in the ocean and it would be bad if a torpedo hit one anyway. Ground effects craft can be made larger, but they need to carry more engines and burn higher grade fuels then a typical ship. They are great for fast deployment of cargo and troops, but not that much else. BTW, the USMC and USN do operate one hovercraft system for fast deployment of forces and it works very well for that. Modern Naval fleets have pretty good protection against subs that even if a sub did manage to launch one torpedo on a target, chances are it wouldn't get a chance to fire a second before getting clobbered by ASW forces. Also the ships are pretty well designed to minimize damage from torpedoes, unless they are nuclear and all bets would be off anyway if that happened.
sllevin
Sat Sep 13, 2003 8:49 pm
For a landplane, you're right -- staying in ground effect does not imply something can fly. But for a seaplane, the most difficult thing, by far, is actually breaking loose of the water. Any seaplane that can get airborne will easily fly outside ground effect.
I can't fathom a sure guess why Hughes didn't go for a spin over downtown. He was an odd character (although a great pilot), for sure.
Some of the things that may have gone through his head:
1) CYA with the FAA (but, then again, he was Howard Hughes. Like he couldn't have dealt with that?)
2) He didn't want to expose a crew that hadn't agreed to the risk of flying to that danger (but then again, it wasn't like he had a planeful of children on board. And he was fairly selfish)
3) He just didn't like the handling of the aircraft and decided not to fly it farther.
4) He thought aliens would abduct him if he flew higher than 70 feet.  Smile
Steve
vanguard737
Tue Sep 16, 2003 6:15 am
The Sproose Goose is nice, but I find the Messerschmitt Me-323 of WW2 to be much more amazing. It was smaller, yes, but still impressive. It was powered by six Gnome Rhone Engines and had a Max T/O Weight of 94,815 pounds! Impressive for that era! It could even transport medium sized German tanks or 120 fully equipped troops! Also, it was mass produced, which the Sproose Goose wasn't.
Take a look at it here: www.www.warbirdsresourcegroup.org/LRG/me323.html
320 717 722 732 733 735 737 738 739 744 752 753 763 772 773 788 DC9 DC10 MD80 B1900 S340 E120 E145 E170 E175 CRJ CR7
Alessandro
Tue Sep 16, 2003 6:32 am
Well, I think it only flew because of the ground effect, like the Dornier Do-X.
The most amazing thing about the Spruce Goose is the hydrualics.
Worlds largest cargo bay on an airplane is the Airbus Beluga, An-225 got the
heaviest load ever lifted.....
[Edited 2003-09-15 23:35:15]
