UAL747
Areas Known For The Worst Turbulence
Sat Sep 20, 2003 11:35 am
I was wondering if there are certain areas of the world where turbulence is pretty much a constant. Here in the US, flying over the Rockies almost always produces some light to moderate chop. The weather at MIA seems to be a big producer of turbulence, and probably the worst is the plains states in spring with all the storm clouds everwhere.
N766UA
RE: Areas Known For The Worst Turbulence
Sat Sep 20, 2003 11:40 am
I'd say in and around the rockies is consitantly the worst. Puddle-Jumper pilots out there have alot of stories to tell, I'm sure.
This Website Censors Me
AirVB
Sat Sep 20, 2003 12:03 pm
I'd have to agree about the Rockies-consistently bumpy on the times I've flown out of DEN.
AirVB
UAL747
Sat Sep 20, 2003 12:06 pm
Both flights I've had over the Swiss alps have been very bumpy as well. Denver approaches are probably some of the worst. I have also encountered a lot of turbulence around Japan on HKG-USA flights, and on decent into NRT.
UAL747
pilottim747
Sat Sep 20, 2003 12:20 pm
The North Pacifc can be quite the ride I believe. I've only flown through it a couple times but last time on a flight from HKG to SFO we hit some good turbulence over Japan with a strong weather system. On that flight we we're at FL330 when it hit (we had be warned ahead) but had to stuff it out for a little until we had burned off enough fuel to climb to a higher altitude (I think we ended up at FL370).
pilottim747
Aviation Photographers & Enthusiasts--Coordinate your life.
copenhagenboy
Sat Sep 20, 2003 12:21 pm
Correct, but I also feel some waterarea like the Biscayen and the Indian Sea can give some heavy turbulence aswell?
AA777MIA
Sat Sep 20, 2003 12:31 pm
Definitely over the Rockies, depending on the time of the year, decent into LAX can be a bit bumpy as well into MIA...
BA
Sat Sep 20, 2003 12:45 pm
Rockies are bumpy as are the Alps at times.
However, the king when it comes to turbulence is the Aleutian Islands in Alaska. No place on Earth has worse turbulence.
Heard some horror stories from B-17 pilots during WWII that had to fly over the Aleutian Islands during the campaigns against Japan.
"Generosity is giving more than you can, and pride is taking less than you need." - Khalil Gibran
Dazed767
Sat Sep 20, 2003 12:48 pm
Florida, in the late afternoon, in the summer time.  Big grin
The Rockies are pretty rough though.
MCIB757
Sat Sep 20, 2003 12:57 pm
LAX gets hit by the Santa Ana winds during part of year and that makes it pretty rough around there. Also watch out for those pop-up thunderstorms in the midwest during the spring.
Tom
"God bless catastrophe..."
BlackJackLV
Sat Sep 20, 2003 1:04 pm
I've flown in and out of Reno (RNO) several times and I've almost always had a rough ride. The winds over the Sierra Nevada's always make for fun trip into Reno/Tahoe.
jpetekyxmd80
Sat Sep 20, 2003 1:09 pm
Rockies, last month YX912 SFO-MCI encountered bad turbulence resulting in 2 FA's with broken legs and an emergency landing at DEN. It always gets a little bumpy there atleast.
The Best Care in the Air, 1984-2009
RNOcommctr
Sat Sep 20, 2003 1:11 pm
Yes, BlackJackLV, lots of green-faced passengers getting off planes at RNO. Often there's a pretty bad windshear on very short final to 16R.
Active loading only, ma'am, keep it moving!
kilavoud
Sat Sep 20, 2003 2:58 pm
http://www.geocities.com/khlim777_my/asturbulence.htm
This year I have been flying three times between Zurich and Singapore, and I have notice that in Bay of Bengal near Andaman Islands it was every single time turbulent, but normally.
But during the flight of end of May, the whole area south of Himalayas, between Pakistan and Andaman Islands was turbulent with only very short breaks. It was for the first time in my life that I had to experience such a long bumpy flight, so long that I began to have a pain in my stomach.  Nuts
Was it due to the approach of the monsoon in Indian Subcontinent ?
Regards. Kilavoud.
QANTAS747-438
Sat Sep 20, 2003 3:06 pm
I'd say that an area that gets a ton of turbulence is around the equator in the Pacific. All the winds and pressures rise up at the equator and travel to their respective poles. I flew LAX-SYD-LAX and it's notoriously bumpy with lightning storms and pockets of turbulence that appear to come out of nowhere. It threw our 744 up and down quite hard a few times.
milesrich
Sat Sep 20, 2003 7:51 pm
Mt. Fuji Japan. A BOAC 707-436 was literally torn apart in clear air turbulence there in the early 60's.
As previous writers pointed out, flying into RNO and DEN can be pretty rough. There is often a mountain wave that rolls down the east side of the Rockies at DEN. But for a wild ride, try TVL. When Air Cal and PSA flew Electras in their in the mid and late 70's, both take off and landing could be quite turbulent.
7E7
Sat Sep 20, 2003 8:25 pm
Kilavoud, indeed Bay of Bengal near Andaman Islands is one of a hell place to fly through. On an earlier trip with EK last year on a B773 (I think EMS) I actually saw the tea flying out of the cup in mid-air (10-15cm high and I would not be exagerating), then splashing back inside of it.
With EK also, on an A330 few months back, my mate spilled his coffee all over his clothes as he lifted the cup as the FA was backing up dinner trays.
Same area, two years ago, with GF on a A340 (A4O-LF) similar things happened.
Another mate of mine had also some 'sickening' trip (over the same region) when he flew with MH from KUL to DXB early this year.
AMS
Sat Sep 20, 2003 8:31 pm
I always experience heavey turbulance above Japan.
regards,
AMS
sq_ek_freak
Sat Sep 20, 2003 9:09 pm
For me the areas where moderate turbulence seem always to be present is in the areas of Japan, as I fly over it (on the way to HKG/SEL) or as we descend into NRT, KIX or NGO. There was a time flying from SIN-NRT on Singapore Airlines when we hit bad turbulence as we were just commecning our descent into NRT. The plane just dropped catching people unaware. The seat belt sign went on in a flash as we started veering left right and center and dropping up and down. An FA fell over as she was walking and into a lav. The poor FAs tried to get their pre landing procedures done as the plane became a roller coaster. The American captain later apologized sincerly both to his passengers and to his crew. Also, flying over the northern Pacific on the way to the US from Asia usually yields some turbulence as well.
The Bay of Bengal can also equate tons of turbulence, most harshly during the monsoon season. The worst I had encountered was with SQ on their A310 on a Dhaka to SIN run. The plane was bouncing all over the place from take off and the crew couldnt even start meal service until about two and a half hours into the flight.
These two areas consistently give turbulence, though the worst I have experienced was on a flight from BNE to Port Moresby on Air Niugini. Bags falling all over the place, the crew going haywire in the forward galley...what an experience.
Keep Discovering
JumboBumbo
Sat Sep 20, 2003 9:12 pm
Flights into DEN on summer afternoons always seem to be pretty rough. This is due to the convective storms that usually for on summer afternoons in the Rockies and then move out east over the plains.
I would imagine that turbulence is typically pretty bad over most mountain ranges. This is due, in part, to the way in which topography disrupts movement of weather patterns over the land surface... a phenomena known as orography or orographic lifting.
I would be curious as to what is driving the turbulence over places like the Bay of Bengal. Kilavoud might be on to something when he suspects the approach of the Monsoon is the culprit.
TNboy
Sat Sep 20, 2003 9:56 pm
One of the complaints with SQ using the A340 on flights to Europe was that, with the long, slow climb, there was always a long period of turbulence over the Bay of Bengal.
I've always found the equator bumpy on SYD-LAX flights, as well as around Fiji; and North Pacific runs can be like travelling on padded corrugated iron at times. Around Singapore can be bumpy, although ATC is pretty good at manoeuvering flights around the worst of it; Japan can be bumpy a lot of the time, and the west coast of Australia can get buffetted by winds quite often, not to mention cyclones. I've had some pretty bumpy trips across the Rockies also.
The Pacific runs are also generally at night, which makes it a bit worse. But the trick is to keep the seat belt fastened, relax, and trust the integrity of the aircraft, the systems and the crew. And have a drink!
Bill
"...every aircraft is subtly different.."
jcs17
Sun Sep 21, 2003 12:42 am
I dont think flying in the Rockies is too bad. I flew DEN-ASE this summer on a 146, and it was a relatively smooth flight. In fact, the worst turbulence occured while we were still over the Denver area and not over mountainous terrain (downsloping winds, perhaps?).
America's chickens are coming home to rooooost!
StevenUhl777
Sun Sep 21, 2003 12:57 am
I'm surprised no one mentioned flying over Iceland/Greenland? I've flown between LHR/LGW and SFO/LAX a few times and it's almost always bumpy in that area.
I flew a DEN-ABQ in July 1991, and even though it was only an hour or so, it was bumpy the ENTIRE way, right up until touchdown.
And the winner for best actress is....REESE WITHERSPOON for 'Walk the Line'!!!!!!!!
Vimanav
Sun Sep 21, 2003 1:01 am
Bay of Bengal gets my vote. I have overflown that area at almost all times of the year and each time there was some chop from moderate to severe. My pilot friends definitely have a thing or two to say about the area though there are other areas around the globe as well including the notorious Mt. Fuji area in Japan. (there is a saying in Japan that when the sky is clear, Mt. Fuji is angry!!) - lots of CAT.
Coming back to Bay of Bengal - a lot of aircraft have been lost in that area. Its most famous victim being Sir Charles Kingsford Smith.
rgds//Vimanav
Sarfaroshi kii tamannaa ab hamaare dil mein hai, Dekhnaa hai zor kitnaa baazu-e-qaatil mein hai
CRJ 900
RE:Turbulence
Sun Sep 21, 2003 3:04 am
From my experience it would be the mainland to Hawaii in the winter( it never fails and always at night) and coming off the lee side of the rockies.
pilottim747
Sun Sep 21, 2003 3:15 am
Here's a little explanation of the Bay of Bengal turbulence experiences from An excerpt from FLYING THE HUMP by Otha C. Spencer:
The world’s most violent weather comes into Asia because it is the meeting place of three turbulent air masses: low pressure from the west moves along the main range of the Himalaya between Tibet and India to the Hump, where warm, wet high pressure systems from the Bay of Bengal clash with frigid low pressure from Siberia. The polar vonex, and the heat rising from the jungles of Burma, intensify the weather movement.
pilottim747
Sun Sep 21, 2003 4:39 am
I would say maybe the areas off the coast of Ireland and the UK are bad especially in Winter when we have severe storms!
EGFFbmi
 Smile/happy/getting dizzy
buckfifty
Sun Sep 21, 2003 4:42 am
Japan can experience severe chop from westerlies flowing over mountainous terrain, and from the jet streams as you're travelling en-route overhead. The polar jets overhead Japan in the wintertime are the strongest jetstreams that exist over the earth on a seasonal basis.
Orographic lifting is ascending air when it hits the mountain, though more often than not, it is used to describe the formation of clouds and precipitation. Orographic turbulence, on the other hand, is a more common usage of the term when describing turbulent effects when air is passing over upsloping terrain. More often than not, they're also associated with mountain waves, which can exist leeward of the ranges for almost hundreds of miles, depending on the stability of the weather mass it exists in. Creates side effects like rotor streaming (very very nasty). Areas around Denver are extremely prone to this type of weather pheonmena.
Goose
Sun Sep 21, 2003 4:47 am
I've heard that flying over the Sea of Japan can be fun, especially during storm season.......
"Talk to me, Goose..."
DeltaRules
Sun Sep 21, 2003 4:58 am
One I didn't see above- All three times I've flown into DCA, it's been a rough ride. I don't understand why this is....anybody know?
DeltaRules
syncmaster
Sun Sep 21, 2003 5:29 am
Let me put it this way, my first time flying in and out of DEN (From SBN to SEA) in June was the most turbulent flight(s) I have been on, particularly while on approach.
copenhagenboy
Sun Sep 21, 2003 5:43 am
Correct, but I also feel some waterarea like the Biscayen and the Indian Sea can give some heavy turbulence aswell.
Indian Sea=Bay of Bengal, just to clarify  Wink/being sarcastic
jetdeltamsy
R E N O, Nevada
Sun Sep 21, 2003 8:22 am
it's like riding in on a bucking bronco. those hills around the field sure whip things up.
Tired of airline bankruptcies....EA/PA/TW and finally DL.
OS-A330
Sun Sep 21, 2003 8:56 am
Definitely the Bay Of Bengal!
flyboyaz
Sun Sep 21, 2003 8:59 am
TUS-PHX in the summer....barf city! Low altitude flying with hot temps.....HANG ON!
Catch a ride on a smile!
JetRanger2000
Sun Sep 21, 2003 10:31 am
I always get a very rough descent and takeoff into SLC.
FlyboyOz
Sun Sep 21, 2003 10:41 am
Yeah! I remembered that I hate to fly across between Australia and New Zealand and also on the way to US. I have encounted the worst turbulence I've ever had. Ont he US, I blamed that the turbulence always wake me up so that I could not slepp properly.
The Spirit of AustraliAN - Longreach
BCAInfoSys
Sun Sep 21, 2003 10:50 am
I agree with JetRanger, SLC can be quite a ride.
Militant Agnostic - I don't know and you don't either.
