Starship
Hawker Siddeley Trident
Wed Dec 29, 1999 5:34 am
Can anyone please explain the logic behind the Trident's nosegear being offset to the left and retracting sideways to the right? I have never seen this on any other aircraft and it certainly looks very odd when viewed from the front.
On another note, did you know that the Trident 3 had a fourth engine? It was located between the centre engine and the rudder above and was a Rolls Royce RB.162-86 booster with a thrust of 5 250 lbs. It was only used during take-off.
Nick
Behind every "no" is a "yes"
RE: Hawker Siddeley Trident
Wed Dec 29, 1999 5:55 am
It is an interesting a/c isn't it? In some circles it was referred to as the world's only "three and a half" engined jetliner. I understand that the booster turbo jet was added to increase takeoff performance (obviously) but the RR speys where pretty much at their economical limit of upgradability. It was cheaper to add the booster which could also be used during other phases of flight. The Trident was also the first airliner to be certificated for automatic landing in zero visibility. As far as the unusual landing gear, particularly the side retracting nose gear, I can't help you there. Perhaps this arrangement would make for an easier manual deployment since it wouldn't be competing with the wind as much as a forward extending gear. Regards, Doug.
viscount
Wed Dec 29, 1999 9:25 pm
We used to see loads of Tridents (mainly two's and three's) here in GIB in the 70's.
These were truly majestic aircraft. Pity that they were not stretched slightly and re-engined otherwise the 727 would have had a real competitor.
They were certainly underpowered. The three's had to stop in TNG en-route GIB-LHR because they could not lift enough fuel from here for the trip.
I think that the front bogie thing was just a space problem but I'll try and find out.
Tg 747-300
Wed Dec 29, 1999 9:36 pm
where is TNG?
Tg 747-300
intentionally left blank
pilot21
Thu Dec 30, 1999 3:09 am
Just a quick question in regard to the main landing gear of the Trident. I thought I saw/read somewhere that they turned 90 Degrees and retracted into the wing. Was this the case??
Aircraft I've flown: A300/A310/A320/A321/A330/A340/B727/B732/B733/B734/B735/B738/B741/B742/B744/DC10/MD80/IL62/Bae146/AR
Pilot 21
Thu Dec 30, 1999 5:19 am
Yes it's true the gear turned 90 degrees then inward. Each bogie had 4 tires...not like you'd see on a 747 but all on a single axle, 2 on each side of the strut..thats the primary reason for the 90 degree rotation
Thu Dec 30, 1999 12:10 pm
The nosewheel was offset to one side on the Tridents to accomodate the automatic landing system which was located on the centre line of the fuselage towards the nose
akelley728
Fri Dec 31, 1999 2:01 am
TNG - Tangier, Morocco
