futterman
Registration Position
Fri Sep 26, 2003 10:17 am
on all aircraft, the registration is displayed on the aft end, near the empennage or engines [rj's, s80, etc].
in addition, i sparatically see registrations under the wing, especially on 747s and classic props/jets. is there any specific reson as to why its not displayed under the wing on most aircraft, but it is on others?
What the FUTT?
Shenzhen
RE: Registration Position
Fri Sep 26, 2003 11:23 am
It all has to do with the country requirements from which the airplane is on register.
Fri Sep 26, 2003 12:31 pm
Actually, ICAO recommends (there ARE NO ICAO RULES, just recommendations) that registration be shown on the upper surface of the RH wing, the lower surface of the LH wing, and the sides of the aircraft, near or on the tail... but as Shenzen says correctly, many countries... do not abide by such practices...
xxx
Happy contrails  Smile
(s) Skipper
Vimanav
Sat Sep 27, 2003 5:32 am
Apart from the positions mentioned above, you are likely to see the last alphanumerics of the reg on the nose-wheel door and the last letter or last two letters of the reg in the centre just above the windshield.
rgds//Vimanav
Sarfaroshi kii tamannaa ab hamaare dil mein hai, Dekhnaa hai zor kitnaa baazu-e-qaatil mein hai
