VS340
Safest Plane To Ditch
Sat Oct 18, 2003 11:20 am
If the situation arose where a plane was forced to ditch in water, what would be the best aircraft type to be in? which type would stand the best chance of remaining intact?
MD11LuxuryLinr
RE: Safest Plane To Ditch
Sat Oct 18, 2003 11:25 am
The MD11 seems to do pretty well when it crashes.. The CI and FE crashes in the late 90s.. both aircraft's hull was pretty much in tact. 312 of the 315 people on the CI jet survived (we all saw that horrific video) and the crew members on the FedEx jet survived too. As for water.. who could tell?
 Big thumbs up
Caution wake turbulence, you are following a heavy jet.
Birdwatching
Sat Oct 18, 2003 11:30 am
I guess an advantage is if the plane has no engines on the wings (727, DC9) because when landing on water the engines would touch the water first, ripping the wings off and probably breaking the fuselage. Some of you have maybe seen the tourist's video of that 767 landing on water in the Carribbean a couple of years ago, but I can't remember what airline / when it was.
So my guess is that you're safer on an airplane without engines on the wings, but I have no proof for it. Just sounds logic...
All the things you probably hate about travelling are warm reminders that I'm home
AZAFATA
Sat Oct 18, 2003 11:34 am
I would think any airplane with the engines mounted at the rear (717,dc-9,md-80,ect).Years ago I saw in the news a 767(i think) ditching in the indian ocean and the engines impacted first causing the airplane to break apart,also years ago a dc-9 from ALM airlines ditched in the caribbean and some pax's survived,the airplane didnt break apart.I think not having the engines on the wing gave that airplane a "flat" surface to land on.This is just what I think.....What do I know anyways...
airman99o
Sat Oct 18, 2003 11:38 am
Hey there,
Engines on a plane are designed to break off on impact. I think hitting the water at the speed the plane would be going would be sufficient impact. The 767 that you mentioned was of Ethopian Airlines. I think that crashed off the coast of Africa. I wonder if the pilot managed to have the plane level would it have been a successful ditching?? If there is such a thing????
Airman99o
Safety is Everyones Responsibility.
VS340
Sat Oct 18, 2003 11:44 am
I believe that the Ethiopian 767 would have been level had the terrorist who hijacked the plane not interfered with the controls at the last second causing the wing to roll into the water first
pilotpip
Sat Oct 18, 2003 11:52 am
If you're in the North Atlantic I really don't think it matters. Hypothermia will kill you in a matter of minutes.
DMI
gigneil
Sat Oct 18, 2003 12:13 pm
Airbus is studying this in depth, along with the AWIATOR. I had a great PDF about it that someone posted here, and now I can't find it to save my life.
Mostly about ditching in water... but I'm sure studies are ongoing about ditching on land with no gear.
N
Sat Oct 18, 2003 1:15 pm
Ditching.... This is an airline subject we can all be in fear of! There has never been a safe ditching i.e. no fatalities..(of a decent sized aircraft falling from the sky)! To be honest, think about it! A mass of metal, full of fuel, plunges to the Earth, at nearly 500 miles an hour! Outcome - not so good! In Flight Attendant training -Ditching- is discussed but taken with a grain of salt. If a plane full of fuel hits the water.. she will not land like a graceful swan. Say goodbye, and have a cocktail on the way!
VS340
Sat Oct 18, 2003 1:36 pm
well, thats reassuring
Airbus Lover
Sat Oct 18, 2003 1:37 pm
Umm Kl777jfk
I think they are refering to ditching in the ocean during an emergency. So i dont think it would be at 500mph more like a Vref speed I suppose...
There were successful ditchings before i believe, IIRC.
L-188
Sat Oct 18, 2003 1:39 pm
I know that Flying Tigers had a DC-6 successfully ditch, and Pan-Am did it with a B-337, but those where back in the 1950's.
I would suggest though that the safest aircraft to ditch would be one of Chalks Mallards.
GulfstreamGuy
Sat Oct 18, 2003 1:49 pm
This Convair did fairly well....  Laugh out loud
Photo © Fabrice Nelson
Photo © Graham Hitchen
GG
"If we couldn't laugh, we would all go insane. " -Jimmy Buffett
airxliban
Sat Oct 18, 2003 2:00 pm
Something with a low stall speed, large wing area and engines not reaching below the fuselage.
I think that the safest plane to ditch would be a BAe-146 to the due efffect of the top mounted wings on the B-force. In the open sea, I think that any aircraft would be doomed. If it was a BAe 146 in the same situation as the Ethiopian 767 (near an island in somewhat shallow waters) I think there would have been fewer fatalities.
Just my opinion. I would think something like the concorde wouldn't be too bad either due to the shape of the engines and the delta wing. Should we try it? At mach 2 and 60,000 ft....just drop the noise and accelerate down to the sea level then pull up. I wonder what speeds it would reach? Probably break apart b4 touching water.
Anyway, just my opinion.
Air Liban
ha763
Sat Oct 18, 2003 4:05 pm
The Ethiopian 767 crashed like it did because one of the hijackers was at the controls. It took great courage and strength for one of the pilots to regain control so that some of them even had a chance to survive. If the pilot had more time, the aircraft would have hit the water more level and not the way it did.
A high wing aircraft would most likely fill up with water to the wings quite quickly. I know of a C-130 that ditched and it filled up with water really quickly and only the wings and top of the fuselage were slightly above water level. Some of the crew survived only because of the escape hatches on the top of the fuselage.
cfalk
Sat Oct 18, 2003 11:29 pm
Photo © Wouter Sikkema
Photo © Bob Smart
Charles
yqfca
Sun Oct 19, 2003 12:11 am
The only jet that successfully ditched in the ocean without breaking up was a DC9.
FrequentFlyKid
Sun Oct 19, 2003 12:37 am
Of course a BAe-146 would have fewer fatalities than a 767! It holds less passengers.  Big grin
LambertMan
Sun Oct 19, 2003 12:53 am
Would someone post a link to the video of the Ethiopian plane? I know I've seen it somewhere. It would be very much appreciated. Big thumbs up
EGGD
Sun Oct 19, 2003 1:05 am
Yeah, I think it was the DC9 (or maybe Fokker 100) that tried to land at SXM, but couldn't, diverted, and eventually ran out of fuel and ditched.
The pilot was at fault for allowing the a/c to run out of fuel anyway, but his ditching was faultless. I think the only reason why there were any fatalities is because a)the crew were so calm the passengers didn't realize the seriousness of the situation and weren't all in their seats when the aircraft hit the water and b)one of the life rafts inflated in the aircraft blocking quite a few peoples exits...
ardian
Sun Oct 19, 2003 1:06 am
And a link to the video of the CI-crash, if possible.
Grtnz, Doug
VS340
Sun Oct 19, 2003 3:15 am
