Howdy
Calculating Distance Between Two Airports?
Thu Nov 13, 2003 8:32 am
IS there a Web site which would give me distance between two airports?
ManchesterMAN
RE: Calculating Distance Between Two Airports?
Thu Nov 13, 2003 8:48 am
Flown: A300,A319,A320,A321,A330,A340.A380,717,727,737,747,757,767,777,DC9,DC10,MD11,MD80,F100,F50,ERJ,E190,CRJ,BAe146,Da
USAFHummer
Thu Nov 13, 2003 8:50 am
http://gc.kls2.com is the URL for the legendary Great Circle Mapper which is also an effective means of finding distance...
Greg
timz
Thu Nov 13, 2003 10:40 am
Notice that the first site says 8417 km from BOS to SCL, while the second one says 8388. Like a lot of sites, the first one apparently assumes a spherical earth. Best stick with kls2.
DL328
Thu Nov 13, 2003 12:14 pm
Try airnav.com as well, find a starting airport and then on the right column you should be able to put in another airport and find the distance.
Howdy
Fri Nov 14, 2003 6:33 am
I tried airnav.com and not sure how it works. Thanks for the responses.
