svenvdm
No Flaps Set In This Photo Of A300 Takeoff?
Thu Nov 13, 2003 9:47 pm
It looks like no flaps are set for take-off in the following photo. Shouldn't they be extended for takeoff?
Photo © THAI SPOTTERS
Coincidentally I've experienced this type of TG A300 t/o at BKK myself and it also looked like no flaps were extended.
AJ
RE: No Flaps Set In This Photo Of A300 Takeoff?
Thu Nov 13, 2003 9:50 pm
Hi SvenvdM,
Exactly this topic with the same photo was discussed a week ago in the tech/ops forum, that should answer your question:
http://www.airliners.net/discussions/tech_ops/read.main/72538/4/
Cheers!
swissgabe
Thu Nov 13, 2003 9:52 pm
Correct me if I'm wrong (I don't have any technical knowledge of this issue).
But if there is a lot of wind and/or the plane doesn't have a heavy load it might be possible that the captain didn't set any flaps.
Smooth as silk - Royal Orchid Service /// Suid-Afrikaanse Lugdiens - Springbok
upsmd11
Thu Nov 13, 2003 11:13 pm
If I were sitting behind the wing and noticed this I would be a bit scared. After the M80 crash in DTW where the NW crew didn't follow proper cabin procedure and the flaps and slats weren't extended I always watch the flaps/slats. I'm not a pilot nor qualified to know if they should be set but most of the time they are.
John
LBA
Fri Nov 14, 2003 1:18 am
Its common practice - the A300s I've been on have never used flap when leaving Bahrain.
Ryanair737
Fri Nov 14, 2003 1:31 am
Its also common practise on the Fokker 70/100.
Photo © ARN Photography - Joakim Ewenson
Photo © Bruce Leibowitz
Ryanair737
LAST FLIGHTS= Ryanair LPL-BGY-LPL - EI-DPS/DWV - MAY 08 // NEXT FLIGHTS= TBC
