N860DA
DAL Pulls 777 Service Out Of CVG
Fri Nov 14, 2003 9:40 am
Delta has pulled B772 service ouf of CVG in favor of B673s for trans-Atlantic flights. Does anybody have the inside scoop on what was behind this move? There was nothing like watching one of those babies rotate off the runway. I will surely miss that all-to-familiar low growl of the Trent 892 engines overhead too.
N860DA
MSYtristar
RE: DAL Pulls 777 Service Out Of CVG
Fri Nov 14, 2003 9:43 am
Delta always shuffles equipment around to meet capacity needs at various times throughout the year. I'm sure the 777 will be back at CVG at some point, but the 763's are probably an overall better fit for the market.
Steve in New Orleans
ramerinianair
Fri Nov 14, 2003 10:03 am
Will that be the case MSYtristar? From JFK almost all the Trans-Atlantic aircraft are 767-300ER's. I like DL but BA has a better deal. Better service in Y class and J class is cheaper with a full reclinable flat bed. Aybody know if this will change, I want to fly DL overseas but their service Trans-Atlantic is not at the top when other offer 777's and 747's with PTV's?
W N = my Worst Nightmare!!!!!
CALMSP
Fri Nov 14, 2003 10:23 am
Well then I would suggest flying CO. You still get your onepass miles, and you can still get your private tv!!
deltabobo
Fri Nov 14, 2003 10:28 am
You might get SkyMiles on that flight too, you never know!!!!!
Dispatchers...saving pilots from themselves and their egos since 1938!
B4REAL
Fri Nov 14, 2003 10:54 am
This is not to be a surprise.
DL's 7 or 8 777s will be effectively minus 2 for the traditional routes, as 2 a/c will be allocated for the ATL-NRT run, starting January 1. Also, soon a 777 will be on the ATL-LAX route.
This will be good for the CVG-CDG route as AF and DL can both operate their own flights, but having the CVG-FRA on a 777 was awesome, and for a while having a CDG and FRA flight on the 777 - two @ CVG was even better!!
Maybe in 2004 when they take delivery of some more 777, we will see it restored to CVG.
Frankly though, with the new FCO and AMS flights on 763, I am just thrilled for that. That has to be a factor in removing seats to Europe - as with the new flights in May, there will be a great jump with the 2 new routes.
b4real-keeping it real
behramjee
Fri Nov 14, 2003 11:11 am
Doesnt DL use B 772s for its JFK-LGW or JFK-CDG or JFK-FRA flights? If not Im surprised, as there is enough demand to warrant the B 772 of theirs plus this aircraft has a superior inflight product than its B 763ERs!!!
sebwhite
Fri Nov 14, 2003 11:21 am
Delta does not operate JFK-LGW.
ConcordeBoy
Fri Nov 14, 2003 11:35 am
They currently have a total of 8, and three will be devoted to Asia.
The reason for the pullout was to centralize all remaining 777 ops to Atlanta.
worldtraveler
Fri Nov 14, 2003 11:47 am
CVG is gaining two new destinations next year making it one of only a handful of cities that have that many or more transatlantic destinations and by far the smallest city with that many transatlantic flights.
777's aren't needed in the winter and the switch to the 777 for NRT means they need to be more centralized. DL has only 8 large int'l widebodies after Dec 31, by far the lowest of any int'l airline anywhere. Unless the MD-11's come back, until a few more 777's join the fleet, or Delta takes delivery of the 7E7 (probably a good bet), the 767-300ER will be what you'll fly on Delta internationally.
ramerinianair
Fri Nov 14, 2003 11:54 am
Behramjee, Delta serves on MXP with an MD-11 and soon to be a 772, all the rest have 763ER service.
Fri Nov 14, 2003 4:23 pm
Delta is not taking any deliveries in 2004; they will take delivery of two 777s in 2005.
I don't see DL bringing back 777s to CVG anytime soon if ever. Much more cost effective like ConcordeBoy was saying, by concentrating all 777 crews to ATL. More traffic from there too than CVG on most routes.
DL WIDGET HEAD
Fri Nov 14, 2003 4:54 pm
As strange as it sounds...it takes 3 a/c to operate the ATL-NRT route daily.
ConcordeBoy
Sat Nov 15, 2003 3:25 am
It only takes two to complete the route daily
Just that the third Pacific-configured bird will be retained for a spare as well as possible maintenance rotation
rockyracoon
Sat Nov 15, 2003 4:01 am
AF picked up the slack, now they are flying a A340-300 in daily instead of the A330-200. So it kinda balances out with DL downgrading to a 767-300. I miss the tripple 7 too, but an AF A340-300 is a nice site a CVG too.
Tim
Airports: CVG PIT MWO PHL PIT PHX ORD DCA MIA TPA MCO ATL DTW DFW SJC LAX DEN SLC LAS HNL LIH OGG YVR MUC ICN NRT PVG SHA SZX MNL PPS CRK BKK DMK KBV EOH MDE CLO CTG SMR BOG ACD MEX CUN MID
Sat Nov 15, 2003 12:40 pm
Just that the third Pacific-configured bird will be retained for a spare as well as possible maintenance rotation.
ConcordeBoy,
No, the route requires three aircraft. Once the B777 take over ATL-NRT, the third aircraft will do an ATL-LAX turn. An additional aircraft will remain as an operational spare.
BTW, check out the occuptation of the person who made that statement - I wouldn't be arguing with him  Big grin.
DL WIDGET HEAD
Sat Nov 15, 2003 1:18 pm
Concordeboy, You're wrong. It takes 3. Just do the math.
Sun Nov 16, 2003 5:10 am
Oh man, say it again! That sounds so good!
(just kidding, ConcordeBoy  Big grin )
ConcordeBoy
Sun Nov 16, 2003 5:19 am
(Reply #13)
ConcordeBoy,
IP,
maybe you're getting senile in your old age, but you "corrected" me only to repeat what I'd already said
*slap*  Laugh out loud
