H. Simpson
Can DC-10-30 Do Nonstop LAX-NRT?
Mon Nov 24, 2003 11:01 pm
I'm just curious...can a DC-10 fly from LAX-NRT nonstop? How about SEA-NRT?
TR
RE: Can DC-10-30 Do Nonstop LAX-NRT?
Mon Nov 24, 2003 11:20 pm
Distance between LAX and NRT is not even 9000 kms so it should be possible for a DC-10 to cover that route. Guess SEA to NRT is quite a bit shorter so that should be possible without any problems.
JAL
Mon Nov 24, 2003 11:27 pm
It should be possible, I do know that Canadian Airlines used to operate DC10-30s from Vancouver to Tokyo.
Work Hard But Play Harder
sebwhite
Tue Nov 25, 2003 12:04 am
NW has operated SEA-NRT on a DC-10.
Jetmarc
Tue Nov 25, 2003 12:09 am
In fact, NW currently flies SFO-NRT with a DC10...
"Sucka, I'm gonna send you out on Knuckle Airlines. Fist Class!!" ~ Mr. T
gigneil
Tue Nov 25, 2003 12:31 am
LAX-NRT is perfectly doable with a DC-10-30. The DC-10-30's range of about 5900 nm works fine for that route.
M
mandala499
Tue Nov 25, 2003 1:14 am
In the 80s I flew HKG-SEA, so NRT-LAX shouldn't be a problem!
Mandala499
gigneil
Tue Nov 25, 2003 1:18 am
Nonstop HKG-SEA is starting to really push up against the envelope, especially considering DL used their two longest ranged MD-11s for PDX-HKG.
N
dutchjet
Tue Nov 25, 2003 2:01 am
NW did use the DC-10-30 for the SEA-HKG nonstop run in the mid 1990s without any real issues, but I am not sure if that flight carried much cargo in addition to pax.
To my knowledge, DL did not fly PDX-HKG nonstop ever, with any aircraft type.......DL did operate LAX-HKG, first with the L1011-500 with a fuel stop in ANC, and then nonstop with the MD11.
Bobs89irocz
Tue Nov 25, 2003 2:08 am
Didnt even know Delta flew to HKG.....wow.
Did Delta's MD-11's have the 2 ox tanks in the forward cargo area for extended range? If so you dont see many of those around, i know swiss doesnt us them and use the MD-11 from zurich-O'hare.
rb211
Tue Nov 25, 2003 2:14 am
Yes, for a brief moment, Delta did fly to HKG. In the beginning they flew the L-1011-500's and then switched to the MD-11.
Airline photography. Whether they're fully clothed, butt naked, having issues or confused I'm taking pictures!!
Kempa
Tue Nov 25, 2003 2:16 am
Didn't Varig use DC-10-30s to fly between LAX and NRT?
cdgdtw
Tue Nov 25, 2003 2:28 am
NW does NOT operate SEA-NRT with a Dc10. SFO-NRT is the only TPAC route with DC10 aircraft. SEA is still and will continue to fly a 747-200 until the arrival of 330-200. DL used MD11 aircraft for PDX-Asia destinations.
cpharris5514
Tue Nov 25, 2003 2:37 am
NW also flies a DC-10 nonstop daily SEA-AMS, which, as the crow flies looking at the globe, is a similar distance. NW also used to fly one SEA-KIX.
From rural Carlisle, Iowa
H. Simpson
Tue Nov 25, 2003 3:06 am
DL used MD-11 on routes from LAX-HKG, in fact they send a MD-88 once to HKG...anyone know why?
B747-4U3
Tue Nov 25, 2003 3:13 am
Varig used DC10s to London, I guess that is similar in distance to LAX.
ConcordeBoy
Tue Nov 25, 2003 4:38 am
Delta never flew that route.
L15s flew LAX-ANC-HKG
M11s flew LAX-HKG nonstop
Just to add... it was Kai Tak they flew to. DL has never offered service to Chek Lap Kok.
Photo © Colin Parker
Photo © Gary Watt
