747-600X
4 Quiz Questions
Sun Jan 09, 2000 1:47 pm
1) What is the fastest subsonic jetliner?
2) What Boeing jetliner flew as a testbed with 5 engines?
3) What are each of the following:
E-3
E-4
E-6
4) What will the length of the A318 be?
RE: 4 Quiz Questions
Sun Jan 09, 2000 6:59 pm
The fastest subsonic jetliner is the Convair 990. However, the DC-8 was the first supersonic commercial jetliner when it reached mach 1.012 on a dive over California on a test flight in the early 60s.
The four engined airline that flew with five engine was a testbed Boeing 707 for an engine manufacturer (I forget which) with a fifth engine mounted on a horizontal strut off the right hand side of the nose.
(If this isn't the answer you wanted, its still an answer!)
E-3 is a Boeing 707 with a radome on the top.
E-4 is a twin turboprop engine carrier-based radome-equipped airliner.
E-6 is a 767 for the Japanese Air Force used in the same way as the E-3 for the USAF. (not always equipped with a radome)
The length of the A318 will be..... even shorter than the A319??????
DLMD-11.
ravi
Sun Jan 09, 2000 8:12 pm
1. Convair 990 (out-of-production). Boeing B747-400 (in-production).
2. The Dash-80 once flew with a fifth engine on the rear of the fuselage as a trial for the B727 engine arrangement. The B747 has also flown with 4 JT9Ds and 1 CFM56. I also suspect that a B707 has flown as a testbed with a fifth engine for PW.
3. E-3 = B707 AWACS; E-4 = B747-200 Advanced Airborne Command Post; E-6 = B707-320 TACAMO.
4. Too damned short. 31.4m.
Glenn
Sun Jan 09, 2000 8:16 pm
I will agree with most of what you said but isn't an E4 a USSAF 747
ravi
Sun Jan 09, 2000 8:57 pm
Yes the E-4 is in service with the USAF, but is known as the Advanced Airborne Command Post. This is fancy slang for "the President rides this baby when he needs to go somewhere or a war starts".
TWA902fly
Mon Jan 10, 2000 11:04 am
I only know the first one, A319
life wasn't worth the balance, or the crumpled paper it was written on
