PBIflyguy
Song/Delta
Fri Dec 05, 2003 12:35 am
I'm curious as to how DL will be replacing mainline 757s as they get refit and sent over to Song. Will Song be purchasing used aircraft or expanding its fleet solely with aircraft taken from DL's mainline fleet? If that is the case, what will DL replace the 757s with? Are they a potential customer for the 739?
Any thoughts?
luv2fly
RE: Song/Delta
Fri Dec 05, 2003 1:13 am
Well since Song is doing more and more flying and replacing DL on some routes then I think they balance themselves out, right now at least.
ssides
RE: Song/Delta
Fri Dec 05, 2003 1:17 am
Plus, DL isn't shifting all of its 757s to Song, right?
"Lose" is not spelled with two o's!!!!
luv2fly
RE: Song/Delta
Fri Dec 05, 2003 1:20 am
I thought I read that the Song fleet will be roughly 35+ aircraft in the fleet. Well I also read that Song would not be operating to and from ATL and we saw how long that lasted.
rockyracoon
RE: Song/Delta
Fri Dec 05, 2003 1:23 am
Luv2fly, do know anytihng about the JFK-ATL flight as to what the reasoning was/is? It seems crazy to me and I don't get it. Thanks
Tim
Airports: CVG PIT MWO PHL PIT PHX ORD DCA MIA TPA MCO ATL DTW DFW SJC LAX DEN SLC LAS HNL LIH OGG YVR MUC ICN NRT PVG SHA SZX MNL PPS CRK BKK DMK KBV EOH MDE CLO CTG SMR BOG ACD MEX CUN MID
DL685
RE: Song/Delta
Fri Dec 05, 2003 1:24 am
Song pretty much operated to and from ATL just for crew rotations and mtc issues with starting the ops up.
MSYtristar
RE: Song/Delta
Fri Dec 05, 2003 1:27 am
Many former Delta mainline 757 flights have been replaced by MD-88 and 737-800 aircraft. Likewise, quite a few former M88/738 flights out of ATL/CVG have been replaced by the 737-200's, which have been refitted for mainline operations. Some routes have seen decreases in capacity due to the equipment swaps.
Stephen/New Orleans
PBIflyguy
RE: Song/Delta
Fri Dec 05, 2003 1:31 am
Luv2fly....... I was thinking along the same line as you about the "balancing" act.... DL's flights will increase a little and Song's will increase equally.. but.. look at some of the pairings that Song is flying..... FLL-LAX , FLL-LAS. These are new, not existing routes that DL already flew. Obviously some new planes had to come into the fleet to operate these flights. Who knows what new pairs they will come up with as they expand.
DL685
RE: Song/Delta
Fri Dec 05, 2003 1:43 am
Song looks like it is doing fairly well. Here are some stats...........
These are all numbers for the month of November only :
Ontime - 86.2%
Passengers - 573,861
Total flights - 4138
Flights cancelled - 0.2%
The total seats available for the month of Nov. system wide was 823,462 and they filled 573,861 of those for a 70% LF
scottysair
RE: Song/Delta
Fri Dec 05, 2003 2:13 am
DL685,
Where did you get woth those flight status on their Song? Can you tell me about where did you even find one of pages for me? The load factors are pretty high on these flight from Florida to New York - JFK, LGA, & EWR. What are you about need added more expansion of Song out of FLL anytime soon? Thanks!  Smile
Iflewrepublic
RE: Song/Delta
Fri Dec 05, 2003 4:17 am
I wonder how long it will be until we see Song Domestic and Delta International.
"Welcome aboard Delta's Song..."
Iflewrepublic.
Aviation is proof that, given the will, we have the capacity to achieve the impossible.
