VS340
Westjet Aircraft Plunges 20,000 Feet In A Minute
Sun Dec 07, 2003 1:45 pm
I came across this article today in the Edmonto Sun http://www.canoe.ca/EdmontonNews/es.es-12-06-0003.html
CALGARY -- A minute-long nosedive by a plane which left Calgary International Airport had a Cochrane man praying for his life.
The Winnipeg-bound WestJet flight descended almost 6,100 metres (20,000 feet) in a one-minute span after encountering problems about 20 minutes after taking off from Calgary. The aircraft has since been taken out of service.
The plane plunged from a near-cruising altitude to 2,440 metres (8,000 feet) - dropping the aircraft's air masks from overhead compartments - before recovering and returning to Calgary.
"I felt the G-forces on my stomach, my chest ... all over my body," said John Perry, a Cochrane salesman and a passenger on Monday's flight.
"It took us 20 minutes to get up to more than 25,000 feet (7,620 metres) and only about one minute to come down."
Perry, a father of three- and five-year-olds, said the experience left him "making peace with God."
"I thought, 'Please forgive my sins' and 'look after my family,' " said Perry, who was flying to Winnipeg to visit a friend when the plane started to plummet.
He described the atmosphere as "eerie" and "surreal."
"But no one knew anything ... even the (flight attendants) didn't know what was going on."
Perry said most passengers turned to quiet reflection as the plane continued to drop.
"In the movies, you always hear people screaming and crying, but here it was so quiet you could hear a pin drop," said Perry.
A stiff 180-degree turn also added to the concern of the passengers, he said.
Once the aircraft stopped its dive, Perry said the captain explained the plane had fallen victim to a pressurization problem but had levelled off at 2,440 metres.
When the plane recovered from the plunge, it was forced to return to the airport, where passengers were transferred to another aircraft.
That plane was taken out of service in Calgary and a replacement aircraft was brought in, said a WestJet official who asked not to be identified. Passengers were reloaded onto the waiting plane and carried on to Winnipeg.
WestJet couldn't offer any details relating to the incident or what caused the plane to aggressively lose altitude.
Does anyon know anything further about this incident?
N79969
RE: Westjet Aircraft Plunges 20,000 Feet In A Minute
Sun Dec 07, 2003 1:54 pm
These numbers (either the duration of the emergency descent or the amount of descent) do not sound right.
This sounds like the media and understandably terrified passengers exaggerating what was a dramatic event. (e.g. use of the word "nosedive")
The airspeed required to descend 20,000 feet in a minute has got to be very high and is probably more than enough to overstress a transport airplane.
If anyone reads more, please post it.
flyf15
Sun Dec 07, 2003 2:01 pm
Sounds like they have they have some things confused.
Sounds like the aircraft had a depressuization and there was a pilot initiated, controlled (although very fast) descent. I can see how the passengers would've thought the plane was going to crash and would've been very fearful, but there is no reason to report it like it was going to crash and just make a one sentence mention of the real problem (much less explain what was going on).
LN-MOW
Sun Dec 07, 2003 2:02 pm
Doesn't sound like the plane was out of control, but merely a precautinary rapid decent due to a pressurisation problem ...
Dramatic for the passengers, but not dangerous. If the cabin pressure drops, the aircraft must decend to below 10.000 ft as quick as possible. However it sounds like the pilots could have done a better job explaining this to the passengers once the situation was stabilized.
- I am LN-MOW, and I approve this message.
flyingbronco05
Sun Dec 07, 2003 2:07 pm
Can somebody figure this out?
If a plane dove 20,000 ft in one minute, what was the angle of that dive.
It, to me, seems impossible unless it was straight down.
When you climb, the angle is about 6 degrees in most jets (plus or minus a few degrees) and they are climbing between 1500 and 3000 feet a min.
Any help would be appreciated.
FB05
Never Trust Your Fuel Gauge
yyz717
Sun Dec 07, 2003 2:09 pm
Was it a 732 or 73G?
I dumped at the gybe mark in strong winds when I looked up at a Porter Q400 on finals. Can't stop spotting.
flyf15
Sun Dec 07, 2003 2:12 pm
20000fpm down is a vertical speed of 198kts. This would equate to a 45 degree nose down pitch if the aircraft were travelling 279kts, or a 30 degree nose down pitch if the aircraft were traveling 396kts.
[Edited 2003-12-07 06:16:41]
CanadaEH
No comment by Westjet yet. The numbers sound a little exaggerated to me, 20K ft in a minute? Says who? Expect details on Monday.
EH.
pilottim747
Sun Dec 07, 2003 2:14 pm
I'm with you N79969.
There is now way that this plane could descent 20,000 ft in one minute. Maybe it seemed like a minute to a passenger or the media played it up a little. It sounds like a rapid decompression descent.
pilottim747
Aviation Photographers & Enthusiasts--Coordinate your life.
VS340
Sun Dec 07, 2003 2:20 pm
yah it seemed very strange to me when i first read it, i can understand dropping the plane to a safe altitude as fast as u can when a pressurization problem occurs, but the way this article makes it sound is that a sudden pressurization problem caused the plane to fall 20000 ft.
I guess it can be attributed to ignorance on the part of passengers and the media. I just wish the media would get things right in the first place because making a huge deal out of a problem that may not be that big in the first place makes an airline and the aircraft manufacturer look really bad when they both are known for good reputations.
a330marcus
Sun Dec 07, 2003 2:25 pm
What can cause a pressurization problem?
miles_mechanic
yeah to me it sounds like it was a bit exaggerated also. I do know that when you are up at the normal cruising altitude of 30,000+ that if you loose pressurization that you only have about 5 to 8 seconds to get your oxygen mask on or you will pass out. I learned that from a training course, of course the lower you are the longer you have. Everyone remember the Payne Stewart Learjet incident from a few years ago. That is why when 1 pilot leaves the cockpit of the aircraft the other pilot is supposed to have his oxygen mask on his head, or at least in the company I worked for they had to do that.
N79969
Sun Dec 07, 2003 2:26 pm
Flyf15,
Those calculations you did make the airspeeds seem almost doable (but not the pitch).
Can a transport airplane safely descend at 279 kts constant-speed with that much nose-down pitch? My own intuition (and limited hours in a Cessna) makes me think 'no.' But I do not know the true answer.
FrequentFlyKid
Sun Dec 07, 2003 2:28 pm
If they descended 20,000 feet in one minute that means that they would have travelled 1,200,000 in one hour. That equates to roughly 213 miles per hour. However, that's on a vertical axis and obviously the plane wasn't in a vertical dive. So either that plane was doing over 400 miles per hour at a 45* down pitch or the numbers are incorrect.
mog
Sun Dec 07, 2003 2:37 pm
Would something like this be done on manual or would the auto-pilot and other avionics take over? Hmmmmm . . .
wjv04
Sun Dec 07, 2003 2:44 pm
I belive i saw this flight, i was starting my shift at the airport about 8am, and went out for a smoke with my crew awaiting the emery 727 to come in (im a cargo ramper at yyc), and all the fire trucks were waiting on the runway for some reason. But at the same time we saw a America west taxi down, do a 180 and went back to the terminal so we assumed it was this. However we never bothered to see what it was...
im assuming after hearing the story it was the westjet. But like i said our plane came in and we never heard anything about it.
I belive this is total media bullcrap, I mean if a plane were to "nose dive" and loose 20000 feet, im really sure the captain would be able to pull it out of the the dive without ripping the wings off. Its sad really, I mean it was a text book cabin depressurization checklist desent with a turn back to Calgary. But the general public will never hear that. And now WestJets public image is tainted.
I think im gonna stop watching the news period.
[Edited 2003-12-07 07:01:28]
Goose
Sun Dec 07, 2003 2:54 pm
If it was a pax saying they had decended 20K feet, then I might suggest that his sense of distance might be somewhat skewed. He has no idea what altitude he's at, aside from what he can tell from looking out the window - not a great measure of distance.
And how did he have the presence of mind to time the event - giving us the one minute decent? Hrm, sounds funny.....
"Talk to me, Goose..."
XFSUgimpLB41X
Sun Dec 07, 2003 3:07 pm
"Can a transport airplane safely descend at 279 kts constant-speed with that much nose-down pitch? My own intuition (and limited hours in a Cessna) makes me think 'no.' But I do not know the true answer."
In a word... no.... Jets are way too slippery. You'll be dropping like a rock, just not 20,000 feet a minute. Nor did they drop 20,000 feet... in a minute. A 10,000 fpm descent is not out of the question for a short while, even a bit higher than that....but it is unsustainable as the aircraft would go supersonic and have structural failure. Here is what happens:
Emergency descent procedure: oxygen masks-don and 100%...establish communication, no smoking seat belt sign on...twist the altitude knob to a lower altitude, set a IAS descent down at Vmo or Mmo (335 knots or .85 Mach in the CRJ- varies from bird to bird, the 737 is a bit slower), thrust levers idle, flight spoilers extend...F/O declares and emergency and gets permission for lowest safe altitude or 10,000 feet after strapping on his mask.
This manuever was obviously an emergency descent....and another unfortunate misconception from the news media by not asking the right people. Its amazing how little people know when they think they know alot.
[Edited 2003-12-07 07:11:12]
Chicks dig winglets.
PiedmontGirl
Sun Dec 07, 2003 3:25 pm
XFSUgimpLB41X:
I'm with you. This sounds like a rapid decompression and the crew made a very controlled emergency descent.
I've been through decompressions and this is what it's like.
For those folks who think the Captain should have made a better announcement: Right then he is concerned with getting his bird safely on the ground. He is a busy as a one armed paper hanger and does not have any time for public relations right then.
The announcement he did make was primarily to let the flight attendants know that the rapid descent was over, that it was a descent following a decompression, and that it was safe to move about without a mask and take care of their passengers.
And, as someone else, noted the pilots at the carrier he worked for were required to wear the oxygen mask if one of them left the cockpit. That's the way it was at mine, too. I think that's probably pretty universal.
BO__einG
Sun Dec 07, 2003 5:13 pm
I was at the airport for a few hours today spotting. Maybe I may of spotted that plane land and took a picture of it.??
My spotting time was from 11:30-1pm..
Was that Winnipeg flight departed/arrive around that area?
Good to hear that all is safe at the end. A close call for WestJet indeed but the crews acted professionaly and followed all guidelines for such an emergency. Well Done!
Follow @kimbo_snaps on Instagram or bokimon- on Flickr to see more pics of me and my travels.
elwood64151
Sun Dec 07, 2003 11:45 pm
Let's see... 20,000 in 60 seconds is something like 4 miles a minute...
Sorry to disagree with *everyone's* math, but:
Actually, it would be 227.27 mph. I am sure, however, that the aircraft was not in a dive for exactly sixty seconds. It may have been shorter or longer.
For example, if the aircraft had been in a dive for 80 seconds, the vertical airspeed would have been 900,000 feet per hour, or about 170.45 mph. In a 90 second dive, 800,000 feet per hour, or 150 mph.
So let's say it took just over a minute: 70 seconds. That equates to a vertical airspeed of just over 1,000,000 feet per second, or about 194 mph (approximately the same speed that Flyf15 posted earlier).
This means that (and my geometry and physics are a little rusty), travelling at 274 mph (or about 238 kts), the aircraft must be in a 45 degree dive (it travels one foot down for every foot forward, so travelling 194 mph forward and 194 mph downward makes a velocity vector of 274 mph). At at 30 degree angle, it must be travelling at approximately 349 mph (appx 303 kts).
The math is actually quite simple. It's basically Euclidean Geometry: Vertical speed (squared) plus horizontal speed (squared), and take the square root of the result, assuming no accelleration.
So even if the aircraft fell like a stone, I think this is well within a 737's flight envelope, even if it is a bit dangerous.
Given: Hypotenuse of a traingle: c= sqrt(a^2 +b^2)
One mile: 5280 ft
One nautical mile: 6076 ft
One minute: 60 sec
One hour: 3600 sec
For a graphic representation, e-mail me.
Those who fail to learn history are doomed to repeat it in summer school.
AWspicious
Mon Dec 08, 2003 2:23 am
Here we go again, folks...  Yeah sure
Not exactly the kind of calm attitude you'd expect to find during a minute-long nose dive, is it...
I sense media/passenger over-sensationalism at work, here. (ie: cough cough*bullshit*cough cough).
The aviation industry has been battered enough. Why is it, the media (and some people) scrutinize airlines under a microscope then run around making claims about their careless and fallacious findings?!!!
How the hell did he know this?! Did he have one of them there new fangled ACME all-in-one scanner/altimeter/stop-watch gadgets that's all the rage, and a must have for every airplane passenger and wanna-be aviation enthusiasts?!?! This isn't one of you guys in here, is it?!!
Sheesh... For the kind of bad publicity caused by stories like this, people like him should ride the bus.
A.W.
Nevermind political correctness - Envision using your turn signals!
EZYAirbus
Mon Dec 08, 2003 2:51 am
You guys all aviation experts? seems to me you lot calling westjet officials liers!
Glenn
http://www.glenneldridgeaviation.com
VS340
Mon Dec 08, 2003 3:04 am
Nobody is calling Westjet officials liars because the Westjet Officials never made any comment other than
"That plane was taken out of service in Calgary and a replacement aircraft was brought in, said a WestJet official who asked not to be identified. Passengers were reloaded onto the waiting plane and carried on to Winnipeg"
This whole story was based on the account of 1 passenger who is obviously not an expert.
The media is the liar here, sensationalizing something that isnt all that sensational and basing their entire story on the account of a single passenger
CanadaEH
Mon Dec 08, 2003 3:07 am
A Winnipeg-bound WestJet Boeing 737 had to abort its journey and return to Calgary last week after an air conditioning unit malfunctioned, causing the airplane to slowly lose cabin pressure.
Officials said the matter prompted the crew to put the plane into a steady, eight-degree descent, returning to Calgary without incident last Monday.
A commercial plane typically lands with a descent of about three degrees.
Clive Beddoe, WestJet's chief executive, said there was never a danger and bristled at a media report of a "nosedive" that alleged a plunge of 5,100 metres in only a minute.
Tim Morgan, the airline's senior vice-president of operations, said the descent would have lasted at least three or four minutes, adding the manoeuvre was a standard process in such a situation.
He said WestJet had experienced a similar incident once before.
"It's certainly something you would not normally experience, but you're not hanging from your seat-belt heading towards the ground," he said. "It was by no means dangerous."
Morgan said the air conditioning unit was fixed and the airplane is flying again.
There you go.
EH.
LN-MOW
Mon Dec 08, 2003 3:13 am
A gentleman in Mexico sent me the following via email:
''I often read airliners.net forums and this one seems interesting... However, I never write to any of them... This time I wanted to share some data regarding this event about this aircraft plunging 20k in 1 minute... I have performed several emergency descents during trainning in different types of planes... B727,DC10,A320,B757/767 and F100... Due to the aerodynamics of F100 during this maneouvre, I got the best rate of descent in Mexican airspace about 10 years ago, dropping from FL330 to 14000ft. at an average of 12000fpm, and Mmo/Vmo... (speedbrake out, landing gear retracteed). 20K in one minute makes no sense to me... Hope this helps to the topic... ''
sllevin
Mon Dec 08, 2003 3:19 am
All this said, you CAN get a pretty doggone rate of descent once you roll to get the lift vector off vertical. Check our skydive operations -- a lot of times, from 12,000', the planes beat the divers back to the ground!
They probably had a pitch down of 20 degrees. For someone inside, it probably felt like a vertical dive. I've done the reverse -- been in a lightly-loaded Lear 24 and in a 20 degree pitch up -- and from a sensation standpoint, you feel like you're lying on your back (i.e., vertical).
Steve
OPNLguy
Mon Dec 08, 2003 4:09 am
The original media story (presumably originating in Calgary, and carried elsewhere) highlights a problem in covering in fast-breaking stories, that is, the occasional media tendency to attribute too much credibility and accuracy to "eyewitnesses", in this case the passenger quoted. There is no doubt that the gentleman passenger could speak authoritatively on his emotional experiences on the flight since he was "there", but assuming the passenger's credibility extends into the more technical areas of the hows and whys of the underlying event is a big assumption, and this case a big wrong one.
I understand the media has a job to do, and works on deadlines, but I think it would have been a better example of responsible journalism to have run some of the passenger's statements through a "reasonableness" check before publication. Yeah, now that immediateness of the event has past, they could theortically run a retraction (ha!) or a clarifying story, but it'd be buried on page 33Z, and reach about 1% of the folks who saw the original one (and will still will run around thinking that Westjet dived 20,000 feet in one minute).
And all this was over an outflow valve and depressurization? Makes you wonder how'd they cover a blown tire, bird strike, or aborted takeoff...
I think I'll second Wjv04's statement and just quit watching the news, period...  Big grin
VS340
Mon Dec 08, 2003 4:26 am
recently there was an incident at YEG where there was thought to be a chemical spill inside the pit of a plane. It turned out to be a bottle of hair spray that broke open. Of course the media jumped all over the idea of a chemical spill, claiming that there were injuries and people going to the hospital, I was there working that flight and i can tell you that nothing came of it. Of course the media never changed the story or wrote a retraction.
OPNLguy
Mon Dec 08, 2003 4:37 am
Oh brother... Maybe the next time YYC fogs in they'll report it was a chemtrail attack by UFOs...  Big grin
I'd love to know where the original story re: the supposed 20,000 foot death dive originated...
USAFHummer
Mon Dec 08, 2003 4:52 am
"Did he have one of them there new fangled ACME all-in-one scanner/altimeter/stop-watch gadgets" -since this was a pressurized airliner, an altimeter such as that will show the cabin altitude (based on the pressurization of the plane), not the plane's actual altitude...therefore it would be of no value to determining the plane's altitude...they generally take several seconds to get a readout so I highly doubt if he had one that his first reaction would be to check his altimeter...wastes too much time and is not necessary to survival...
Greg
OPNLguy
Mon Dec 08, 2003 5:01 am
Greg,
Everyone -knows- these Acme gadgets never work. I mean, they never seem to for Wile E. Coyote......  Big grin
FrequentFlyKid
Mon Dec 08, 2003 5:41 am
...smartass
Goose
Mon Dec 08, 2003 6:07 am
As a matter of fact....
WS has experienced two blown tires in as many months. The first one was, if I recall, on takeoff from YLW.... and they overflew YYC with the gear down so that the WS mechanics could take a look - it wasn't that bad, and the aircraft landed safely with no injuries; but the YYC emergency personnel were on-hand just in case. They don't get to ride around in their fire trucks with the sirens on out here that often, I suppose.....
The incident got several pictures (some rather fuzzy) in the Calgary Sun and a few in the Herald as well; the Sun sensationalized it, making comments like "avoided disaster" and "could have been a bad accident," while the Herald played up the good work of the crew and the safe landing, pointing out that the fire trucks were a precautionary measure. It all depends on who's paper you read.... the Sun is a tabloid, the Herald is not.
CRJ 900
RE: Air Canada Questions
Mon Dec 08, 2003 7:24 am
Actually 14000ft is sufficient for an emergency decent. O2 levels are fine at this altitude. Further descents can be made after this initial loss of altitude. TUC(time of useful conciousness) at F140 in our manuals is stated as infinite.
Whiteguy
Mon Dec 08, 2003 7:40 am
This is funny, Westjet gets some bad press and everyone is all over the media for make it look worse than it really was. But when its about Air Canada its gotta be true. Funny how that works.
PiedmontGirl
Mon Dec 08, 2003 7:45 am
Whiteguy:
I wouldn't have matter to me if it had been Air Canada or some airline, I had never heard of, I would have thought the same thing: That it was a decompression that had been improperly reported by the press.
fallingeese
Mon Dec 08, 2003 10:58 am
The original story originated in the Calgary Sun on Saturday. In the Sunday issue of the Calgary Herald was a much more develloped version of the same story.
http://www.canada.com/search/story.aspx?id=74587baa-9c6c-4505-bc68-6c8a92a96a98
Mark McWhirter...Contrails Photography
AWspicious
Mon Dec 08, 2003 11:17 am
No one caught the reg# of this aircraft, yet?
A.W.
behramjee
Mon Dec 08, 2003 11:27 am
Once again the question is asked was it a Boeing 737-200 or Boeing 737-700 or -800?
a340pilot
Mon Dec 08, 2003 12:48 pm
Here is another incident that happened to westjet, IM assuming that the media coverage would have said that it came within 12 feet of the ground or something to that effect!
Summary
WestJet Flight 35, a Boeing 737-200, serial number 20196, was en route from Calgary, Alberta, to Abbotsford, British Columbia, at about 1740 mountain daylight time. The aircraft climbed to the planned cruise altitude of flight level 310, at which time the auxiliary power unit was shut down. Within minutes, there was a loss of cabin pressurization. The aircraft descended and diverted to Kelowna, British Columbia. The passenger oxygen masks automatically deployed when the cabin altitude reached 14 000 feet above sea level. The cabin altitude subsequently reached about 24 000 feet above sea level before pressurization was re-initiated. The aircraft landed in Kelowna, without further incident, so the oxygen system could be serviced. No injuries were reported.
Here is the link for the entire write up: http://www.tsb.gc.ca/en/reports/air/2000/a00p0101/a00p0101.asp
a340pilot
Go! Canucks Go!
fallingeese
Mon Dec 08, 2003 12:52 pm
It was mentioned in the Calgary Herald article that something similar had happened once before. This case was a malfunctioning air conditioning unit.
redngold
Mon Dec 08, 2003 1:58 pm
If nobody else has posted this yet...
I would bet that there was some screaming and hollering. However, between the effect of rapid depressurization on the human ear and people putting on the masks, nobody could really hear the screaming.
redngold
Up, up and away!
CanadaEH
Mon Dec 08, 2003 2:02 pm
Who really cares? The plane landed safely, the pilots followed procedure, and the passengers got to their destionation [delayed].
EH.
Midway2AirTran
Mon Dec 08, 2003 2:14 pm
Gotta love the media and their stories. If passengers still got on the replacement aircraft, then I guess it couldn't have been that horrifying.
"Life is short, but your delay in ATL is not."
OPNLguy
Mon Dec 08, 2003 2:31 pm
About the only similarities between this earlier incident above and the more recent ones is that they both resulted in the "rubber jungle" effect, i.e. the masks dropped in the cabin, and that a emergency descent was initiated.
In the first incident, it would appear that someone forgot to reconfigure the bleeds after takeoff (APU bleed to engine bleed). This kind of mistake, rare as it is, has happened elsewhere, with similar results. It's not a fatal mistake--just one of those embarassing "oops" kind of mistakes that humans sometimes make.
In the latest incident, we don't know for sure (at this point) what caused it, and if I was a betting kinda guy, my hunch would be an outflow valve problem over a human mistake.
What's really funny is how that Calgary Sun article makes it sound like they're investigating why the aircraft dive occurred. Seems pretty clear that it was crew-initiated in response to the depressurization, but this reporter seems to think that the depressurization threw the aircraft into the dive. Idiots...
wjv04
Mon Dec 08, 2003 3:11 pm
We should write a letter to this guy, and let em have it.
BO__einG
Mon Dec 08, 2003 4:05 pm
In the Sunday Sun, there is a picture of the arrogant Cochrane Salesman guy.
But if I were to be a pax expereincing such a rapid descent, my ears would blow up! Unfortunetly for some reason my ears always hurts whenever there is a descent, whether it is in an airplane or in an elevator in Calgary Tower.
Oh and as for the flight. It was said to be #94, a -200 series which was used for the leg.
USAFHummer
Mon Dec 08, 2003 4:53 pm
OPNL - I actually have one of those altimeter watches...
Works pretty decently for me  Smile
Greg
Navigator
Tue Dec 09, 2003 3:42 pm
This was an emergency descent made by the pilots. The descent was probably in accordance with routines. This is normal procedure when planes encounter pressurization problems. The pilots did what they were supposed to do. There is really not much more to it...
747-400/747-200/L1011/DC-10/DC-9/DC-8/MD-80/MD90/A340/A330/A300/A310/A321/A320/A319/767/757/737/727/HS-121/CV990/CV440/S
