3lions
Rolls Royce, Pratt Or GE
Wed Dec 17, 2003 1:36 pm
Who do you think makes the best engines.
Please give your reasons.
[Edited 2003-12-17 05:39:12]
BA
RE: Rolls Royce, Pratt Or GE
Wed Dec 17, 2003 2:27 pm
I don't think there is one best. They all make equally good, successful, and high quality engines.
"Generosity is giving more than you can, and pride is taking less than you need." - Khalil Gibran
gigneil
Wed Dec 17, 2003 3:08 pm
Unfortunately this is an undiscussable topic. Nobody here is really qualified to give a business answer.
We can hear from mechanics about which is easiest to fix, and from pilots on which they prefer.
But its hard to decide a "best".
N
Southamerica
Wed Dec 17, 2003 3:15 pm
There are no best.
Every airline has its own perspective and preferences in order to maintain the correct economic standars through equality and adaption of the engine to the carrier's network.
If there eventually were a best, it would be very subjective.
Federico in SOUTHAMERICA
ContinentalFan
Wed Dec 17, 2003 4:39 pm
Dunno, seems like Pratt is falling behind the other two, just barely hanging on (relative failure of 409x on 777, having to team up w/ GE on GP7200, probably will be GE vs. RR for 7E7, PW6000 project, etc.). Almost seems they're not too serious about the commercial engine market :-(
brons2
Wed Dec 17, 2003 4:42 pm
I will agree with the previous poster, seems that PW is falling behind.
In addition to the things mentioned, the FAA has prodded PW to make improvements to the 40xx series due to a higher rate of IFSD than other engines in the same thrust class. And we all know about the well publicised initial failure of the PW6000. Time will tell if they are able to fix the 6000.
Firings, if well done, are good for employee morale.
wilcharl
Wed Dec 17, 2003 5:58 pm
they all turn and burn... all are certified to the same standards all turn fuel into power and heat... the JT-8D was a true workhorse u could have a compresser stall and keep on rolling with them, The rolls royce tay had its issues... The RB-211 had its problems... I think if you look at the statistics which would be the only immpartial thing, CFM has the best numbers for on wing time... lowest IFSDs and the best dispatch relaiblity. Plus its the #1 selling engine right now... So based on that i would say CFM makes the and i hate to use the word "best"
MD-11 forever
Wed Dec 17, 2003 7:55 pm
Wilcharl,
I agree with your opinion. I already ponted out in a similar thread in the Tech/Ops forum, that ther is NO "best" engine. There is just the "best" engine for a certain mission profile and operation environment, nothing more, nothing less in my opinion. But there are many parameters influencing this environment, like fleet usage, usage of take-off derates, fleet commonality (maintenance) and so on to take into consideration.
Regarding your statements concerning the CFM engine, I would like to add some comments (as it is my daily job to handle them in our shop). There are examples where CFM engines reached high amounts of on-wing time. Nevertheless, the CFM56-5C4 variant that powers the A340-300 is known to cause a lot of headache for the short on-wing time you can achieve usually. The parameters like IFSD and dispatch reliability are also widely varying between the different operators and engine models. What I just want to point out is, that also those CFM56 have a lot of technical issues that causes the maintenance and operation personnels a considerable amount of headache.
Cheers, Thomas
FutureFO
Fri Dec 19, 2003 9:54 am
As far as a personal favorite engine i prefer the RR RB211 that is on the L1011/757. As far a 777 Engine the RR Trent 90 is an awesome engine. And then of course there is the BR715 that is on the 717. I guess I am just a fan of the RR variants.
Sean from MCO
I Don't know where I am anymore
futureualpilot
Fri Dec 19, 2003 10:03 am
Its hard to say, they all make good engines, some are better suited for a certain type of aircraft than others. Maybe if you asked who made the best engine for a certain type of aircraft, this could be answered.
Personally I love how the RR engines sound on 757s.
Life is better when you surf.
MD11LuxuryLinr
Well, I agree with the people that say that there is no "best". I'm sure there are people in this forum that would like one engine more than another just because it sounds better when it's wound up for takeoff or because it produces more power than a different brand on a same aircraft. I'm one of those people Big grin
Let me ask this: Which engine manufacturer has sold the most engines overall. I'm going to guess and say Pratt... Including all those JT8Ds they slapped on the DC9s, 727s and 732s way back when..
 Big thumbs up
Caution wake turbulence, you are following a heavy jet.
futureualpilot
Fri Dec 19, 2003 10:07 am
Dont forget all of the engines Pratt supplied to military aircraft. I believe GE also has put many an engine on military aircraft.
syncmaster
Fri Dec 19, 2003 11:51 am
GE has put many an engine on almost all types of aircraft. Everything from CRJ's to 777's to Military and more.
ConcordeBoy
Fri Dec 19, 2003 12:10 pm
I assume you mean RR Trent800... as opposed to GE90 (by far the superior engine for the highest MTOW 777s  Big grin)
Accidentally
Fri Dec 19, 2003 12:26 pm
I've never piloted an aircraft equipped with any of those...I dont see how I or anyone in a similar position can possibly answer that accurately.
Indianapolis, IN
KBOS
Fri Dec 19, 2003 12:36 pm
Lycoming makes the only engine I have ever used myself. I'll take any of the big three as long as they stay attached to the wing.
I don't care if the sun don't shine, I do my drinkin in the evening time when I'm in Rhode Island
